Hi.
Disconnect power, then move
the machine forward and check the drain hose at the back of the machine. Check if the hose is kinked or blocked and check that the hose height setting is as from manual. If the hose elbow is set at
incorrect height the water will be siphoned back inside the tub.
Access
the drain pump filter (this is located behind front-bottom access trim or door ). If there is blockage in there
the water will not be drain completely. Remove trim, unscrew the cap and be prepared to collect water. Ensure that power is off. Remove any blockage in there.
lean or replace the pressure
switch and the rubber hose connected to the pressure switch. This
device detects water level and stops drain when there is no more water.
If all that does not help, then the drain pump itself must be tested. In some rare case the main control module may be defective. Test all the rest first.
The problem is usually given by blockage, drain hose or by pressure switch.
Regards.
Ginko
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
