Question about Mitsubishi WS-55857 55" Rear Projection Television
Mitsubishi WS-55857 55 in issue
I have a Mitsubishi sw-55857 55 in, and recently started acting up turn on but after 30 minute, and the video signal goes off and i leave it along a turn it on a few minutes later and work fine for another 30 to 45 minutes and so on, but now I can hear the audio but not pic at all, I have the Service manual, and the Schematic Diagrams anyone can help me out what to look for?
    Problem Solver:
  • 53 Answers
Hello Rodfamy:
You will need to look in the small signal board section of your service manual.
Posted on Aug 17, 2008
2 Suggested Answers
thaurfen
  • 623 Answers
SOURCE: sw-55857 issue
check the projection bulb
Posted on Aug 10, 2008
Sometimes the picture rolls for 30 minutes to one hour and then the picture is perfect. A few times when we turn it on, the picture is okay and then after a few hours, the rolling picture starts. Where is...
The rolling is a bad filter capacitor on the signal board in the set---Any Mitsubishi dealer can look the model up and see known faults including this one---some of the sets when cold---vertical jitter in picture or just menu---If the menu is stable you have a tiny bad cap= weak caps when cold act up and when get hot regain capacitance and start to work.
Aug 28, 2012 | Mitsubishi WS-55807 TV
Mitsubishi WS-55613 55in.
1. "wavy" may mean a signal problem inside the set--are you seeing colors out of position or skewed around letters etc?
2. Does it do it when a DVD is played? (this will rule out certain things).
SD TECH
Apr 21, 2012 | Mitsubishi WS-55613 55" Rear Projection...
Hello, my 55513 tv when turning it on was blurry. after a few minutes it became clear. shut off and came back about 3 hours later and it was blurry again for about 10 minutes. about 10 minutes later it...
in the customer menu select convergence when set acts up---look to see if grid of lines is skewed, see some photos and let me know if your problem anything like this..........
Apr 08, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi Medallion rear projection lost signal from all devices
Have you fixed this problem yet?. I seem to have the same issue.
Sep 07, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Green light continues to flicker, TV will not turn on or off.
Unplug it for 30 minutes. Then try again.
Let me know and I'll check the service manual. I've got a 65511.
Feb 01, 2009 | Mitsubishi WS-65809 65" Rear Projection...
Tv shuts off sporadically, and now won't recieve any video signal
Check the solder on the vertical output IC this is a common problem and can cause loss of video while sound remains and often will shut the set down with a vertical deflection error
May 07, 2008 | Mitsubishi WS-55513 55" Rear Projection...
Sometimes it takes a minute to get Reception
White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change
Dec 11, 2007 | Mitsubishi WS-55809 55" Rear Projection...
2 new problems with my TV after my move
Well it may just be the signal in your area that isn't quite as good. That's just fact. Also, because the signal may be weaker, it may take longer for the TV to fine tune to get the best picture quality, which would explain the slight blurring after turning your TV on.
Sep 07, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Open Questions:
Mitsubishi WS-55857 55" Rear Projection Television Logo
90 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
