Question about Canon PowerShot SD600 Digital Camera
Hello my camera was working fine when i plugged it into the computer. now all of a sudden when i connect it- zoombrowser does pop up and the camera doesnt connect. i am not sure what i did wrong. in the process of cleaning up my computer- i may have accidently erased something i needed !! HELP
    Master:
    Sergeant:
  • 398 Answers
I would go out to canon usa and click on download updates and find your camera and download the software there. This should help you.
Posted on Aug 11, 2008
Can i download zoombrowser for my canon ixus sd200 camera?
You may download Canon software from here.
You don't really need to use ZoomBrowser. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as ZoomBrowser or Picasa.
Feb 28, 2013 | Canon PowerShot SD200 / IXUS 30 Digital...
I'm trying to download photos from the comera onto my computer. The USB cable is connected. I changed "communication" on the camera to PC connection (which made the "busy" flashing disappear). But I still...
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Oct 26, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Canon zoombrowser ex ver 6.4.1 with windows 7
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use ZoomBrowser or any other photo cataloging program.
Feb 20, 2010 | Canon PowerShot S3 IS Digital Camera
I have a A590IS. Pictures will not upload when plugged into the computer. Zoombrowser says it connot detect a camera connection.
Try NOT connecting your camera to your computer.
Dec 15, 2009 | Canon PowerShot A590 IS Digital Camera
Not wanting ZoomBrowser
Start EOS Utility. Click Preferences. Click Linked Software. Select None.
Feb 22, 2009 | Canon Cameras
Another zoombrowser problem
You can use microsoft scanner and camera wizard to download in the meantime. I'm not sure what is going on with your Zoombrowser software. Which Operating System are you running?
Jul 14, 2008 | Canon PowerShot A95 Digital Camera
Canon zoombrowser Ex downloading problem
The sd1000 manual says that you will get this error when you have too many pictures on your memory card (aprox 1000). I am not sure how many I had on my 2GB card but it was a lot. I deleted about 50 - 100 pictures and then it started working again and the new pictures downloaded to the computer.
Jun 28, 2008 | Canon PowerShot SD1000 Digital Camera
Try updating the Zoombrowser software.
If you have a connection to the camera, go into my computer and get images directly off the camera using scanner and camera wizard, microsoft's default program. This will at least allow you to transfer your images until you can resolve the software problem.
If you have no connection to the camera via your computer, you need to try some other troubleshooting steps to get a connection. I will post those below in the next post.
May 30, 2008 | Canon PowerShot G7 Digital Camera
I can't upload pictures from my SD850 to XP
I had same problem: ZoomBrowser had been working fine on XP sp2, but today I found it could no longer detect the camera. My guess is some operating system patch caused it to stop working. I finally got it working again by doing the following:
1) Go to http://software.canon-europe.com/ , select Powershot G1 as the product, and get the list of available updates.
2) Download and install the latest version of ZoomBrowser (6.0.1).
3) Download and (re-)install the USB driver ( Canon Digital Camera WIA Driver 3.9.1). It will probably tell you it's already installed, but continue with the install anyway. It will also warn you that the driver isn't certified for XP, but ignore that and continue.
4) Reconnect the camera to the USB port on the computer and put it into upload mode. *Now* a window should pop up with a selection of programs you can launch, including ZoomBrowser. Yay!
Hope this helps.
Mar 28, 2008 | Canon PowerShot SD850 IS Digital Camera
Go to the "Add and Remove Programs" in your Control panel.
Do a "Change" and do the 'repair program' utility.
That should fix it, good as new.
If that is not a possible option, try uninstalling. (if there is no "Change" and 'repair program') then Run the normal uninstall program.
Oct 28, 2007 | Canon ES-E1 EOS Link (4593a006) for PC
Canon PowerShot SD600 Digital Camera Logo
32 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
