Clean the sensor first the receptive sensor is located UNDER the printhead, You can see the LED light near the bottom of this area. Tilt the printer back to see this area better. 1. Verify the latest driver and firmware is loaded. These are found at this link: http://www.fargosupport.com/ 2. Calibrate both the Ribbon and Film sensors. This is done through the driver from the TOOLBOX.
1st when the
airbag light is on the system is disabled, so if u have an accident
they will not work, as to the common cause read below.
When
the airbag light is on it means a fault has occurred in the system
and the airbag diagnostic monitor has disabled the system, the most
common problem that turns the light on is a break in the connection
to the steering wheel mounted airbag, this is due to a rotating
ribbon contact that breaks under the steering wheel that connects the
airbag to the wiring harness and the diagnostic monitor, the part is
called th clock spring contact, a coiled up ribbon electrical contact
that turns with the wheel
