Windows Media Player is not visible when opened. I don't know how this happened or how to fix it. I use Windows XP Home and have Media Player 11. After I discovered the problem, I downloaded version 11, thinking that might fix it, but it didnt!! Any suggestions?
  • Kate8 Aug 10, 2008
    Thank you for trying. However, Windows Media Player was not running in the background. I have rebooted more than once since installing Media Player 11. This problem happened after several unsuccessful attempts to view some streaming live video of a conference. One other thing: My computer is a laptop and uses NVideo. I may have altered a setting on NVideo that is causing the problem.
  • Kate8 Aug 13, 2008
    thanks to those of you who considered my problem. I decided to use system restore, and problem resolved.
    Kate
    Novelist:
  • 171 Answers
There is a possibility that its running on the background, try to end the process of the program under task manager(Press Crtl+Alt+Del) the go to Processes, look for mmpnscfg.exe, highlight and then click End Process button. Then restart the computer and try again to open Windows Media Player.
Hope this will solve your problem with the media player not opening..
Regards
Posted on Aug 10, 2008
Windows media player won't work
Which operating system ? Which version of Media player ?
Though designed with Windows 7 in mind, Windows Media Player 11 (WMP 11) is fully compatible with Windows XP.
The trick is knowing which version of WMP 11 to download.
Different versions of the software exist not only for Windows 7, Vista, and XP, but also for both 32-bit and 64-bit Windows XP.
Additionally, WMP 11 is only compatible with XP if it is using Service Pack 2 or Service Pack 3. Before downloading the appropriate installation file, you will need to verify which version your system requires.
Open the "Start" menu.
Open "My Computer."
Click "Help", then select "About Windows."
This will display a window with system information.
Find the listing that specifies your Service Pack. If you are operating without Service Pack 2 or 3, you will need to install one (see Resources).
Open the "Start" menu and click "Run." Within the text field, type "winmsd.exe."
Click "OK." Select "System Summary."
Find the heading labeled "Item."
Under this heading should be the word "Processor."
The value associated with "Processor" will determine which version of Windows XP you are running.
If the value begins with "x86," you are running a 32-bit version.
If it begins with "ia64" or "AMD64," then you are running a 64-bit version.
Download the Windows Media Player installation file that matches your version of Windows (see Below).
http://windows.microsoft.com/en-US/windows/downloads/windows-media-player
Open the file once it has finished downloading.
This will launch the installation wizard.
Follow the onscreen instructions to install WMP 11.
The program should now run normally.
How to Fix Windows Media Center
Windows Media Center is the home entertainment hub on a Windows computer.
With Media Center, you can play live television, songs, DVDs and slideshows.
It is preinstalled on Windows XP Media Center Edition, Windows Vista Home Premium/Ultimate Edition and Windows 7 Home Premium, Professional, Enterprise and Ultimate editions.
From time to time, users run into issues trying to play audio or video files, or with an extender connected to Media Center.
Extenders are devices that allow you to "extend" the Media Center onto a TV screen or larger display.
The Xbox 360 gaming console is an example of an extender.
Launch Windows Media Center from your computer's Start menu.
Scroll down to "Music" on the Media Center home screen.
Select "Music library."
If you find an empty folder under "Music Library," navigate to the folder on your hard drive that stores your music file and add it to Media Center's library.
If the problem isn't an empty folder, look at the file extension on the music file that won't play. Media Center can't play files with unknown or incompatible extensions.
If you find a questionable extension, skip that file. Click once on another file with a different extension, one you know is compatible with Media Center, and then click "Open" to test if you can play that one.
Media Center will play MP3, CDA, WAV and other music file formats.
Open Windows Media Player from the Start menu if you receive a codec error while trying to play either audio or video files.
If you open the file in Media Player, the codec will download automatically.
You should then be able to play the file in Media Center.
Troubleshoot your firewall settings if a Media Center extender doesn't work.
You'll have a problem using an extender if Windows Firewall blocks it.
Go to "Control Panel" from the Start menu and double-click on "Windows Firewall."
Click on "Allow a program or feature through Windows Firewall."
Click to check "Media Center Extenders."
Click on "Apply."
Check external speaker cables to make sure they're connected if you can't hear any sound. Check the computer's volume settings by clicking on the "VOL+" icon at the bottom right corner of the main Media Center screen to make sure the volume is not turned off or down too low.
You may need to reconfigure your speakers if you're having volume or sound issues.
Scroll down to "Tasks" in the Media Center home screen and select "Settings."
Click on "General" and select "Windows Media Center Setup."
Click on "Set Up Your Speakers."
Follow the on-screen prompts to reconfigure your speakers.
Dec 01, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
No problem, just don't have the software, I GUESS, on my computer to download my own music from my own cd's to it..numbers on the bk are B109118MTK-8GB whatever that means
Hi lfeichtner...
Downloading Music to your MP3 Player
1...You must download and install Windows Media Player 11 on your computer.
NOTE...Some older MP3 players will not work with Windows Media Player 11 or Windows 7 with Windows Media Player 11.
If this happens to you, then you will have to uninstall Windows Media Player 11 and install Windows Media Player 10.
2...After you have downloaded and installed Media Player on your computer.
3...Open Media Player on your computer.
4...Install all your music into Media Player that you want to install on your MP3 player.
5...Plug in your MP3 player to the computer using your Data/Sync cord, be sure that Windows Media Player is on.
6...Media player should recognize the MP3 player and sync with it.
7...After it is sync'ed with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Please take time to rate me thumbs up.
Sep 13, 2011 | SanDisk Sansa m240 MP3 Player
I don't know how to put more music on to my nextar, what do i do?
Hi georgelopezi...
Downloading Music to MP3 Player
Aug 05, 2011 | Nextar MA797 MP3 Player
I don't no how to download music videos to my mp4
Hi
Free Answer...Please take time to rate me
Jul 31, 2011 | Audio Players & Recorders
What do we use to download music to my MP3 player? Itunes, bearshare, what do we use?
Hi
camry cotton
This is the way I know...there may be more, but I don't know them.
Jul 01, 2011 | Philips GoGear ViBE Digital Media Player
I recently found a black iRiver H10 but don't know how to sync music. I bough an USB cord for it but now what?
Hi maria lopez0...
Jun 27, 2011 | iRiver H10 MP3 Player
I do not know how to add music to my mp3 player.
Hi crystal 1299...
5...Plug in your MP3 player to the computer using your data cord, besure Windows Media Player is on.
6...Windows Media Player should recognize the MP3 player and sync with it.
7...After it is synced with the computer,you can add the music you have installed into Windows Media Player to your MP3 Player.
Jun 01, 2011 | Sylvania Audio Players & Recorders
Error when I try to use Windows Media Player 10 or 11
This error is generally the result of a corrupt or missing Custsat.dll file, usually located in the C:Program FilesWindows Media Player folder.To workaround this problem:
1. Remove the current Windows Media Player 10 install.
2. Download and install
Windows Media Player 11 for Windows Vista
or
wm_tn_wmp11xp.jpgDownload Player 11 for Windows XP
I tend to use VLC Player, as it plays everything I throw at it..
Hope this helps
Chris (ziraffa)
Jan 05, 2009 | Microsoft Windows Media Player
WINDOWS MEDIA PLAYER NOT RESPONDING..
Windows Media Player in this case has a script error that causes it not to respond on any OS platform that has yet to be fixed by updates. I have currently updated it to its fullest and it refuses to respond properly on windows xp, let alone beta versions of windows like windows 7. My suggestion is forget windows media player 11 and go download VLC player which plays more things off the bat anyways. Its free and easy and small. There is also any number of other media players like Realplayer, Quicktime, or Windows Media Player Classic.
Sep 15, 2007 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
