Question about Kodak EASYSHARE 5300 All-In-One InkJet Printer
AIO Home Centre
When I click on the Icon (aio) It does nothing. This is our second machine the first one would give me an Error message, this one does not. Since I i have installed this software I now have a problem with .net frame work will not upgrade for windows.
  • casper040558 Aug 12, 2008
    windows xp home
  • Matt D May 11, 2010
    Are you using Vista or Windows XP?
  • 40 Answers
Try to do the following:
Go to www.kodak.com/go/clear ; download the utility and run it.
After that, go to www.kodak.com/go/downloads and download the Software with drivers. If it still giving you trouble, call Kodak AIO tech support.
Posted on Aug 19, 2008
SOURCE:
100-2070 home center
Right click on the KODAK AiO icon - select properties. Click on the compatibility tab and check "run this program in compatibility mode for:" and select your operating system. Then check the box for "run this program as an administrator". Click apply and run your KODAK AiO Home Center program. No more 2070 error.
Jan 26, 2012 | Kodak Office Equipment & Supplies
Error 1203.consult user guide .write on my printer screen.and i nothing can to do.thanks for help
Overview
The 1203 error message is caused by either a communication failure between one of the printheads (cartridges) and the All-In-One (AIO), or by a short in one of the printheads. The procedures below will help you to resolve this issue.
Troubleshooting a Communication Error between the Cartridge and the Printer
NOTE: The embedded links in the table lead to specific troubleshooting documents.
Step Action
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Print a test page. If the test page prints, the error is resolved.
2 Open the top cover of the AIO and remove both cartridges from the AIO.
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark.
No: Continue to Step 4
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the color cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat step 4. If you have already tried cleaning the contacts, continue to Defective Cartridge Test.
No: Continue to step 5.
5
Power off the AIO and remove the power supply from the back of the unit. Reinsert the power supply, and power the AIO on. Open the top cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
1 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
2 Remove the cartridges. Clean the cartridge contacts and the AIO carrier contacts .check the link for cleaning http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:590:0:0&framed=&docid=ENUS24064&relevance=0
Defective Cartridge Check
To test the cartridge, replace it with either a new cartridge or a known good cartridge from another printer of this type. If the error message persists, proceed to Contacting Lexmark.
Please rate my response!!
Jan 28, 2010 | Lexmark P4350 All-In-One InkJet Printer
Kodak 5300 all in one printer will not scan. Cannot get on line with 5300 a10 home center program, tells me printer is not connected
try to unplug replug the usb cable of the printer.
You may also go to control panel printer and faxes and look for the printer of your 5300 now if you see 2 icons delete them both then exit to printer and faxes. and unplug/replug your USB cable then restart computer.
If this issue not solve try to uninstall the software and download the clearutility kodak.com/go/clear. then after doing this restart computer.
Nov 07, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a kodak esp9 on win xp wireless connection. Constantly get the 1-2010 error code and kodak aio home center will not open and the printer will not connect any solutions?
  1. From your computer, access Device Manager.
    • For WINDOWS XP OS:
    • Right-click My Computer, then select Properties.
      • Select the Hardware tab, then Device Manager.
  2. Select View > Show hidden devices.
  3. Select Printers.
  4. Select Action > Uninstall.
  5. Select Action > Scan for hardware changes.
  6. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
  7. Set administrator rights for the Home Center application:
        • Right-click on the Home Center icon.
        • Click Properties.
        • Click the Compatibility tab.
        • Clear all the check boxes.
        • Click Apply and OK.
    1. Double-click the KODAK AiO Home Center icon. If the error occurs again, go to the next step.
      IMPORTANT: In the next step, before you install the Home Center Software, make sure you disconnect the USB cable. Then, connect the USB cable when the software installation instructions tell you to do so.
    2. Upgrade the software and firmware for your printer:
Jul 17, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 1- 2036
I fixed my error code 1-2036 by going to the "Configure Settings" in the AiO Home Center then selected AiO Printer changed to "Print Quality" to Draft and clicked OK.... Then I was able to Scan with no errors. I think the config settings were corrupted some how and this resaved them properly.
if that doesnt help
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
if both the solutions doesnt help... its time to call kodak
Jul 10, 2009 | Office Equipment & Supplies
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
I have a Lexmark P4350, I put a new 33 color ink cartidge in and it does not reconize it and has an Error 1102
The 1102 error message is caused by a communication failure between one of the printheads (cartridges) and the All-In-One (AIO).
The procedures in this article will help you to resolve this issue.
Please follow the steps given below:
Power off the AIO and remove the power supply from the back of the unit. Wait 30 seconds, then reinsert the power supply and power the AIO back on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
3 Remove both cartridges from the AIO. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: There is a hardware problem with the printer. Continue to Contacting Lexmark below.
No: Continue to Step 4.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
5 Insert the color cartridge. Close the top cover, reinsert the power supply, and power on the AIO.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 4 and 5. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
No: Continue to step 6.
6 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, gently move the cartridge carrier to the middle of the unit.
7 Insert the black/photo cartridge. Close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Cleaning the Cartridge Contacts, then repeat steps 6 and 7. If you have already tried cleaning the contacts, skip to Defective Cartridge Test.
Step Action
2 Remove the cartridges and clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
(click here for instructions).
Apr 03, 2009 | Office Equipment & Supplies
Error 2200 lexmark 6250.
hey ,
Follow the steps :-
Step Action
1 Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved...
Nov 15, 2008 | Lexmark X7170 All-In-One InkJet Printer
Replaced colour cartridge and got error 1203
Power off the All-In-One (AIO) and remove the power supply fromthe back of the unit. Wait 30 seconds, then reinsert thepower supply and power the AIO on.
Yes:Continue to Step 2.
No: Print a test page. If the test page prints, the error is resolved.2 Open the top cover of the AIO and remove bothcartridges from the AIO. 3
Power off the AIO and remove the power supply from the back of theunit. Wait 30 seconds, then reinsert the power supply andpower the AIO on.
Yes:There is a hardware problem with the printer. Continue to ContactingLexmark below.
No: Continue to Step 4.4
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the color cartridge. Close thetop cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 4. If you have already tried cleaning the contacts,continue to Checking the Cartridge.
No:Continue to Step 5.5
Power off the AIO and remove the power supply from the back of theunit. Reinsert the power supply and power the AIO on. Open thetop cover of the AIO and insert the black/photo cartridge. Close the top cover.
Yes:Continue to Cleaning the Cartridge Contacts, thenrepeat Step 5. If you have already tried cleaning the contacts,skip to Checking the Cartridge.
No:Print a test page. If the test page prints, the error isresolved.
Nov 12, 2008 | Lexmark X5470 All-In-One InkJet Printer
Printer Error
Step Action
5
2 Remove the cartridges. Clean the cartridge contacts (click here for instructions) and the AIO carrier contacts
Mar 04, 2008 | Lexmark P4350 All-In-One InkJet Printer
Kodak EASYSHARE 5300 All-In-One InkJet Printer Logo
112 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
