Question about Casio HR-8TMPlus Calculator
Printing error Each time I print calculation I get a printing error display.
  • Anonymous Mar 25, 2014
    cant get the me off the display so calculator will not print
  • 21 Answers
The problem is with the printer. try to examine if the printer head is on the right side. the default must be on the right side. if you can't move the printer head towards the right it means it got stuck up. if you will look inside it you will see a 'rail like' object on the bottom of the printer you can push it down with any pointed object for the pinter head to get back to its original position. if this doesn't solve the problem look for the nearest service center coz the printer needs an alignment.
Posted on Sep 30, 2008
The display for my P170-DH Calculator is difficult to read (not bright enough). Any suggestions?
unfortunately is claims to have
Display
Display Type
Fluorescent Tube Display
Digits Displayed
12 digits
And you know how florescent tubes dim with age. Time for a new one.
https://www.usa.canon.com/internet/portal/us/home/products/details/calculators/printing-calculators/p170-dh?selectedName=BoxContent
Jul 06, 2016 | Office Equipment & Supplies
Calculator will not print
I don't think you'll find parts for this, however I did find a used one, buy it now, for less than $20, shipped: http://cgi.ebay.com/Texas-Instruments-Electronic-Printng-Calculator-TI-5045_W0QQitemZ160148715050QQcmdZViewItem Buying a used unit and either replacing yours or using it for parts is probably your best bet.
Sep 20, 2007 | Texas Instruments TI-5045 SVC Calculator
On screen show E and can not print or .How to remove
Your calculator is beyond repair. You can use it in no print mode ohly. The printer is not working, causing the error code.
Turn it off and back on and only use the display mode.
Dec 15, 2015 | Canon P27-DH 12 Digit Mini Desktop...
I will be adding up multiple things, it is printing great, and then the screen goes blank except for a small "e" appears in the lower left hand corner and I have to start all over. WHY?
Oct 22, 2015 | Canon P23-DH III 12 Digit Printing...
Why In my casio apears one P word in the display, like an error?
From Casio support:
First, check the batteries, and ensure there is not a paper jam in the printer.
If both are fine, then while the calculator is in the "Print" mode, press the [CA] (or [AC]) button 20 times consecutively to clear out memory buffers. Try some numerical calculations, and if the problem persists, repeat pressing the [CA] button 20 times.
If the problem still persists, then the calculator may require service.
Apr 28, 2014 | Casio HR8TM Calculator
Can't print due to E displayed. I already pushed the reset button on back of machine and it did not remove the E
The same thing happened to me. Wouldn't feed paper and the printer function didn't work. The E was in the lower left of the screen. I took the ink cartridge out and reseated it and that fixed the problem. It was installed incorrectly direct from the factory as my calculator was new out of the box.
Mar 08, 2012 | Canon P23-DHV Calculator
How to turn printing on and off?
PRINT KEY: To save paper you can only print what is displayed, even in non-print mode. Pressing after the entry of a number will print the entry with the symbol “#” even in non-print mode. Pressing will insert a separator into a number entry such as a code, date, etc. Separators are displayed as a period and dashes but printed as periods. MEMORY + KEY / PRINT ON / OFF KEY: Pressing selects print mode or non-print mode. Cause the calculator to operate in a display / print or display only mode, depending upon the calculator’s present state. “P” on the display: Print mode. “NP” on the display: Non-print mode. MEMORY – KEY / DECIMAL SELECTION KEY: Pressing sets the number of decimal places in the result. “F” on the display: The answer is displayed in the floating decimal system. “3, 2, 1, 0” on the display: Presets the number of decimal places in the answer. “A” on the display (Add mode): The decimal point in addition and subtraction entries is automatically positioned to the 2nd digit from the lowest digit of entry number. Use of the add mode permits addition and subtraction of numbers without entry of the decimal point. Use of , and will automatically override the add mode and decimally correct answers will be printed.
Aug 18, 2010 | Sharp EL-1611P Calculator
How do I set it to calculate without printing?
Press b172726.jpg to select print mode or non-print mode.
One of the following is displayed on the LCD:
Dec 08, 2009 | Sharp EL-1611P Calculator
Won't print/feed
Try removing the batteries in addition to reseting the calculator.
Oct 12, 2007 | Canon P23-DH Calculator
Casio HR-8TMPlus Calculator Logo
349 people viewed this question
Top Casio Office Equipment & Supplies Experts
Piyal Perera
Piyal Perera
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
