Question about Samsung DVD-V4600 DVD Player/VCR
Sound but not picture
On Friday we used our DVD player just fine. Today there is sound but no picture. Any suggestions?
  • 3 more comments
  • krut72 Oct 16, 2008
    DVD-4500 same problem. No it is not the cable. VCR works fine, DVD - only sound ! The other awkward thing is I can't get the main menu.
  • tbrogdon Nov 05, 2008
    I have exactly the same problem. Sound, no video, black screen. No forewarning. Kids sat on remote and some comment about progressive scanning pops up on tv screen just before screen goes black.
    Any thoughts? And yes, VCR side works fine - sound and picture.
  • tamcgill13 Nov 14, 2008
    same darn thing....sound, but black screen. I stopped watching, turned everything off, 20 min., then had screen again. Now, there's nothing but black screen and no amount of time will fix it. Hmmmmm.........
  • girvenhunt Dec 11, 2008
    no picture shows only sounds from dvd
  • Anonymous Jan 01, 2009
    Same problem no picture only sound on DVD and VCR works fine.......???
I have the same problem. I pushed the EZ View button to see what it would do and I lost all picture to the DVD but the VCR worked fine. I searched the WEB ALOT.... and there seems to be alot of this but no help! Well - GOOD NEWS- I have your rescue - if you haven't thrown the dang thing out yet. I went to the Samsung website and here is how to reset the V4600. Turn the unit on, then press the Fast Forward AND the Rewind buttons at the same time and hold down for 15 seconds. WHala... It's all back! Here's a link so others can view it. It gives the reset for all machines. They ARE different.
Good Luck!
Posted on Mar 15, 2009
Samsung has moved the instructions for resetting all of their DVD players to:
Thanks for this thread. It really bailed me out by getting my machine working again!
Posted on Oct 13, 2010
Woo hoo!! I ALMOST tossed my Polaroid VHS / DVD combo, for the same reason (been that way for 2 years!) but I still watch VHS with it. Then my portable DVD player died... I found this (#2 solution) & from there searched & found all that was needed was press I/P on the remote.(for the Polaroid).. DOH!!! THANKYOUTHANKYOU!
Posted on Apr 11, 2009
  • 1,148 Answers
Video jack could of went bad ,,or it comes and goes,, it happens,, hope to help
Posted on Oct 05, 2008
Sound okay on tv but no sound on bluray player
Make sure the audio inputs are on the same input as the video cable.
Dec 29, 2014 | Audio Players & Recorders
Sound no picture
Hi,i suggests there is a loose or broken connection on your video connections between the Koss KS3102 System dvd player and tv. Having sound suggests the optical pickup is fine. If you did not have sound then the Koss KS3102 System dvd player could have been broken. If checking the connections doesn't work, try a cleaning disk.
Take care.
Mar 25, 2011 | Koss KS3102 System
Memorex mvd2047 dvd player - no audio when playing dvd
Regarding the problem with the sound on your DVD player, I would suggest you to make sure the audio cables (red and white) are connected properly to the TV and player.
Also, try using a different set of cables since those ones might not be working and this is why you are not getting audio. On the Memorex remote you will find a mute button, make sure it is not activated.
Jul 23, 2010 | Memorex MVD2047 DVD Player
Hitachi l42vpo1u no sound through hdmi
HDMI port damaged, mainboard need to be replaced.
But be absolute sure your HDMI port is not working properly, I recommed you try it again with another HDMI cable, you can also try same cable in another TV.
May 18, 2009 | Televison & Video
No sound
Is your set plugged into a tv via scart sockets if so check the connections movement often unseats them and turns off sound and picture etc : If they are ok check that the sound is turned on in the menu and on the menu of the television set , low battries in a remote sometimes give the wrong signals and it causes many problems like this as it changes settings without you knowing crazy but true , when I was a field engineer I used to travel round an reset scores of sets Tv,s Video,s and other Infra red remote equipment with the same fault all because of low battries . If this dosen't work sorry to say a local service engineer to check out the set may be your best course of action .. Regards Vortash
May 06, 2009 | Cyberhome CH-DVD 300 DVD Player
Panasonic TX32LMD70: split and green picture from DVD
Cut feed lead to pin 16 (in the scart not the equipmend!)
Does not matter which end. It just stops the TV from switching to RGB- The DVD is sending non standard RGB - PanamanNE
Jul 04, 2008 | Televison & Video
No sound from anything but FM
Disconnect whatever's connected to the blue wire behind the unit, and re-connect it to the blue/white wire instead.
Aug 05, 2007 | Kenwood KVT-617DVD Car DVD Player
Feedback from spekers
suggest,checking pwr point earth,power leads, try a different antenna,unplug any external connections not needed to recieve broardcast,shift position of tv by 3 mtrs. Regards Chook.
Apr 01, 2007 | LG DVD 5253 DVD Player
Dvd/vcr combo,vcr is fine ,but dvd no picture,or sound,disc reads.
Hi There is an I/P button on your player's remote control. Power your player on then press the I/P button on your remote control.
Aug 16, 2006 | Apex Digital ADV3800 DVD Player/VCR
No picture while playing DVD or VHS tape
Your unit has it seems to have developed a video problem. it could be in the video switching IC or the video processor. Its going to need a trained technician, who knows how to use an ocilliscope to find the video problem.. Good Luck
Aug 02, 2006 | Insignia IS-DVD1001 DVD Recorder/VCR
Samsung DVD-V4600 DVD Player/VCR Logo
265 people viewed this question
Jerry Greenberg
Jerry Greenberg
