Question about Hitachi 42EDT41 42 in. HD-Ready Plasma Television
Black Line Down Center of Screen
I have a black line down the center of my screen that comes and goes mostly just stays on screen.
    Master:
  • 623 Answers
Dry solder joints on the pins of the vertical integrated circuit may have caused this problem Tap each I/C lightly with a plastic screwdriver handle to find the intermittent one. It is the one with a heat sink attached.
Posted on Aug 10, 2008
Theres a black stripe down the center of the screen, it comes and goes, does anyone know what may cause this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations.
Aug 06, 2014 | LG Televison & Video
Have LG 42 inch plasma, 1 inch black line down center of screen, picture good other than black line blocking center of screen, comes and goes sometimes
Sounds like the middle scalar board is defective. Since the issue comes and goes it could just be a loose connection to the between the scalar board and the PDP Module (plasma panel).
Great caution needs to be taken when checking this connection because it is a ribbon cable connection it and needs to be put in correctly aligned or it could cause a short in one of the circuit boards.
Oct 07, 2009 | LG 42LC2D 42 in. LCD HDTV
Black line in centr of Screen
sounds like a bad panel, try reseating any cables you can on the buffers . the buffers would be on the lower edge right where the black line appears. unfortunately Vizio does not supply panels.
E
Jul 28, 2009 | Televison & Video
Red static in black background ~ thin line running down center
Robjrpena,
Did you find a solution to your "red dot" problem? I'm having the same issue :(
Thanks John
Jun 17, 2009 | Hitachi 50HDA39 50 in. Plasma HDTV
Black Lines
My Hitachi TV Flat screen 42 EDT 4 1A has a one inch black line from the top to the bottom of the
screen on the left side. What or how do I fix it. I did blow it out with a air compressor as suggested by a local repairman.
Nov 09, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Black band running from top to bottom of screen
this will need to go into the shop to get one of the video processing boards replaced that controls that part of the screen , this will happen when it gets to hot inside the set ,( thermal break down)
electech
Oct 31, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Black line down the center of the tv wont go away
Sorry, justindorval;
I did not complete my questions.
4. Does line move when the channels are changed?
Good luck, big IRISH. ps let me know, I'll more happy to help you.
Jul 19, 2008 | Televison & Video
Vertical Black bar on the screen
What is the model number it sounds like pixel problems or board problems. For more info ctechnicians.com
Jan 06, 2008 | Televison & Video
Black line down the center of screen
Usually this means pixel, but I would question if the line is mostly near right side or left side of screen? If more to one side this could be a bad board inside. for more info ctechnicians.com
Dec 31, 2007 | Hitachi CMP4201U 42 in. HD-Ready Plasma...
Black line in center of screen
These black lines on the plasma screens are very fixable.  There is a dry solder joint on a circuit board at the bottom of the plasma that needs resoldered.  There are 6 or 7 "ribbons" along the bottom of the screen that correspond to vertical sections of the display, so you just follow the black vertical line down to figure out which one is faulty.  I just performed this fix successfully on my first attempt on a Gateway plasma, but it will work on most plasma's, specifically Hitachi, gateway, LG, Hyundai, & Akai. I think they may all have LG boards, my gateway did.
I can't really describe very well what to do, but I assure you it is fixable.  If anyone is near nashville, I might be able to help you out.  My email is tomp2000@juno.com.
thanks,
ST
Jan 18, 2007 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
Hitachi 42EDT41 42 in. HD-Ready Plasma Television Logo
647 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
