Question about Dryers
Kenmore Elite gas ddryer model 72062--No heat
I have a Kenmore Elite gas dryer model 72062. It stopped producing heat.
Still tumbles, etc.
Can you help me troubleshoot, or are there troubleshooting directions that you can direct me to?
  • 1 more comment
  • Ed53129 Aug 14, 2008
    I used your tip. Removed both ignitor and thermal fuse. Brought to Sears service center. They tested both components and found the thermal fuse to be the issue. Replaced it for $15-not bad!
    The service rep indicated that about 8-9 of 10 reports of non-heating dryers are caused by burned out thermal fuses. This is the place to start. I tried testing it with my ohm meter, but I think it is broke. So I had them test it. I also re-did vent, as the dryer was moved, folding the vent. A freer vent should prevent thermal fuse overheating.
    Thanks for the help!
  • Anonymous Mar 15, 2014
    "gas dryer no heat troubleshooting."
    HOW DO I GET TO IT
  • 869 Answers
Check the glow coil ,if its not glowing run a test for voltage when its heating ,should be around 117 volts.check thermal fuse.
Please Rate This !!!!
Posted on Aug 11, 2008
SOURCE:
I have a Kenmore Elite 110.74082201. It tumbles, but there is no heat. I cleaned the bottom filter and did get some heat briefly. I emptied out the dryer, replaced that load with wet towels. I turned it...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Kenmore Dryers
Kenmore elite model 11070092990 dryer tumbling but not heating unplugged and started again-still not drying
heatman101
Jun 13, 2011 | Kenmore Dryers
I have Kenmore gas dryer - no heat - I followed some of your advice to others and replaced the ignitor - still no heat - do I need to replace the thermostat as well? Any other advice?
Look for a blown duct fuse. Make corrections to the air flow and replace the fuse. A kenmore dryer has fuses that look like this: themobilian_18.jpgthemobilian_19.jpgthemobilian_20.jpgthemobilian_21.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 02, 2010 | Kenmore 72062 Gas Dryer
The Pilot light oa a Kenmore Gas Dryer went out .How can I re-light it?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 27, 2010 | Kenmore 72062 Gas Dryer
My Kenmore Elite Gas Dryer in Refresh mode the cloth comes out wet.
I think the refresh mode is a no heat tumble only setting... just to fluff your clothing...
if they were wet they will not dry on that setting...
heatman101
Aug 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
I have Kenmore dryer model 110.70052990. I runs normally for two minutes and then shuts off.
Those coils work one time and then they get heated and quit. They are cheap, replace em02cdf0c.jpgcc71e57.jpg
Aug 06, 2010 | Kenmore 72062 Gas Dryer
My Kenmore Elite dryer will not heat. It tumbles
REPLACE THE ELEMENTS, YOU CAN CHEC THEM WITH AN O METER TO SEE IF THEIR NORMALLY CLOSED AND NOT OPEN, BUT I WOULD THINK THIS IS THE PROBLEM IT USUALLY IS
Jul 10, 2010 | Kenmore Dryers
Kenmore Elite Dryer, start button doesn't stay on
when I press and hold the start button it tumbles but not sure if it heats up. When I let go of button machine stops
Aug 16, 2009 | Kenmore 62602 Electric Dryer
Hi, I have a Kenmore gas dryer that shows the symptoms above -no heat, but everything is operational-. I have replaced the thermal fuse, and both thermostats. It did work for a few minutes, but then it...
Really? You want me to pay you to tell me how to fix it, but you want me to TELL YOU how I fixed it for free? Some scam you're running. Please remove my e-mail address from your system.
Jun 11, 2009 | Kenmore 72062 Gas Dryer
Tumbles but no heat
Probably your heating element.
May 26, 2009 | Dryers
Dryers Logo
331 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
