Kenmore Series 70 Washing Machine - won't drain water
Washer seems to agitate fine, but will not spin and drain water. PLEASE HELP!!!
Thanks, in advance!! Series 70 kenmore washer won't spin or drain water.Problem started when machine went out of balance. I shut down machine but after re-arranging the clothes and attemting a re-start,nothing happened.
  • 15 more comments
  • Anonymous Mar 11, 2014
    ricoh copier -gestetner 2718z+ faint printing after replacing the old developer with a new one together with toner
    My Sony DAV-880 is showing lock while ejecting CD plate how do I unlock it pls
    I need to access bottom panel to clean out drain
    normal rpm should idle for 2000ques
    Have a 2009 Nissan Sentra trying to replace front door checks and the one that we are getting from our nissan dealer are not the same bolt pattern they are about 1/8 of inch off (80430-ZT50A) has any one else ever had this problem and how did you fix it
    how do i set the time and date on a epson wf2530 printer
    Starter does not engage, No dash lights, no lights, nothing. Truck was working fine before.
    replacing driver side mirror on 2006 pathfinder does door panel have to be removed?
    how to put freon in 2005 KIA Amanyi
    want to register new shaver PT860
    my laptop video is stops when i play video
    my rockola grand salon is on free play and i want to switch it to coins it only has the box on the side with three switches and the coin mechinism with the wires and i don't know what to do please help
    It got jammed up after doing button holes and now it won't change stitches
    I downloaded free eBooks from the iPad. I deleted them after reading, but when I go to books purchased, they are still there. I'd like to delete them.
    please show where wires go so I will connect [properly toop many rotted
    kb-300 produces no sound
  • Anonymous Mar 16, 2014
    lint on clothes coming out of washer
  • 2,071 Answers
WHAT IS WRONG WITH YOUR WASHING MACHINE?
Kenmore Series 70 Washing Machine - won't drain wa - small_11_21.jpg For a detailed Washing Machine illustration, click below.
Top Load Whirlpool Style
Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Hope this may help;
DON'T FORGET TO RATE:
Posted on Aug 10, 2008
SOURCE:
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
My Kenmore 70 series is 18 years old. It will not
Hello. Since your machine is 18 years old and the agitation/spin is costly to repair I would definitely recommend a replacement washer.
Jul 06, 2009 | Washing Machines
Kenmore series 70 washer will only fill with water.
I recently had this problem. It was found that the main drive belt broke and the washer would fill but not spin, agitate or drain. I replaced the belt and everything worked again. A defective or disconnected cover switch would also cause the same problem.
Jun 30, 2009 | Kenmore Washing Machines
70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 27, 2009 | Kenmore 22422 Top Load Washer
look at the bottom of the control panel on the end caps and back out the two screws then pull the control panel slightly forward and tilt it back then you should see gray wires either going in the body of the washer or to a switch on the left side un plug the harness and put a jumper wire across the connector going to the control panel then try spin
Feb 15, 2008 | Washing Machines
i have a kenmore 70 series washer model 10020722990
it will fill with water but will not wash. if you put it on spin the water will drain but it will not spin. it sounds like the motor turning. is it a clutch that has broken.
Sep 05, 2006 | Kenmore 22422 Top Load Washer
Washing Machines Logo
512 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
