Question about Refrigerators
LG LRSC26940ST Defrost Heater Problem
Error Er dh. Need to fix myself. Need help with finding the right part and replacing faulty part.
  • ourdesert
    ourdesert Aug 10, 2008
    I talked to LG. They had me unplug it for 3-4 hours. Did that! Displayed Error Code again. Emptied the refrigerator and let it defrost completely. A day later, plugged it back in and it ran until the back of the freezer defrosted over. It's empty again and I have everything removed from the back of the freezer compartment. The evaporator coils are showing. I have pictures that I could email. I have the owner's manual and the service manual. I believe that I know what part I need. The exploded view shows the part floating in the picture. I have the part number but the last page of the service manual (page 143) is not there. That would be that parts list page. I need some help! I will not except that I can't fix it until I know why that is. Certain things I could see a problem with me fixing. So far with what I know between taking it apart and such, I can fix it. The fact that companies don't want you to fix things yourself is causing me to come to you for help. I will not rest until I can get someone to help me. Not just someone that wants to take the easy way out. I was not satisfied with my first response back... Sorry, but thanks but no thanks... Not good enough for me! I don't give up that easily! If there is someone who will help me through this, could you please give me the benefit of the doubt. I have fixed many things! I just need some more input. I would be very grateful! Let me know!
  • 3,037 Answers
Please post the part number that you need for this and I will find a place that you can order it from. If you have any other questions, let me know
Posted on Aug 11, 2008
  • Refrigerators Master
  • 6,487 Answers
Check this link it will be helpful to your concern http://appliancejunk.com/forums/index.php?topic=1039.0
Hope that helps........
    Master:
  • 623 Answers
Call 411 for nearest lg lab
Posted on Aug 10, 2008
I am getting error code dH.. What is this?
Thank you for contacting fixya.com.
DH means defrost heater and refrigerator computer is not sensing the defrost cycle. It is due to a bad defrost sensor located on the evaporator behind the plastic cover in the back of the freezer compartment. You need to replace that.
Also check this link if it helps:-
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Please get back to us if you have further query else please accept the suggestion.
Jun 02, 2011 | Kenmore 73503 Stainless Steel Bottom...
Problems for Refrig. Kenmore Elite
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
Message ER DH continues to pop up on the door. If
ER =ambient temp sensor failure
DH= defrost heater
Defrost heater, temperature fuse short
circuit, unplugged connector(indicated
4 hour later after trouble)
You is gonna have defrost problemas!
Feb 24, 2010 | LG LRSC-26922 Side by Side Refrigerator
LG code ER DH, Defrost Heater or Thermistor?
Check for current flow through the defrost heater. If no current then replace the heater. If heater is OK check thermistor for correct operation. From service manual chart (their words not mine): ER DH is Poor defrosting. Indicates: Even though it is passed 1 hour since then
Defrosting , if Defrosting
sensor is not over 8°
Remarks: Temperature fuse Disconnection,Heater
disconnection, DRAIN Jam,
Poor Relay for Heater
Aug 11, 2009 | LG LFX25960ST Stainless Steel French Door...
Door display shows ER WITH A UPSIDE DOWN HP. I turn the power off and back on and the display goes back to normal but after several hours it goes back to where the only thing on the display is the ER PH...
That stands for "error defrost heater"
Even though the refrigerator has gone through a defrost cycle, if a temp sensor does not reach a set temp within an hour, that error will display. You may have a bad defrost heater, defrost relay, thermal fuse, blocked defrost drain,..... something wrong with the defrost system anyway.
Aug 03, 2009 | LG LFX25960ST Stainless Steel French Door...
I have error code ER dH. Unplug and then replug
Error Code - erdh
Kenmore and LG 795 Series. Model 795.77556600 but most models use the same repair. Controller Part # 6615JB2005H
To Verify correct part. Check part number for your model number at
www.searspartsdirect.com
Don't be intimidated by this repair... The 'erdh' error code indicates - error defrost heater. Replacing the controller is EASY. The difficult part is removing everything in the freezer section to access the evaporator coil but hang in there and stay with it. You will not hurt anything if you use common sense.
The new part (defrost controller) is relatively inexpensive ranging $10 - $14. Here in the SouthWest I used Appliance Parts Depot for a $10 part cost. Don't forget to have 3-4 small wire ties to secure the defrost heater, defrost sensor and wires.
It would help to write down a few notes of some of the particulars during disassembly.
I had the same ERDH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel.
(See Diagram Image) I accessed it by removing the freezer door, all components inside the freezer, including the slide rails / tracks mounted on the sides of the freezer. Be careful when removing the rear white panel because an evaporator fan is mounted on the back of it and plugs into the back left side of the freezer compartment. You just saved yourself about $375 or more.
Stay With It & Good Luck!
Feb 17, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore Elite Refrigerator error er dh
Sep 21, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
LG Refrigerator Defrost Error ER DH
it the def t-stat, def. thermistor, or def. fuse whatever lg decides to call it this week that is causing your issue
Jun 13, 2008 | Refrigerators
Great advice from medeer, I had the same ER DH error code, and my refrigerator began to warm up. I replaced the defrost thermostat assembly part # 6615JB2005H which is located inside the freezer, on the right side behind the white plastic panel. I accessed it by removing the freezer door, all components inside the freezer, and the tracks mounted on the sides of the freezer. Be careful when removing the white panel because a fan is mounted to the left side of the white panel and plugs into the back left side of the freezer compartment.
Found the green technical data sheets under the refrigerator in a small plastic bag near the front.
My refrigerator is 20 months old, just a few months past the warrentee,
Feb 19, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
Hi. You have an Error Defrost Heater. Its taking too long for the heater sensor to open the circuit during defrost. You normally replace the heater, heater sensor and circuit board(motherboard) located on the back of the refrigerator in this situation. Check your mollex plugs and make sure they are connected tightly at the evaporator coil area. Sometimes they come loose. I reccommend replacing the heater and heater sensor located top right on the evaporator coil. This should take care of the problem. Need parts see me on ebay as user, themackshack. Good luck, Mack
Jan 02, 2008 | LG LRBC22544 Bottom Freezer Refrigerator
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
