Question about Zenith R49W36 49" Rear Projection HDTV
Zenith No power.
  • 2,071 Answers
First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Posted on Aug 10, 2008
I have a Z42PJ240 42 in. Zenith Plasma television I canno.v.t find anywhere to manually power on the t
hi the power button might be underneath the tv or a touch screen panel
regards
shaun
Apr 21, 2014 | LG Z42PJ240 42 in. Zenith Plasma TV
Zenith tv dosen't work
Power supply Board Call UED 1-800-648-6657 or try Encompass 1-800-638-3328
Dec 07, 2009 | Zenith E44W46LCD 44" Rear Projection...
I need to buy Powerboard for 26" LG LCD Television 26LX1D
There u go .!!
http://cgi.ebay.com/LG-Electronics%2FZenith-6871TPT303B-PCB---POWER-BOARD_W0QQitemZ390119483627QQcmdZViewItemQQimsxZ20091117?IMSfp=TL091117189007r1099
This product works with the following models:
LG Electronics/Zenith 26LX1D
LG Electronics/Zenith 26LX1D-U
LG Electronics/Zenith 32LP1D-UA
LG Electronics/Zenith 32LX1D
LG Electronics/Zenith 32LX1DUA
LG Electronics/Zenith 32LX3DCS-UA
LG Electronics/Zenith 32LX3DC-UA
LG Electronics/Zenith 32LX4DCS-UB
Nov 24, 2009 | LG 26LX1D 26 in. LCD HDTV
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
Need a power cord for a Zenith L20V26C 20.1 in. LCD Television
You can find a replacement power cord for this model from a major Zenith/LG parts distributor at the following link:
Zenith/LG L20V26C Replacement Part Power Cord
Please note the AC Adapter is no longer available from the manufacturer as you can see here.
Jan 29, 2009 | Zenith L20V26C 20.1 in. LCD Television
Old zenith 36"
Bad CRT (the picture tube) they fail on the many of the zenith sets.
Jul 26, 2008 | Zenith C27A24T 27" TV
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Programming remote
The BNZ110 is designed to be for Zenith by default. If it gets changed and won't work, then take the following steps.
1. Remove the batteries.
2. Hold the power button down for 10 seconds.
3. Reinstall the batteries.
This works for many Zenith TV's.
Here are the codes for Zenith if that does not work.
713 502 606 409 710 701 507 714 405 712 015 916 008 002 115 224 324 126 326 826 228 430 632 435 437 903 407 505
Oct 27, 2007 | Zenith DBZN-311 Remote Control
Zenith R49W36 49" Rear Projection HDTV Logo
89 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
