Question about Eddie Bauer 22864MRC Booster Car Seat
Can't put back together
I just washed the car seat and I'm not sure how the 5 point harness goes back together. Got a front facing carseat the # on it is 02524AAR Made 01/26/2000
  • 2 more comments
  • Anonymous Aug 19, 2008
    i have a rear facing seat and like phyzzil38 i washed the upholstery and i can't rethread the straps through the shell.. I need urgent help
  • Anonymous Aug 28, 2008
    washed the cushion and now i cannot remember how to put the harness back in
  • Anonymous Sep 04, 2008
    washed and can't get back together
  • Amir Amin
    Amir Amin May 11, 2010
    its which munufacture
  • 48 Answers
Contact cosco as they are the manufacture, this attached link will give you a site that with the model number and manufacture date you can download the manual which will tell you how to put it back together
Posted on Aug 20, 2008
I am guessing the roadblock you found is when you are trying to insert the belt in the bottom part of the car seat, between the seat and the recliner assembly. The rest of the assembly process is prety obvious and is not discuss in this solution.
For this you will need something long (about a foot), thin and flexible. A ty-rap or cable tie is perfect. Well this is how I fixed it.
First, take out the plastic snap-in buttonholes from the seat, then slide in the ty-rap in the belt and pass it through one of the holes where you took out the snap-in buttonholes. Second, slide your other hand between the recliner assembly and the seal and catch the tip of the ty-rap. Then carefully, slide the other end of the ty-rap until you have both ends in your other hand. Pull the belt through the hole. Now put together the ty-rap all the way in to secure the belt in a loop and the slide the tip of the ty-rap through the other hole this time from the bottom (between the recliner assembly and the seat) until you catch it from the top. this last part is a little bit tricky because you are going to ha to giggle it a bit in orther to catch it but after a while you wll succeed.
If you have any problem just email me this way.
Posted on Feb 15, 2009
I just washed the car seat and i'm not sure how the 5 point goes back together.
Posted on Sep 26, 2008
2 Suggested Answers
my3angels
  • 125 Answers
SOURCE: can't put back together
Do you have a company name for this product? Graco, Cosco? If you do I can look up an online manual for you as there is most likely a diagram to make my description easier for you to visualize. At any rate you need to insert 2 of the straps (the ones with the pieces to snap into the buckle at the **** ) through the back side (aline your child with the slots to ensure correct placement. You want the belt to come out just above the shoulder) DId you take this completely apart to wash? If so you will need to slip on the chest buckle pieces as well. Hope this helps. I can help better if you are able to get back with the company name so I can get the manual for you. :)
Posted on Aug 19, 2008
PIERRE CARDIN BABY CARRIER
Hi
Due to the safety implications of the carseat harness being incorrectly fitted if the harness has been completely removed from the carseat shell it would need to be sent to engineers for them to re-fit the harness. What country are you in we can direct you to the appropriate customer care team to arrange this.
Feb 02, 2012 | Maxi-Cosi Cabrio Red Flame Reflection...
Footmuff instructions
Hi Beth - First open the footmuff, and set the carseat down on the floor in front of you so you're facing it. Take the harness pads and ****** pad off the harness straps and place the footmuff into the carseat. Pull the harness straps through the holes in the footmuff and press the back of the footmuff into the curve of the carseat. Replace the harness pads. You're ready to go! When you use the carseat, simply put baby in and do up the harness as usual, then do up the footmuff for cosy, safe travelling.
Nov 24, 2011 | Maxi-Cosi Baby Gear
Have removed cover from front facing car seat can't secure straps at back when put back on
The carseat harness should never be removed due to the safety implications of it being incorrectly re-fitted. Your carseat will need to be sent to the engineers for them to fit the harness correctly.
Feb 05, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
Need instructions to put harness in carseat back together
my mom has an eddie bauer carseat for my daughter and washed it how do you put it back together
May 24, 2009 | Eddie Bauer Baby Gear
Harness straps off cosco car seat to wash cover, help reattaching
I need help putting the straps back on a Cosco 5-point car seat. Took it apart to wash and can't get it back together
Mar 08, 2009 | Century Encore 5-point Harness
Put harness belt back on baby car seat
22880-mtta is an Eddie Bauer carseat. Go to http://www.eddiebauer.djgusa.com/usa/eng/Instructions
Enter the model number 22880-MTTA, and date of manufacture.
Nov 11, 2008 | Baby Gear
Aug 16, 2008 | Baby Gear
Please look at this manual instructions to get a clear help. and dont forget your rating for me. Thanks.
http://www.coscojuvenile.com/instructions.asp
Aug 21, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Cosco 5-point omega carseat
ok I had such a hard time with this, i looked on the internet for hours and found NOTHING!! haha so i went to babies r us and checked out a similar one so here it is.
first the strap goes on the bottom, pull them even and the add the buckle, plastic buckle thing, and the other thing soft thing. then put the strap through the back of the seat (you should have two ends) not the must go OVER the adjusts! now take the metal piece that adjust the length and pull it long enough for it to reach the two straps and hook them up!! haha if this isnt good enough go to a store that carries the alpha omega elite car seats and check it out! GOOD LUCK!!
May 10, 2007 | Cosco Alpha Omega Elite 5-Point 22-155
Eddie Bauer 22864MRC Booster Car Seat Logo
708 people viewed this question
Top Eddie Bauer Baby Gear Experts
Jennifer Rock
Jennifer Rock
Nikki  Mclean
Nikki Mclean
woodzowl307
Are you an Eddie Bauer Baby Gear Expert? Answer questions, earn points and help others
