Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I have 2 garage doors
One side works and the other side blinks yellow can you hellp
  • Glenn Mayer
    Glenn Mayer May 11, 2010
    please let me know more info ,one side of what works ?and the other side of what blinks yellow? please explain the whole question ,this is extremely vauge and i only would be guessing ! thanks glenn
  • STEVE WOLFINBARGER
    STEVE WOLFINBARGER May 23, 2010
    IS IT THE SAFETY EYES BLINKING YELLOW? IF SO IT IS EITHER A BAD WIRE OR OUT OF ALIGNMENT. BE SURE THE EYES ARE POINTED AT EACH OTHER. IF THEY APPEAR TO BE OK CHECK THE WIRES. IF YOU CANT FIND ANY LOOSE CONNECTIONS OR BREAKS TRY CONNECTING WITH (TEST) WIRES TO BYPASS THE EXISTING. IF IT WORKS THEN YOU MAY HVE TO REPLACE THE WIRES. THEY SOMETIMES ARE DAMAGED INSIDE THE WALL. THE ACTUAL SAFETY EYES CAN BE BAD BUT VERY RARELY HOPE THIS HELPS
    President:
  • 3,197 Answers
They are not aligned properly. Tweak them until it quits blinking.
Posted on May 23, 2010
Tip
2010 BMW 528XI Garage Door Opener Homelink Setup
**** >>> This setup I performed with my new 2010 BMW 528XI Garage Door Homelink and Chamberlain Garage Door Opener <<< ****
Chamberlain:
01. Power off or unplug the garage door opener motor power supply (which is mounted on ceiling of the garage) ;;;
02. keep the garage door opener transmitter in your hand (do not press any button at this time) ;;;
03. In your 2010 BMW 528XI Homelink button (which resides under rear view mirror) press the 1st and 3rd homelink button together for about 30-40 seconds (i.e., until the yellow light blinks fast) and when the yellow light next to the homelink button blinks fast release from pressing the (homelink) buttons ;;;
04. now hold the garage door opener transmitter closer (means within 2-4 inches) to the homelink button (either 1st or 2nd or 3rd) whichever you are planning to program to open the garage door ;;;
05. now press the garage door opener transmitter button and chosen homelink button (either 1st or 2nd or 3rd whatever you need) together ;;;
06. the yellow light (next to homelink button) initially may blink slowly but after few seconds (may be 10-20 seconds) will blink fast; once it started blinking fast release from pressing both garage door opener transmitter and homelink button ;;;
07. Now plug or power on the main garage door opener motor (which is mounted on garage ceiling) ;;;
08. On the main garage door opener motor (which is mounted on garage ceiling) press the "LEARN" button (once you press it may have yellow/orange color light; make sure the light is on) ; then within 30 seconds do the next steps #9, #10, #11 very carefully ;;;
09. go to your car and press the homelink button you programmed and hold it for 4 seconds and then release it --> 1st iteration ;;;
10. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 2nd iteration ;;;
11. again hold the same homelink button you programmed and hold it for 4 seconds and then release it --> 3rd iteration ** important note; generally three iterations are not necessary; and steps #9, #10, #11 must be performed within 30 seconds ** ;;;
12. during one of the iteration you will hear "CLICK" sound one-time from Garage door motor (which is mounted on ceiling) and if you have light attached with it; it will blink once (** if you hear the CLICK sound and/or light blinks once**) then the particular homelink button is programmed ;;;
13. now press the programmed homelink button; the garage door will open or close (but always it will take 3 or 4 blinks in yellow light or 2-3 seconds before the garage door opens or closes and which is normal) ;;;
** Thats it, your 2010 BMW 528XI Garage Door Opener Homelink setup is complete ** ;;;
You can program rest of the homelink button the same way but following from the steps between #4 and #13 ;;;
Hope this steps will help you to program chamberlain Garage door opener in 2010 BMW 528XI Homelink. ;;;
** possibly the above same steps may work with other BMW 5-series cars homelink too (but I'm not sure) **
on May 29, 2010 | BMW 528 Cars & Trucks
Car garrage door opener
smart or learn button is located on the back of the garage door opener. (the machine that is over your head) on most units such as liftmaster, craftsman, chamberlin. its on back or side by the light bulb and is green, yellow, orange/red, purple. genie units are black button behind light cover. or external on old units. push and hold your cars homelink button will blink slow, at the same time push and hold the remote for the garage door. led light in car will blink fast. let both go. now go to the garage door head unit, (overhead) and push the learn button. button will blink and you have 30 sec. to go to car and push the cars garage door button. head unit should flash its light, letting you know that it is programed succesfully. genie units push 3 times
Dec 10, 2013 | Building Materials
Door stopped working when I was trying to adjust the door. Blinking yellow light on the overhead unit
The motor has a thermal overload that will turn it off it if starts to overheat. Normally a 15 or 20 minute rest and it will automatically reset. The blinking yellow light may be sending a code. If it blinks 5 times and then pauses and then repeats it is the overload.
Feb 10, 2011 | Sears Craftsman LiftMaster Chamberlain...
DOOR CLOSES MOST OF THE WAY AND THEN OPENS. LIGHT THEN BLINKS TEN TIMES. I NOTICED THAT ONE SAFETY SENSOR IS GREEN AND ONE IS YELLOW. PLEASE ADVISE.
Hi. The sensor with the yellow light is telling you that it is miss-aligned, Usually it only takes getting bumped to knock them out of alignment.
I would slowly turn or adjust the positioning of the sensor.
The one with the yellow light should turn green when it is all the way in line so that the beam is completing it's path.
It's out of adjustment, so the sensor is looking at it like there is an object blocking the door from closing.
It's called the obstruction sensor.
It's there as a safety feature, so that the door doesn't come down and smash anything in the opening.
I hope this helps you out.
Feb 04, 2011 | liftmaster Garage Door 1/2 Hp
One of the sensors on the side of the door is yellow, the main unit hanging in the garage has a yellow light, and it only closes if we hold the button down. otherwise light blinks and it kicks back, like...
senor are obstructed, gently wipe off the lenz, look for any dust, cob webs or loose wires.
make sure the eyes see each other ( look for the lites on the side) one green and one yellow, tap on to make sure they do not flicker, move them around until you have a strong steady lite and then tighten down. this should solve your problem
Sep 12, 2010 | liftmaster Chamberlain Garage Door Opener...
Door won't close, blinks 10 times, sensor light yellow
Anytime the main light flashes 10 times and the door reverses to the open position it is a door sensor problem or the wiring to them. Nothing else causes this symptom.
Sep 13, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door indicator light blinks 5 times
this probably means you have a bad photo eye if you happen to have to doors side by side may be picking up on other sides photo eye just switch sides from left to right, however if the lights are coming on but does not mean that photo eye is not bad it has a small circuit board inside of it...
Apr 03, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door opener motor will not open garage door
It sounds like you did a really good job! My Craftsman 1/2 hp gar. dr. opener has a red reset button on it on the l/h side as you are looking at the light/motor from the garage door opening. You have to take the light cover off to be able to see it. My reset button is on the same side as the ground wire. You might check the ground wire while you're there. I really hope that this fixes it for you (and me). I'm quite sure it will as you know your way around the garage door opener already. Good Luck and Let me Know (Please) if it fixed it or not. If I think of anything else, I'll let you know. Have a Good Day!
Jan 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
21 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
