Question about HP Office Equipment & Supplies
Paperjam in printer - HP Office Equipment & Supplies
    Master:
  • HP Master
  • 262 Answers
Contact the customer care of hp support for paper jam issue you can reach them directly (877-690-9305) Support For Hp Printer
Posted on Jan 26, 2018
    Novelist:
  • 180 Answers
1. Turn the printer off.
2. Unplug the power cord of the printer
3. Open the rear access door
4. Remove the jam
5. Clean the rollers of the printer with a lint free cloth that is moist with water
6. Close the rear access door
7. If you a document feeder open it and try to remove the paper jam and also clean the rollers
8. Close the document feeder
9. Plug the printer directly to the wall outlet
10. Try to print again
Posted on Aug 11, 2008
Paper jam printer
kindly check it what shows in the display:
"paperjam 0" , its related to pick up roller related problem.
"paperjam 1", its related to cartridge unit, kindly re inserted the cartridge.
"paperjam 2", its related fuser unit, kindly open the rear cover of printer, ther you can see the fuser unit. check the one liver from fuser unit to HVPS .
kindly check all these things and contact
Jan 29, 2014 | Samsung SCX 4521F All-In-One Laser Printer
Power lite on my 3250 kodak printer keep flashing & showes paperjam. Cant find paperjam!!!!! GRRRR
Never used this printer but most printers have an access door in the back have you tried that?
Jan 11, 2011 | Kodak ESP 3 Multifunction Printer/ Copier/...
Always paperjam, the printer takes the paper 10cm then warns about paperjam ?
you should clean the roller of the printer with wet cloth, els consult with a qualified technician for technically handle.
good luck
Nov 27, 2010 | Samsung CLP-300N Laser Printer
My canon mp190 gives E3 paperjam error but there is no paperjam how do i fix it?
I have solved this problem with read post at http://slayo.com/how-to-fix-error-e3-canon-mp198-printer.html thanks to slayo.com "Canon MP198 Printer Error E3 is becaused something inside of the printer that makes paper sensor not function properly. To fix this error E3 you must open inside of the printer to remove the things." you must open your printer to remove the things, maybe waste letter or other small part things. Read the post for complete it.
May 18, 2010 | Office Equipment & Supplies
Says paper jam but NO paper is in the machine
One problem i found with those printers is that over time the casting around the paper tray is wearing off and printers starts to show paperjams when there is no paperjam.
One way to fix is try and positions the paper tray better or perhaps raising it a bit with piece of wood or paper.
Cast unfortenately is too expensive to replace so if this doesnt work and you are sure there is no paperjam and nothing obstructing the sensor then replace the printer.
Nov 02, 2009 | HP LaserJet 2200D Printer
My printer says there is a paperjam but I don't see a paperjam.
its a mechanical problem ...
check the rollers of the printer ..and the paper pick mechanism ..maybe it can't caught the paper in the tray that why it display an error of jammed..
May 24, 2009 | HP DeskJet 3653 InkJet Printer
Kyocera paperjam
Normal 0 I suggest you get a sheet of Card Stock (Heavy paper) and place it in the feed way. Then press the print button applying a slight amount of pressure on the Card Stock so it will feed through the printer. The reason for this is in some cases I have been able to clear the paper track of debris that was deposited there over time.
Worth a try, as I have fixed a number of printers this way, saving costly repairs.
Hope this helps. Bud
Jan 02, 2009 | Office Equipment & Supplies
PaperJam
I found that the little plastic hinge guide that supports/aligns the scanning area with the printer (stage 4 on the internal paper jam problem) was misaligned. I just removed it and the printer now works OK
Aug 28, 2008 | Samsung CLX-2160N All-In-One Printer
Printer
Sometimes just a teensy bit of paper stuck inside will make it say paperjam. I would check very well.
Dec 11, 2006 | Canon I900D InkJet Photo Printer
100 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
