First need to take off the SD card; default settign make the SD card as main stored when this is inside the camera.
Take off the SD card and send the internal memory pics at pc folder (use USB connection); insure that the pics are in this pc folder, them delete the files in "internal memory".
Take on the SD card inside tha camera and send pics from pc folder at camera, confirm that the pics are there.
Hope helps.
SOURCE: Internal Memory to Memory Card
This was a pain for me to figure out. I too had the same problem. This may not be the RIGHT way, but it is how I did it.
First, copy everything you want off the memory card and then insert it into the camera. Format the card.
Then, take a single picture.
Now, with the camera on, hit the playback button to view the picture you just took.
Press the MENU button, and scroll through the menu to the very last entry, which should be COPY.
Press OK, and then you can select to copy from INternal to memory card, or memory card to INternal (note, IN means internal in the menu). You, of course, want internal to memory card, so select it if not already done so, and press okay.
That's all there is too it! I recommend erasing all images from the internal memory once you're done so you don't get confused later if you see images on there again.
Good luck! Ray - www.desertdawg.com
SOURCE: cannot transfer my internal memory photos into my sd memory card
if you insert the card and it would read the card immediately - not allowing you to see the pictures on the internal, that means the image storage is set to AUTO, you have to set it back to internal so you can copy them to card and just put it back to AUTO to reactivate the card
please follow this path:
insert card> turn on cam to auto> press review> "reading memory card" > press menu> scroll down to image storage> press ok to select> select INTERNAL MEMORY> press ok
scroll down to COPY> Copy pictures to memory card> scroll down to all> press ok
message to expect: "copying"
when it goes to back the menu screen
scroll to IMAGE STORAGE again and select AUTO> ok> "reading memory card"
you're supposed to see the copy of pictures from your internal and pics from your card if there's any
you can visit www.kodak.com/go/manuals
SOURCE: PHOTOS ON INTERNAL MEMORY - HOW DO I TRANSFER THEM TO CARD SO THAT I CAN GET THEM PRINTED AT SHOP?
Hi KarenB,
Not sure if anyone ever got back to you on this but i just had the same problem then googled it and found this
Yes, the [BACKUP] feature will transfer files from the camera's internal memory to an xD-Picture Card™ flash memory card. It does not delete those files from the internal memory. To perform a backup, insert an xD-Picture Card flash memory card into the camera and then turn the camera on. Press the [MENU] button. Press the Right arrow button to select the Setup icon, and then press the [OK] button to enter the Setup menu. Use the Up or Down arrow to select [BACKUP], and then press [OK].
Wendy
SOURCE: internal memory photos download to sd card
Press the menu and look for the utilities section on the camera. There should be a copy from memory to SD.
SOURCE: How do I get photos out of my internal memory onto
Here are the steps.
1. Insert the card.
2. Make sure that the storage location is set to Internal Memory.
3. Press the review button, once the picture you want to copy displayed in to the screen, press Menu button.
4. Press the down/up arrow to select COPY then Press OK
5. Select where you want to copy the picture then OK.
Note: Pictures will be copied but will not be removed.
Thanks.
Regards,
Neerak21
Note: When the camera is connected to a computer using the USB cable with a
memory\picture card in the memory\picture card slot, the computer will
only see the contents of the memory\picture card.
Thanks for understanding. Please let me know if you require any additional help.
