Question about Hyundai L90D+ 19" LCD Monitor
Appearance on monitor is reddish in appearance
Moved monitor and must have touched some buttons; no appearance is reddish in color; have tried adjusting via monitor settings but to no avail; need factory settings for monitor
Depending on your monitor settings, you should putt all 3 colors on either 0 or 50. whichever is in the middle of the spectrum in your settings. However, when I've seen this problem on monitors, it's been a problem with the cable. Sometimes the cable is tilted, meaning some of the pins aren't connecting. In other cases, missing or bent pins can cause this too. So try to check out both ends of the video cable and adjust it accordingly.
Posted on Jan 11, 2009
Pvm 2530 turns reddish color soon after turned on
This might be a CRT base card fault. Replace the CRT connecting socket at this card. The fault technically called as 'one color predominant screen'. If you wish to get some more details about this kind of fault to CRT TVs, check this link. Pull up older posts there. One among these posts have detail descriptions.
Mar 14, 2013 | Televison & Video
ELMO Visual Presenter (Model EV-2000AF) does NOT display COLOR properly onto HDTV monitor. (Appears Bluish or Reddish w/ 2 Composite Cables connected)
Those jacks you are plugging into on the HDTV are not composite inputs. They are component. The reason the color is not right is, you have to have a Red, Green and Blue connection.
The black and white picture from the 1 cable is because you are using a composite signal into a component green.
Big difference between a composite and a component signal. I hope this helps.
Apr 10, 2012 | Televison & Video
The screen is turning pink or reddish especially the menu and task bar, the desktop is also red in appearance.
It can be that it is nothing getting all the color signal from the PC, I would check all the pins at both ends of the cable first, or try it with another PC to narrow down the problem.
Please post back what you find, we do not want to open it up unless we have too, and if it is the monitor, the only way to fix it will be replacing the logic board (the board that the video cable is plugged into).
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Sep 24, 2010 | Acer 22" X223w LCD Monitor
Screen color has become reddish! how to fix it n
maybe your monitor is damage buy new one
Jun 20, 2010 | Computers & Internet
Sony KP-53HS30 Projection TV has pink and blue hue w/timer blink
Depending on your TV, you may have a Color Temperature (Color Temp) and/or Hue setting in the menu. Use these options to adjust the picture to the setting that best suits your viewing preference.
If your TV has a Color Temp setting, you will normally have the following options to select from:
  • Cool: Gives the picture a cooler, slightly bluish appearance.
  • Neutral: Gives the picture a neutral, more natural look and appearance.
  • Warm: Gives the picture a warmer, slightly reddish appearance.
If your TV has a Hue setting, follow the appropriate step below to make adjustments:
  1. Move the setting to the right to reduce the reddish appearance.
  2. Move the setting to the left to reduce the greenish appearance.
Aug 03, 2009 | Sony KP-53HS30 53" Rear Projection...
Reddish tint on the screen
LG 700e
power suply is dad
resistanc is black not show it ohom
plz help
Dec 21, 2008 | LG Studioworks 700S 17" CRT Monitor
MOnitor reddish color
Try a new cable; you may have bent or broken pins.
Jun 21, 2008 | SAMTRON 55V 15" CRT Monitor
Reddishness in the screen
Have you loaded the drivers which came with the monitor. This will probably allow you to change the settings.
Right click on an area of your desktop and choose properties. Look at the monitor and make sure the resolution is set to the recommended level possibily between 60 or 75 dependant on the model. Also you can get to the display card settings here and change them to suit. Dont get carried away or you can make it so that you cant see whats on the screen at all to be able to change it. Could also be that your monitor is faulty. Check with your manufacturer. It its an old telly type monitor maybe one of the "guns" have gone so you dont get the right colour mix of red green and blue. If this is the case you will need to get a new screen.
Oct 15, 2007 | LG Studioworks 563N 15" CRT Monitor
Pictures reddish or orange
Although normal room lights (tungsten lights) appear white to our eyes, their light is actually much "warmer" than daylight, giving a reddish or orange color to pictures. This happens with digital and film cameras. To prevent or lessen this reddish or orange color: If your digital camera has a selectable White Balance mode (check your camera's User's Guide) and you are not using the camera or external flash, set the White Balance mode for "Tungsten" light. If your pictures are reddish even when you use the camera flash or external flash, the room lighting is overpowering the flash. Try setting the White Balance mode for "Tungsten" and continue to use the flash. If your camera does not have a selectable White Balance mode, use the camera flash or external flash when taking pictures in lighting that makes your pictures turn out reddish or orange. If you can, turn down or turn off one of the room lights (without making the room too dark), or move your subject so that it is not being hit directly by the room lights. If you can, when taking pictures in the daytime, try opening any drapes that might be covering windows. Letting in natural daylight improves the color quality of the lighting.
Aug 29, 2005 | Kodak EasyShare One Digital Camera
Open Questions:
Hyundai L90D+ 19" LCD Monitor Logo
85 people viewed this question
Top Hyundai Computers & Internet Experts
rhodesworks
Randy Schumann
Randy Schumann
Are you a Hyundai Computer and Internet Expert? Answer questions, earn points and help others
