Question about ASUS P5S800-VM Motherboard
ASUS P5S800-VM Microphone input dead
I'm not sure it's ever worked. The "EZ-Connection" senses a mic when one is plugged in, but on the audio input mixer panel I am unable to select any input and the "Advance" button is inoperable.
Running XP Pro 2002, service pack 1
CPU: Celeron(R)
Audio controller SiS 7012
RealTek AC-97 Driver Codec ALC655
I'm a dolt and am afraid I'll screw up my audio outputs which work fine.
Can you help?
  • gatorg Aug 20, 2008
    Reloading the Realtek driver solved the input selection check box / advance button problem. In addition, two consecutive LogiTech headset microphones were defective.
    A-OK now!
Posted on Aug 10, 2008
Drivers motherrboard asus p5s800vm audio
Here's the link u can download Audio driver for your motherboard-
just enter your OS and go to Audio category-
rate me too
Apr 23, 2011 | ASUS P5S800-VM Motherboard
Go to the following website to get the driver you need for your ASUS P5S800-VM Motherboard.
Jan 21, 2011 | ASUS P5S800-VM Motherboard
Bios asus P5S800VM,rom
Try Updating your System Bios from
Version 1023
Update Procedure:-
1. Copy the ROM file in a pen drive
2.connect the Pen drive to the usb port of your Motherboard
3. Restart your m/c and press Del Key and Enter Setup
4. Go to
ASUS EZ Flash and update the Bios.
Jun 06, 2010 | ASUS P5S800-VM Motherboard
How to connect audio from motherboard p5s800
It is Asus P5S800-VM motherboard. Download the manual from Asus, click the link provided;
You'll need to download and install Adobe reader to view the manual;
Turn to page 1-29. Section 11. Front panel audio connector (10-1 pin FP_Audio1). Notice there are two jumpers. One across pins 9 and 10. Another across pins 5 and 6. Pin one is marked, AGND and pin two is marked MIC2. ECT.
This is default setting when using the rear audio jacks. You can not run rear audio and front audio at the same time. (So pick one or the other). To run front case audio remove the jumpers and connect the I/O cables to the FP_Audio1 pins. There is a work around. You can buy an adapter that will split the audio from the rear allowing you to connect secondary audio and mic ports. Open the link provided;
You can buy these locally. To connect the FP_Audio remove the jumpers and connect the I/O cable to FP_audio pins. Use Adobe reader and zoom in. You'll find each pin is marked.
Mar 08, 2010 | Computers & Internet
Mic not working on asus p5pe vm
mine is the same but you can use a soundcard
Sep 20, 2009 | ASUS P5PE-VM Motherboard
I have so fat
Here the Infos about your mainboard:
ASUS P5S800-VM Allgemein MPN: 90-MBL0K0-G0EAYZ, P5S800-VM
Produkttyp: Motherboard
Formfaktor: Mikro-ATX
Breite: 24.5 cm
Tiefe: 24.5 cm
Kompatible Prozessoren: Pentium 4, Celeron D
Prozessorsockel: LGA775 Socket
Chipsatz: SiS661FX / SiS964
Maximale Busgeschwindigkeit: 800 MHz
Storage Controller: ATA-133, Serial ATA-150 (RAID)
Prozessor Installierte Anz. (max. unterstützte Geräte): 0 ( 1 )
Speicher Unterstützte RAM-Technologie: DDR SDRAM
Installierter RAM (Max.): 0 MB / 2 GB (Max)
Unterstützte RAM-Geschwindigkeit: PC2100, PC2700, PC3200
Video Grafik-Controller: SiS Mirage
Videospeicher: Shared Video Memory (UMA)
Audio Audioausgang: Soundkarte
Signalprozessor: SiS964
Audio Codec: Realtek ALC655
Soundmodus: 5.1 Channel Surround
Kompatibilität: AC '97
Telekommunikation / netzwerk Netzwerk: Netzwerkkarte - Ethernet, Fast Ethernet
Besonderheiten BIOS-Funktionen: Wiederherstellung nach Stromausfall (Wiederaufnahme bei Verlust der Wechselspannung), DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash, Hyper-Threading-Technologie, RAID-Unterstützung, DMI 2.0-Unterstützung, WfM 2.0-Unterstützung, ASUS MyLogo2, SMBIOS 2.3-Unterstützung, ASUS EZ Flash
Sleep / Wake up: Wake-On-LAN (WOL), Wake on Ring (WOR)
Hardwarefeatures: ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2, Jack Retasking, ASUS Instant Music Lite, Chassis Intrusion Detection, ASUS Q-Fan, C.P.R. (CPU Parameter Recall), CrashFree BIOS 2
Produktbeschreibung des Herstellers Das P5S800-VM unterstützt die neuesten Intel Pentium 4 LGA775 Prozessoren. Mit 800Mhz FSB, 1MB L2 Cache, Hyper-Threading Technologie und Spitzenleistungen von 3.6GHz und mehr ist der LGA775 Pentium 4 einer der schnellsten Desktop Prozessoren, die es zur Zeit gibt.
Dec 31, 2008 | ASUS P5S800-VM Motherboard
P5S800-VM multimedia audio controller driver
Hi Mairaj, please click the link posted below. This is Asus download site for your board P5S800-VM. Suggest you bookmark this page in case you need another driver.
Creat a folder on your desktop & name it Audio.
Click the + sign next to Audio. If you are using Win XP home or Pro download,
Realtek ALC655 AC''97 Audio Driver V3.66 for Windows 98/ME/2000/XP(WHQL)/2003.
File size 24.17MB. Save file in the folder you created.
The file must be uncompressed before you can install it. If you do not have winzip please download this program for free from the link below. Install winzip into your PC.
Once the file has been uncompressed you can install the software.
If you have more questions feel free to ask.
Good Luck & have a Great Weekend!
Mar 21, 2008 | ASUS P5S800-VM Motherboard
HI can any body help me
Audio Driver Here :
Raid Driver Here :
Network Adapter :
Dec 28, 2007 | ASUS P5S800-VM Motherboard
Installing multi functionfront mounted panel
The manual is here: I don't see an internal Firewire connector, but you can buy a card for one.
Sep 29, 2007 | ASUS P5S800-VM Motherboard
ASUS P5S800-VM Motherboard Logo
197 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
