Question about Tiny Computers B1996 19" CRT Monitor
My Acer monitor sleeps on red instead of amber. Is this a problem?
  • minnie348 Aug 13, 2008
    Thank you for your help. I like my new monitor and want to take care of.
    Sincerely
    Minnie Rogers
    Master:
  • 623 Answers
Try this website
http://xbitlabs.com/articles/monitors/print/20inch-5.html
i know this will help
Posted on Aug 10, 2008
  • 6,487 Answers
Is your monitor still working fine even when the light is red while in sleep mode? because if the monitor is still working fine this can only be a problem with the monitor light...
  • 928 Answers
Different monitors have different indicator lights. If you do not expereince any problems with the monitor then it is ok
SANYO LCD 24K40 TV instead of Red or Green the power indicator display Amber color
press the helpful button,
the amber light may be for stand by or sleep mode, go into your tv setup and check that these are turned off
Jan 12, 2016 | Sanyo Televison & Video
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
LCD AOC 2436Swa is stuck on active-off mode
tried to unplug the unit and don,t use for a while to reset the power supply as will as the main board.
Jan 08, 2013 | AOC 2436swa 23.6" 16:9 Lcd Monitor, 5 Ms -...
Amber light contineu glow
The amber light verifies your monitor is connected to primary power. The internal power supply is dead, otherwise the amber light would change color when the switch was operated.
Sep 02, 2012 | Acer AL1916W 19" LCD Monitor
Acer V173 with flashing amber led. No picture. cable good. other monitors work at this connection.
I have this same problem. Blinking amber Light and no display. on close examination I am seeing the video image attempt to come up, but with no back lighting. I think there is a power supply problem. I will post again if I learn more.
Feb 24, 2011 | Acer V173 b Monitor
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
Amber colored power light on eMachine W3503
The amber power light indicates that your computer has been "sleeping" or "hibernating" and usually all it takes to restart the computer is tapping a key on the keyboard. If this is not the case, try holding the Power switch down for 6-10 seconds to force the system off. Restart in Safe Mode and try to find the settings for Sleep/hibernate, open the control panel and open the Screen Saver. Select "Change Power Settings" and set it for "Never" on sleep and hybernate.
Nov 10, 2009 | E-Machines W3503 PC Desktop
Acer AL1917 Monitor does not start up immediately.
You'll need to have your power board -inverter redone.
The capacitors are starting to fail and that eventually will stop it all together.
I repair many monitors through ebay with these types of problems.
If you take it apart and send me a picture, I can usually see the problem areas.
ebays
bammbammfran
Nov 05, 2008 | Acer AL1917W LCD Monitor
Monitor
OPEN MONITOR , look inside the PC BOARD around the transformer area and look for a burnt solder or cold solder , re solder it , and try again , please rate solution , thanks AJ
Apr 28, 2008 | Acer AL2216W LCD Monitor
Tiny Computers B1996 19" CRT Monitor Logo
73 people viewed this question
Top Tiny Computers Computers & Internet Experts
David Payne
David Payne
Are you a Tiny Computers Computer and Internet Expert? Answer questions, earn points and help others
