Question about Panasonic Microwave Ovens
Panasonic - convection/microwave oven door is stuck shut spring will not open same -dinner in oven help
  • Panasonic Master
  • 8,872 Answers
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be
removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa.
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can order Panasonic parts here.
I hope this picture shows up - it helps illustrate:
Posted on Aug 12, 2008
To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
Posted on Jan 05, 2009
Mine is a NN SD277D. My lever was all flappy and wouldn't open the door. this model is over range model with fan
to access in urgency, remove screws from top vent cover (from the top) and reove that cover. then there are 2 screws on the control section. remove and the panel slides/clicks up a little, then comes out. after you've removed the control panel, you can manually flip open the door lever
my plastic lifter broke, so i glued and replaced.
another method of opening is to use thin wide tool like butter knife or icing spreader type utensil from the bottom of the door to the left of the control panel. you're trying to push UP the levers that lock the door closed. this does work, and is how i got in before i opened the control panel. good luck!
Posted on Oct 09, 2009
The thin blade approach was very helpful, and saved my microwave from the trash heap temporarily. However, my wife came up with an even more helpful temporary 'fix':
Once door is open (use thin blade message described in other messages here), tie some strong, thin thread to the top hook, and extend up through crack in door (a couple strands of embroidery thread wrapped together work great). When you want to open door, simply pull up on the string and door opens easily without the damage of a metal blade on the plastic hook.
I hope it helps!
Posted on May 07, 2010
  • Tom I May 07, 2010
    Apparently, many microwaves use the same door latch, so this approach should work on many different machines. I didn't mention it in my post above, but to clarify, my machine is a Panasonic counter top model.
After the door was open I put a very thin piece of plastic (with double stick tape) on the hinge side of the latches that gently holds the latches toward the edge (control panel side) of the door.plastic measurements-6"x 13/ 16"
Posted on Oct 09, 2010
Microwave keeps running with door open
I'd say the door interlock switch has failed, and supplies a connection when it should not. Microwave ovens can be dangerous to anyone poking around inside, even when unplugged, so get a quote from a service tech. You might find that parts+labour is almost as much as a new one.
Microwave radiation being released through an open door is also a hazard, as it is known to cause eye cataracts, so don't get near if the oven does this.
Nov 19, 2013 | Panasonic Inverter Countertop Microwave
I have a Panasonic Model #NN-S255 microwave oven. The button you push to open the door does not open the door. It's like there is no resistance when you push the button therefore it does not push up...
Hello,To get the door open and salvage your dinner, take a long thin blade ( I used a frosting spreader) and insert from the bottom between the door and the oven frame on the side with the latches (usually next to the control panel). You may have to pry the bottom of the door open just a bit. The object is to push up the lower door latch (which is connected to the upper door latch) and manually open the door. You may have to try a few times but this worked perfectly for me and saved dinner. Obviously the door latch needs to be repaired but this solves the immediate problem of dinner being held hostage by a recalcitrant microwave.
wish you good luck,
take care.
Aug 02, 2011 | Panasonic NN-S255 Microwave Oven
Our panasonic inverter microwave (3 years old) needs repeated hard slams to shut the door so that the light goes off and the microwave will work. How do we fix this problem as I'm afraid we are going to...
We have a Panasonic Inverter microwave. Door became difficult to close and had to slam it hard while holding themicrowave to keep it from moving. When opening the door did not pop open but did unlatch. I ordered a new door lever from Panasonic. When got part I removed case from microwave and lever was okay. I then removed the perimeter strip on the inside of the door. With a screwdriver I stretched the spring at the bottom that keeps the door latches pulled downward. Spring still worked just not as stiff. Put perimeter piece back on the door and replaced housing (which I didn't need to remove in the first place), and then put a small drop of vegetable oil on the cams where the door latches hit when closing door. Viola, door opens and closed as new. Problem solved. Diagnosis: over time the latch tension spring hardens and gets too stiff. P.S.: I had several similar springs as backup in case I screwed up the original one.
Jan 16, 2011 | Panasonic NN-SN657SMicrowave Oven
The renter threw the tray to adapt the microwave to convection oven. I need to know where and how much a new one costs?
Are you talking about the black round pan? I don't think I have any other parts in my Advantium for speed cooking or convection. I occasionally just use an oven safe dinner plate. Sorry I can't help with replacement parts.
Jan 04, 2011 | GE Advantium 120 Convection/Microwave Oven
Microwave oven door heavy
If one of your door springs has failed, you will need to replace both, as well as any associated hardware that has failed.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid Microwave Ovens
Dimension 4 microwave stuck on demo mode
Here are is the manual:
http://service.us.panasonic.com/OPERMANPDF/NNT888S.PDF
Page 13 tells how to shut off Demo mode. (Press FUNCTION-0-2.)
Aug 12, 2009 | Panasonic NN-T888S Convection/Microwave...
GE Monogram Convection oven ZET837SB1SS
I would suspect a couple of wires are crossed.
GE puts mini-manuals in their units, which have wiring diagrams, schematics, etc. Very handy.
It will be folded up in a small envelope, usually behind the control panel or hidden elsewhere. That should help you.
Oct 26, 2007 | GE Monogram ZE2160SF Convection /...
Microwave Ovens Logo
921 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
