Question about Sun MySQL
Problem mysql mysql said: #2002 - The server is not responding (or the local MySQL server's socket is not correctly configured) how can solve tq
  • 30 Answers
I'm not a MySQL wiz, but i played around a bit, and found this.
This is SELinux blocking access to the socket. The easiest way to get around it is to:
1. run system-config-securitylevel (either from a bash prompt or the menus)
2. Select the SELinux Tab.
3. Click the Transition twistie.
4. Select Disable SELinux protection for httpd daemon
5. Click OK
6. Reboot your computer (I know, nobody likes to reboot, but when changing SELinux it seems to be a necessity.)
7. Profit!!!
Good luck, let me know how it went.
Posted on Aug 12, 2008
Could not connect to MySQL
You can start/stop the mysql service on the server by logging into the server as root from the command line interface and run the following command/s.
service mysql stop
service mysql start
service mysql restart
You can also use the following if the above does not work fine.
Fix Toolbox for MySQL
Jul 07, 2016 | Wolfgang Schmuck MySQL
How can I restore my SQL database from .frm files?
You just copy the .frm files to the to the databse folder but you also need to copy the ib_logfiles and ibdata file into your data folder. I have just copy the .frm files and copy those files and just restart the server and my database is restored.
Best Professional Resume Writing Service Online from Washington USA...
Oct 22, 2015 | Oracle MySQL Enterprise Ed 1-4 Socket...
How to solve the mysql error 2003 Can't Connect to mysql server on 'localhost' (10061)
Your client software attempts to connect to a MySQL database instance on your local computer. There is no DB server running locally, hence the error.
Before reinstalling Windows, did you connect to a remote DB server or did you use a local instance?
In former case, you need to configure the DB connection to point to the remote serve. In the latter case, on top of Windows you also need to reinstall the MySQL DB server software locally, and it needs to be started.
Feb 27, 2013 | Sun MySQL
I can't log in, it is saying bad account or password, and then if I hit create new acct it says Warning: mysql_connect(): Too many connections in...
Having a bad day?
Ok, go to IE tools->internet options
Clear your Cache, cookies and History
Close IE
Restart IE
All should be well
If not - the server has reached capacity and no more users can log on at this time and you need to wait.
If this helped please remember to vote
Oct 04, 2009 | Computers & Internet
MySQL server at 'reading initial communication packet'
is the post open to read the mySql Server data ?
Jun 07, 2009 | Sun MySQL
MySQL Database
MySQL Tools
1. A SQL server : This is an engine which provides access to your databases.
2. Client programs for accessing the server : A program allows you to enter queries directly and view results
3. A client library for writing your own programs : You can write your own programs into the client library using C.
Recommended Hardware Requirements For Mysql Installation
  1. Pentium V processor
  2. 128 MB RAM
Note that MySQL can be installed on a platform with as little as 32 MB
RECOMENDED SOFTWARE TOOLS for better performance
IT is recommended to have at least 128MB memory.
You can freely download MySQL from the website MySQL runs on many varieties of UNIX, as well as on other non-UNIX systems, such as Windows and OS/2. MySQL runs on hardware from home PCs to high-end server. MySQL can be installed on Windows XP, Windows Server 2003, Red Hat Fedora Linux, Debian Linux, and others
Sep 08, 2008 | Sun MySQL
MySQL Installation
i advice you to install the last version of apache server version 2.5.10 on your local computer that supports php5 and Mysql version 5.0.51a.
you will find the installation steps in
and the appserv programme in
Sep 03, 2008 | Sun MySQL
OS X 10.4 PHP MySQL problem
To change the location where MySQL creates its socket file, do this:
1. Open your preferred text editor and create a plain text file.
2. Type this text (on two lines as shown):
3. Save the file as: /etc/my.cnf
To change the location where PHP looks for the socket file, follow these steps:
1. In Terminal: sudo cp /etc/php.ini.default /etc/php.ini
2. Open /etc/php.ini in your preferred text editor.
3. Find the [MySQL] section, and change the mysql.default_socket directive:
4. ; Default socket name for local MySQL connects. If empty, uses
5. the built-in
6. ; MySQL defaults.
7. mysql.default_socket = /var/mysql/mysql.sock
8. Change the permissions on /var/mysql so that www can read the socket, by executing this in Terminal:
sudo chmod 775 /var/mysql
Aug 24, 2008 | Apple Mac OS X 10.4
MySQL can't connect Error
Guess you are referring to this error message -
Check your username & password, and make sure that you are authorized to access the server.
If your password & username are correct, there might be a network problem that prevents you from connecting to the machine where the MySQL server is running. To make sure that they are no network failures, click on the "ping" button.
This will "Ping" the MySQL server host. If the host is available (no network failure), you will
receive a message similar to this -
Reply from Time=0ms TTL=128
Reply from Time=1ms TTL=128
If you don't it means there's a problem with the network.
Jul 27, 2008 | Sun MySQL
Sun MySQL Logo
122 people viewed this question
Top Sun Computers & Internet Experts
Robin Hill
Robin Hill
Are you a Sun Computer and Internet Expert? Answer questions, earn points and help others
