Question about HP PSC 1610v All-in-One Printer
Not printing with all colors
Yellow is the only color that is coming thru and that is somewhat broken up but i have no other color at all
    Sergeant:
  • 291 Answers
Tw options can be done for this
1)get the same colour cartridge refilled
2)or buy a new cartridge.
simple.
as the cartridge is over.u have this two options only
Posted on Nov 23, 2008
I need help with the color there is no red or green went thru the manual and the sample colors are ok, went back to regular program and colors are terrible,
check you cables like a VGA monitor you have three colors Red Green Blue on the cable and if one is broken then the color will not come in correct. on your device that feeds video to the tv try some different cables and inputs it might be a bad cable
Jan 02, 2011 | Philips 42PFL3704D LCD TV
Everything is yellow, is it the bulb, but no error message has come up?
Hi....
It's not the bulb...It's what the light passes thru to pick up the colors
See who fixes BenQ on the web
Apr 21, 2010 | BenQ (200NSH-LAMP) Projector Lamp for...
I have a tv that only shows variations of blue and yellow no matter what i do to the menu color options. However the menu will show all of the colors but not the normal screen.
it sounds like an rgb problem it depends what your playing thru your tv but if its coming thru a component lead eg red green and blue it sounds like your missing the red feature also it could be a pin bent on your scart which is carring the red portion of the picture , What kind of set is it and what are you playing thru it ?
Mar 02, 2010 | Akai LCT2060 Television
Just bought a use apple 23" hd display. The color seems to be somewhat yellow and is not a vibrant as my other apple 23" why
Optical components vary, especially when they have been pre-owned and subject to unknown temperatures and environmental conditions.
You can tune the yellow cast out of your monitor and improve the color range by opening Apple Menu / System Preferences / Displays, selecting the Color tab on the screen in question (two will appear), and running the interactive calibration routine.
Feb 16, 2010 | Apple Cinema Display 23" HD Monitor
My colors are not coming out as they are suppose to everything is yellow or green
Hello, In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. That sounds like your problem. Also in Purchasing the Brother's . Color that should be Yellow, will turn out Green, etc. All Generic Cartridges, will print lines thru the words, and also do a mix match with the colors. That's what the Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, but you have to fill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for the PRINTERS.
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Jan 02, 2010 | Brother MFC-5840CN All-In-One InkJet...
My chain saw
you need the correct size line, it comes new yellow colored now , claimed to be more impervious to gasahol -with a razor blade , cut the end of the new hose on a long enough angle to feed it thru the tank grommet, then you can grab it thru the tank grommet with medical locking forceps - its a snug pull thru the grommet but easy - hope this helps
Nov 21, 2008 | Poulan Pro Chain Saw 46cc 20"
Home screen color
Yes, the home (XMB) does turn color depending on the time of day. This is a default feature. I haven't seen it yellow that I can remember. But check it at different times and make sure it is changing to other colors as well.
Sep 24, 2008 | Sony Playstation 3 (PS3) Console
Yellow is a greenish color
Try printing this test pattern. I got this from this other website. But as ridiculous as I may sound, did you put the yellow cartridge into the Cyan compartment? Because to produce green you need to combine yellow and cyan. This test pattern will tell you which colors are not working properly. Then we can trace which cartridge is the problem or not. Let me know the colors that come out.27dfd86.jpg
Jul 22, 2008 | Brother MFC-410CN All-In-One InkJet...
Yellow Hue when color copying
I understand your situation, however let me explain you that whenever you try to make a copy or print, yellow cartridge takes part and provides its color in all the aspects. Please do check that you use the HP ink cartridges and try to clean the cartridges for every 15 days as this may reduce the issues of colors.
Feb 07, 2008 | HP Photosmart 2710 All-In-One InkJet...
Jvc stereo receiver rx-5032vsl
If your TV is a higher quality set that is HD capable, the problem may be in using RCA jacks. I suggest buying some component video cables. Some higher quality DVD players and TVs do not respond well to cheaper video feed wires. The only other option is a problem with the DVD player since the picture is coming through fine through other DVD sets. Try the wires first, its your cheapest option.
Dec 29, 2007 | Gateway FPD2275W LCD Monitor
HP PSC 1610v All-in-One Printer Logo
26 people viewed this question
Ben Johnson
