Dell OptiPlex GX270 PC Desktop Logo
Posted on Apr 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Orange light on Dell GX270 power button - Dell OptiPlex GX270 PC Desktop
Anonymous
Level 2:
New Friend:
  • Expert 49 Answers
  • Posted on Apr 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
49
Questions
0
Helped
9381
Points
105
According to dell there is an internal power problem.
http://support.dell.com/support/edocs/systems/opgx270/en/ug/specs.htm
http://support.dell.com/support/edocs/systems/opgx270/en/ug/solve.htm#1177038
Good luck
Orange light on D
Ha! We used to have loads of these - if I recall, it was a network adapter error - otherwise, check the motherboard for blown capacitors, they'll be bulging or even spewing yellow gunk out the top. This was a very common issue and Dell should replace the board free of charge.
For more info, see http://www.dell.com/support/Manuals/us/en/19/Product/optiplex-gx270
My Dell Optiplex 745 Desktop PC Power light orange blinking how can i solved it..
The orange blinking on your desktop power button says that there's a problem with either the power supply or the motherboard itself.
Please refer to this link for the diagnostic lights on dell computers.
What you can do is: 1. unplug the power cord 2. press the power button, hold on it for more than 5 secs 3. re-plug the power cord on your CPU 4. test if it the system will work.
If this troubleshooting step does not help, that means it is more likely that the problem is with the motherboard.
Hope this helps!
What does the blinking orange light mean on my dell CPU, I can't get it to power up
dell only knows 2 colors blue and orange... if you have no light on the mother board when power is plugged in. then your power supply is probably gone. considering you didn't mention beeps I would say thats it.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
PC is flashing orange light on power button and wount boot up
hi
you have problem with your Disply setting just change from bios it will start
2answers
Optiplex light blinks, fan goes for a second but won't turn on
you may want to do a search on the dell website, i had that problem and never fixed it, you might find the information under service manuals search.
good luck.
3answers
Can anyone tell me what the orange light on the power button means? I am using a Dell GX270 and the PC will not start. You can power it on but nothing happens.
If you are getting an orange which we call in technical terms amber colored light it means that your PC required either the power supply to get replaced or the motherboard (Blinking amber or steady amber) both are guiding towards the same issue. It is better you first check it with the replaced power supply if not then motherboard is the sure shot solution
2helpful
2answers
Dell Optiplex GX270 will not start and power button is orange
I think that it is most likely that this is a power supply going bad. These can be purchased cheaply on eBay (make sure the picture matches). This replacement is moderately technical.
The other good possibility is a bad capacitor(s) on the motherboard. This is very common for the GX270s due to a manufacturer defect. Most of them failed in years 2-4, though. This would require a replacement motherboard (very technical). Pictures of bad capacitors: http://brianmorristech.com/?p=105
It could also be related to the power connector from the power supply to the motherboard (unlikely).
Another good option would be to buy a used GX270 from eBay and put your hard drive into it.
When put power cable in orange light comes on power button and wont boot up
Sir,
Orange light usually comes only if your system stays in low power mode or sleeps, So u get orange light immediately when u switch on the system, try pressing the ESC Key on the top left corner of the Keyboard, and if not try pressing the power button again...
If not working,tell me Whether do u get any sounds in system?
Your system Operationg System?
And What u get on the screen, when u switch on?
Thanks, Regards
Vinod
1helpful
2answers
Dell GX270 won't boot up with solid amber light on Power button
Check motherboard for bad capacitors. I had the same problem and when i had bad capacitors replaced everything is ok.
2helpful
2answers
A solid orange light, usually indicates an internal power problem but just in case try reseating the memory. Also its become a habit on a GX270 to check the capacitors to make sure they aren't bulging.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
