Beko WMA 765 s no water entering the start buton dos not lit and have flaching lit on the maine wash lite
Follow your user guide instructions to reset it.
make sure also door interlock operation is ok
"turn the power off , hold start and pause together , turn dial to 90.
turn the power back on , keeping hold of start and pause , wait 5
seconds. take your hand off start and pause all the lights will be
flashing. put your hand back on start and pause turn dial to spin wait
another five seconds , let go of start and pause.
this should reset the system.
please rate thanks ;-)
Check your push button operation.
for spare part have a look at link below
http://www.4ourhouse.co.uk/cgi-bin/search.pl?query=Beko%20WMA%20765%20S&brand=Beko&model=WMA%20765%20S&path=66991,110919:66999&model_pre=WMA%20765%20S&shop=beko
WHAT IS WRONG WITH YOUR WASHING MACHINE?
For a detailed Washing Machine illustration, click below.
Top Load Maytag Style
Front Load Maytag Style
Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
No water is entering the wash tub
or no hot water
or no cold waterCheck that the water supply valves are turned on
Inspect the water supply hoses for kinks
Check the filter screens
Test the water level switch
Test the water temperature switch
Test the timer control
Test the water inlet valve
The water inlet valve connects the hot and cold water lines from your home to the back of the washer. The solenoids on the valve open one or both valves to provide the proper water temperature for the wash cycle. If the valves are blocked or the solenoids do not activate, the symptoms may include no water, low water pressure, the wrong water temperature or water entering the tub even when the machine is off.
The water inlet valve can be identified by the water hoses connected to it at the back of the washer. Start by turning off the water supply at the valves on the wall. Disconnect both hoses from the back of the washer. Place the hoses into a bucket and turn them on to confirm that you are getting good water pressure and to clear out any debris from the line.
Inspect the filter screens on both the hoses and the inlet valve for debris build up. If you find any debris, clean it out. Use caution to avoid damaging the filter screens because the screens in the valve are not replaceable.
If debris was not present then proceed to the next step of testing the solenoids. Access to the valve may be easiest by opening the top or the back of the washer, depending upon make and model.
Page 1 of 2
Next Page
did the solutions from all of us experts solved your problem if not then let us know the current updates so all the fixya experts can assist you further
Latest updates of the problem!!!
Problem:Machine does
not fill with
water.
reasons: Tap may be turned off. Open the inlet water taps fully.
Water inlet hose might be
bent.
anserw:Straighten the water intake hose.
Water inlet filter might be
clogged. Clean the water intake filter.
The door may be ajar. Close the door.
