Question about Whirlpool Dishwashers
Whirlpool adg 9573/2 error code f2 - Whirlpool Dishwashers
  • jkendall Aug 10, 2008
    Received error code f2, added rinse aid and salt, still no change. Now the dishwasher does not even power on. Have seen internal water leak mentioned elswhere, but no idea what to do.
  • jkendall Aug 11, 2008
    Removed power to the machine overnight and it now powers up again, but still with the F2 error after the initial empty process.
SOURCE: adg 3962 IX showing fault code f2 with flashing
The machine has a switch inside that activates when a set amount of water is loaded.
If this switch then breaks (switches off) during the wash the machine assumes that the water has leaked out.
Run it through a couple of washes, check for a leak and see how it goes.
Hopefully it will be fine.
F2 indicates a flooded base.
Press and hold the start button until the start light goes out. (This resets the appliance)
Select a new programme and try the machine again.
If it comes up with a fault F2, take the panel off below the door and check for water in the base.
Be careful when you take the panel off, the exposed edges are razor sharp.
Drain any water in the base, reset and try the machine again and watch for a leak through the inspection panel.
Posted on May 24, 2010
Looking for answer to error code F5 on Whirlpool Dishwasher ADG 8200
Fault Code F5 or Five Flashes
Cause: Spray arms are blocked/clogged or otherwise malfunctioning.
Action: Spray arms are easily removed so take them out of the dishwasher and wash in the sink to clear out any gunk (using descaler should help shift any stubborn debris). Whilst doing this run the dishwasher on a short program without the spray arms to clear any further blockages.
Jul 14, 2016 | Whirlpool ADG8200 Dishwasher
Whirlpool ADG 8296 error code E1 F8
Check with one of the online "appliance parts" stores. Most likely they know the answer and can help with the part and it's replacement.
Apr 24, 2015 | Whirlpool Dishwashers
Why Whirlpool ADG-6558/1 IX stops sometimes the wash cycle after 15/30 min?
reset the panel by hitting normal-- heat dry NOT at the same time until all lights flash then push cancel and it should start. element is going bad
Jun 02, 2014 | Whirlpool Dishwashers
Adg 3962 IX showing fault code f2 with flashing
May 24, 2010 | Dishwashers
Whirlpool ADG 6556 flashing code
Refer user guide for the correct meaning!
Meanwhile Check all the dispensing compartments- salt - rinse-aid, free inlet water flow and the door close.
May 20, 2010 | Whirlpool 24 in. ADG6552 Built-in...
Reset control panel for Whirlpool ADG 4952
whirlpool adg4952m is reading F2 and not working
Jul 04, 2009 | Dishwashers
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool diwasher adg 9142
Check the inlet strainer at the bottom of the machine for blockage.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 23, 2008 | Whirlpool 24 in. DU930PWP Built-in...
Dishwashers Logo
134 people viewed this question
Top Whirlpool Dishwashers Experts
Mike Cairns
Mike Cairns
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
