Sorry, no. If it fit onto a Pentax camera then the lens has a Pentax mount. The Nikon (I assume you mean the D80 digital camera, or perhaps the N80 film camera) has a Nikon mount. Since the Nikon mount has a deeper flange distance than the Pentax mount, there are no adapters available to allow you to fit a Pentax-mount lens onto a Nikon camera.
Do you mean the lens, or the LCD screen ? Either way, with equipment this old, repair is not economically viable - get a new one, and treat it with care.
Your camera is faulty. It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts. Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks Richard Scott Technical Support New Zealand
I had the same problem - and wondered if if might be that the battery didn't have enough 'grunt' to close the lense - so I am charging it via the actual charger (rather than through the computer) and sure enough, I turned it on and then off, and the lense closed. The green light comes on when I plug the camera into the computer to download photos, and I thought this was therefore charging the battery, but maybe it doesn't charge it properly. Anyway, my lense is now closed and the battery is still charging (light is still red). Good luck.
Hershey, take a small pair of needle nose pliers and try and wiggle the lens and it should work! I just did it with my daughters camara
(Same camara, same error message) Good luck!!
Give the lense side of the camara a few moderate slaps while moving camara from bright to dark obgects back and forth. the shutter gets stuck and doesn't respond to changing light. that's why outdoor pictures are usually too bright and indoor pictures are black.
good luck.
Does your battery work with regular AA alkaline batteries ? They have higher voltage than NiMH rechargeable. I'm having a similar problem, just discovered today that my camera works fine with AA alkaline batteries.
