Question about Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140
Keyless chuck how do you remove and replace chuck from a bdf452hw 18v cordless drill?
    Problem Solver:
  • 18 Answers
You will find a screw inside the chuck that needs to come out first of all but beware that it will be a reverse thread. This is to stop it loosening whilst in use. then you will need to unscrew the chuck but it isn't easy as you have to hold the shaft that the chuck is attatched to. You can sometimes take the chuck off by holding it and pulling the trigger while in reverse. (but they can be stuck fast).
Posted on Sep 19, 2008
SOURCE:
How do you put the black chuck cover back on
It sounds as thought you have a keyless chuck on your drill. The cover is not meant to come off. You will have to replace the chuck.
Apr 18, 2014 | Makita 18V LXT Lithium Ion Cordless 3/8...
Chuck/shaft wobble
check the bearings for the chuck shaft as they may be worn out
Aug 03, 2013 | Makita BDF452HW 18V Cordless Lxt Lithium...
How to change bits
The drill uses a cordless chuck (part bits go into) you will need to hold the outside ring of the chuck and spin it to loosen the jaws on the bit. Then spin the chuck the opposite way to tighten
Sep 26, 2012 | Makita BDF452HW Factory Reconditioned 18V...
Ryobi 12 volt drill/driver- cannot unlock the keyless chuck
replace the part you have taken out .
get a pair of stilson spanner adjust it so it goes around the chuck and do it and then it will ease off to do it up by hand
Sep 21, 2017 | Skil 2887 - 06 Factory - Reconditioned 18V...
How to remove a keyless chuck from bdf452
If the head of the screw is stripped out to much for a driver to grip and remove it you have two options.
1. Use another drill to drill in the center of the screw with a bit just big enough to remove the head. With the head of the screw off, the chuck can be removed from the spindle. There should be enough of the screw remainin in the spindle that you can grip it with vice grips and remove it.
2. Using a metal cutting wheel on a grinder, you have to cut the end of the chuck off, aiming to cut just under the head of the set screw so you don't damage the spindle. After cutting, let things cool off before trying to remove the rest of the chuck and screw from the spindle.
Aug 11, 2012 | Makita BDF452HW Factory Reconditioned 18V...
Ryobi 18v drill keyless chuck stuck
Try holding the bit in a vice and gently tap the chuck off of the bit and see it it releases the pressure on the jaws.
Jun 20, 2012 | Ryobi 18v Cordless Drill - P206 18 Volt V
I have a Black & Decker 18V cordless drill with keyless chuck. The spot where the drill bit fits is in the open position stuck and won't turn in either position. What am I missing how to unlock it?
Look at the three jaws in the chuck,if on is further out than the others the you need to tap ti back into place with a small punch and a hammer.If this does not work then you need to replace the chuck,remove the screw at the bottom of the chuck[where you put the bit],then you will need to to clamp vise grip on the chuck and with it pointed away from you hit the vise grips with a hammer with a sharp blow downward and it should come off.Hope this helps.
Jun 12, 2010 | Black & Decker CD9602SB 9.6 Volt Cordless...
The motor spins but the bit does not ??
You have the chuck problem and need repairing or replacement.
Regards, Jay
May 18, 2010 | Makita BDF452HW 18V Cordless Lxt Lithium...
How to remove chuck on makita bdf452
the chuck should open all the way then look down the old one attached to the drill there should be a screw near the end undo the screw and then it should come off :)
Mar 23, 2010 | Makita BDF452HW Factory Reconditioned 18V...
Keyless chuck question
this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
i prefer metal sleeve.
Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
Makita 18V LXT Lithium - Ion Cordless Impact Driver Kit Model BTD140 Logo
392 people viewed this question
Top Makita Drills Experts
John Trevino
Marvin
Marvin
Spud Howell
Are you a Makita Drill Expert? Answer questions, earn points and help others
