Question about Fisher and Paykel GWL11 Top Load Washer
Washing Machine keeps filling with water
My washer keeps filling with water and makes a beeping sound.
Thanks,
Teresa Jackson of Tennessee
  • Anonymous Mar 17, 2014
    my simpson ezisensor swt802sa washing machine wont start water temp keeps beeping
Teresa
Check the drain hose. if the end of the hose is too low it will siphon water continously while the washer is trying to fill and will cause the problem you describe.
Ron
Posted on Aug 13, 2008
WASHER WAS OVER FILLING PUT NEW PRESSURE SWITCH ON STILL OVER FILLING MANUALLY PUMPED WATER OUT MACHINE STOPS AND BEEPS 6 TIMES THEN 1 WHAT DOES THAT CODE MEAN
Can not tell you what the beeps mean because you did not tell us what model washer you have. Sounds like a problem with the water inlet valve sticking open.
Jun 20, 2015 | Washing Machines
Fisher and paykel Smart Drive 9 excellence 7.5 washing machine wont fill at the start it just makes sounds like its trying then starts beeping?
the water soleniod has went bad pull out washer look to where water lines hook up to it turn of water to them then remove hoses unplug machine remove the soleniod valves make sure you write down the wiring order and hose placement on something get new valves replace rehook water line turn on water ect.
Aug 20, 2014 | Washing Machines
Whats wrong with our ge washing machine it keeps draining water,it is brand new just arrived.what do you think is the solutions to our problem. everything is being put together, we already install the...
make sure the drain hose is higher than the washer tub sounds dumb i know but if the drain hose is left lying on the floor going into a floor drain or something it will not fill up
Mar 23, 2011 | GE WBSR3140DW Top Load Washer
Washer seems to cycle fine but the water will over fill
Hello, fill the washing machine with water and when the water is about 1/2 full of water,unplug the washers power cord from the wall outlet.if the water keeps flowing into the washing machine with the power cord pulled the "fill valve"(where the hot and cold hoses are attached to the washer) has mechanically stuck open and will have to be replaced. if the water shuts off when you remove it's power cord from the wall outlet,try plugging the washer in and out a couple more times and if the water stops each time the fill valve indicates as being good.
Thanks
May 21, 2010 | Washing Machines
Wont fill with water
Here is a tip that I wrote about no water coming into the washing machine2_bing.gif...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
May 13, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Fisher&Paukel washer
might have something stuck in drainage area. see my post on "eco smart won't drain, smells hot" on how to remove motor on bottom of washer.
might also try another website, www.ths.gardenweb.com/forum/laundry to see if anyone on there has an answer.
Oct 13, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machine stopped through cycle and now will not turn on
I can help with this. I work on the units they make. If you can email me @ curator@artinallforms.com I will guide you through
Jun 16, 2007 | Fisher Paykel EcoSmart GWL15
Fisher and Paykel (Old model) Fresh 5.0
you probably have a foreign object in the pump impellor - the favourite is bits of bra wire
May 05, 2007 | Fisher and Paykel GWL11 Top Load Washer
Leaky float valve
Teresa, the water fill is usually a timed fill and the float assy. is a safety device to cut power to the fill valve in the event the dishwasher keeps filling. ( In most models). Sounds like your initial fill is just above the float lever actuator and dripping. Check the level of the dishwasher to make sure that the water is not higher toward the front. Catriver..post back.
Feb 10, 2007 | Maytag 24 in. DWU7402 Built-in Dishwasher
Fisher and Paykel GWL11 Top Load Washer Logo
412 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
