Question about Brother Office Equipment & Supplies
There's no option scan on card and we cannot scan the document to store it on a flash drive
  • 36 Answers
Scan file to hard drive then copy to Flash Drive
Posted on Aug 10, 2008
Can I recover deleted file?
You can recover deleted files from flash drive with a usb drive recovery software, you may refer to this tutorial
Recover Files from USB Drive
Feb 08, 2013 | Kingston DataTraveler 101 G2
What file format do i save a word doc to my sandisk 2 gb
The USB flash drive is capable of storing any type of file. Save it as a word document (.doc) or anything else. However, if you use the drive on a computer that does not have WORD on it, you may not be able to open it. There are other programs that can read WORD documents: Libre Office, Corel WordPerfect and many other documents viewers.
Aug 27, 2011 | SanDisk 2GB microSD Memory Card
My 2GB sandisk memory card has the data of 1.4GB in it, but it is not showing any single file. i scanned it with anti virus but anti virus is showing that no infections found. the scanning time takes only...
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
Mar 21, 2011 | SanDisk 2GB microSD Memory Card
I am having trouble scanning an image into a specific folder on a specific drive (f drive). Can you walk me through the steps (slowly please) that will allow me to save the scanned image directly into that...
Usually the images or documents requiring scanning or printing has to be displayed on a program like work productivity to allow for action buttons to be appears ready. For example, documents stored on hard drives are least printable or scan able directly from the medium where stored. Open the stored location is on the computer to display the document as pages before printer jobs are attainable.
Feb 02, 2011 | Dell A960 All-In-One InkJet Printer
I am trying to open a document on the flashdrive. I repeatedly get a message that the document can not open corrupt file
try right clicking on the doc and check the open with option for opening the doc
then put a right click -> properties and check the default application for the doc
Feb 19, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
My computer recognizes that I have 1.8 GB left on the disk but when I try to download songs it claims that the disk if full. What do I do?
Good day sir/maam, hi, your SD card may be infected by a virus that wont allow anymore software or files to be stored on the disk, run a virus scan on your PC, there is an easy way to check if your PC is infected, to check, on the my computer menu bar click tools, folder options, view, select show hidden files and folder, then apply, close the window, Now go back to the folder option, view and check the show hidden files, its changed. and goes back to not show hidden files. If this happens, download AVG anti virus and scan your computer.
Nov 17, 2009 | SanDisk 2GB microSD Memory Card
Storing documents on my sandisc cruzer 4.0GB flashdrive
Scan the pendrive for virus infection, that may be the possible cause.Or try formatting it once and then check again if you cannot fix it using a antivirus.
Jun 24, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
I bought a 2gb to store my photos it coplied
Found these two solutions online, that worked for others. Hope it helps:
BEFORE YOU DO EITHER OF THESE: Copy all the data on the microSD card to a reliable media.
==========Solution #1==============
First manually create a folder on the microSD drive. Move files/folders from the root into this folder.
Apparently you can only have a limited number of files in the root directory of this and similar solid state memory devices, including SD cards, USB Flash drives, etc.
==========Solution #2==============
Some suggest that if the drive is formatted with the NTFS file system that you should reformat the drive to the FAT32 file system. I would do this only if Solution #1 does not work or the problem reoccurs.
(1) Open Windows Explorer, right click the drive and select Format from the menu.
(2) In the Format dialog, select the drop down menu in 'File System' and select the FAT32 option.
(3) Click the [Start] button.
(4) Exit the format dialog once complete.
(5) Restore your documents
Jun 09, 2009 | PNY 2GB microSD Memory Card
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
46 people viewed this question
James Cagle
James Cagle
Jim Keysor
