CANNOT GET HARD DRIVE TO WORK ON LABTOP IT WANT EVEN REGISTER ON MY COMPUTER THE NAME OF THE HARDDRIVE IS IOMEGA 320GB
  • 36 Answers
You need to make sure the device is compatiable with your laptop.
Posted on Aug 10, 2008
Trying to find the operators manual for prestige desktop hard drive super speed usb 3.0 ,2 tb
The general directions is to plug the USB cable from the IOmega Prestige into any available (Open) USB port.
To open, (Access) the contents on the harddrive, double-click on the drive letter that corresponds with the IOmega.
In WinXP left-click on Start, then on My Computer.
In Win Vista and Win7 left-click on the Windows logo button, then on Computer.
You will see there are different drive letters;
Drive A: is reserved for a Floppy Drive. Older computers
Drive C: is for the Harddrive. (Hard Disk)
Drive D: is reserved for a recovery drive, or an optical drive (CD/DVD drive)
Drive E: is reserved for an optical drive, usually.
Drive letters beyond these are usually under the heading, Devices with Removable Storage
One of these drive letters should correspond with the IOmega.
Suggest, IOmega not plugged in, go to My Computer, or Computer, and look at the devices connected to the various drive letters.
Now plug the IOmega in, and see if it shows up next to a drive letter.
(Give the computer BIOS a few seconds)
Where there was NO device shown BEFORE, there should now be a device shown.
{No device shown before, but now there is. May not state IOmega, just external storage, or similar}
DOUBLE-click on the device shown.
For example:
I have drive letters C: D: E: F: G: H: I: J: and K:
Drive letter C: is for my harddrive.
Drive letter D: is for a recovery drive. (Partition in harddrive reserved for recovery)
Drive letter E: is for an optical drive (CD/DVD drive)
Drive letters F through K are reserved for an external storage device.
Whether it be an external harddrive, or flashdrive, or what have you.
IF you find the drive letter that corresponds with the IOmega DOUBLE-click right on it.
If nothing happens, or if there is no device shown when the IOmega is plugged in, there is a problem with the IOmega.
Hard to believe IOmega is still having problems with their external harddrives.
In the past they were having problems with a small circuit board located inside the IOmega's case.
[ A circuit board is a PCB.
Printed Circuit Board
For example a computer mouse has a small PCB in it,
http://en.wikipedia.org/wiki/File:Mouse_printed_circuit_board_both_sides_IMG_0959a.JPG ]
The small circuit board is an Interface Board.
It connects the harddrive inside the IOmega's plastic case, to a USB cable, and this allows the harddrive inside to be plugged into a USB port on a computer.
As mentioned inside the plastic outer case (External enclosure) of the IOmega is a harddrive.
(Hard Disk drive; proper speak)
Harddrives are measure across their Width. There are two current types used;
A laptop size harddrive, and a desktop size harddrive.
A Laptop size harddrive is 2.5 inches across in width. (2 and a half inches, or 6.4cm)
A Desktop size harddrive is 3.5 inches across in width. (Or 8.9cm)
There are two technologies used;
IDE (PATA) or SATA
I'm sure the harddrive inside susanbrenton is a SATA unit.
I BELIEVE, it is a laptop size harddrive (2.5)
Point?
If there is data (Information) on the IOmega that you must have, you may wish to buy an inexpensive external enclosure, remove the harddrive from the IOmega, and install it into the external enclosure.
The external enclosure has a plastic case (Enclosure), and a small circuit board inside. It has a USB cable, or connector, just like the IOmega does.
Once you install the IOmega harddrive inside the case, the case is closed, and it's USB cable is plugged into a computer.
(Just like the IOmega. You are just replacing the small circuit board essentially)
Once you have the IOmega's case open, and can view the internal harddrive, measure the width of the harddrive.
Buy the appropriate external enclosure.
This is one example of an external enclosure for a 2.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of a external enclosure for a 3.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Basic instructions on how to open an IOmega Prestige external enclosure (Case):
1) There are two Philips head screws on the Back of the case.
These are removed.
Once removed a the oblong panel on the end comes off.
2) You can now see the harddrive inside. Pull from the Front, and remove the harddrive out of the case.
3) The harddrive is attached with screws to a metal carrier. (Bracket, essentially)
Remove the screws, remove the harddrive.
Basic example, the harddrive will look like this,
http://www.geeks.com/details.asp?invtid=0A26923-NDW-R&cat=HDD
For additional questions please post in a Comment, (Believe upper right of your page)
Regards,
joecoolvette
Oct 15, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
How do i wipe my iomega prestige 320gb hard drive
plug it into the computer when the drive shows up in my computer assuming your using windows right click on it and select format keep the default settings and hit ok to the format
May 11, 2011 | Iomega eGo Portable 320GB Helium 320 GB...
My mini max 500gb has just stopped working. i cannot hear the fan at all and all my other daisy chained mini max hard drives still work and register on my desktop
Your Imega external enclosure has malfunctioned. If you can, you need to take the enclosure apart and take the harddrive out and test it with a computer desktop that has sata connectable, if your computer is able to read, then your iomega harddrive enclose suffer malfuction, if the computer isn't able to read the harddrive through the sata connection, then your harddrive is bad.
Jan 30, 2011 | Iomega MiniMax (33464) 250 GB Hard Drive
My computer will no longer react to my external harddrive. It's hooked up correctly but whenever I turn it on the harddrive lights go on for a moment then they just turn off and it does not register on my...
first things you have to do is that test the external drive with another system if it works then reload your system i.e format your harddisk and reload it with your operating system.
Jun 12, 2010 | SimpleTech SimpleDrive Pininfarina 320GB...
PC not recognising Iomega Prestige 320gb usb portable hard drive. I've connected it all up, disconnected, reconnected, rebooted the computer, but the drive is just not recognised and does not show up in...
Does the drive show in Device Manager? Right click on 'My Computer' and select properties, the open device manager.. Navigate down to Disk Drives or Hard Drives, click on the plus sign and see if your drive is listed. If it is, then right click on the drive name and open properties for the drive. Click on the 'Volumes' tab and hit the 'Populate Button'. It may be the disk just needs initialising, then reformatting before you can use it. If it does need initializing, a wizard should appear to guide you through the process!
If this doesn't solve your problem, try using a different USB cable and/or USB ports on your computer, and ensure to unplug all other USB devices other than keyboard & mouse.
Mar 06, 2010 | Prestige Portable 320gb Usb 20 IOMEGA ...
Iomega Silver Series 320GB
I have the SAME problem. I've tried all sorts of things and can't get mine to work either! Have you found a solution? All my information is stored on here from my old laptop and I need to use it asap!
Aug 21, 2008 | Iomega Silver Series 320GB 3.5 External -...
CANNOT GET EXTERNAL HARD DRIVE TO WORK ON LABTOP IT WANT EVEN REGISTER ON MY COMPUTER THE NAME OF THE HARDDRIVE IS IOMEGA 320GB
Is this a USB hard drive?
If so do any USB devices work?
Check Disk Manager (STart Menu - My Computer - right-click - Manage - DIsk Manager) - Can you see hard disk?
If so right cick on hard disk and set a drive letter for it in Disk Manager.
Aug 10, 2008 | Computers & Internet
My hard drive is not working
is the system load the bios or nothing happen ? In this case the system not detected the memory maybe the memory lessen, fix it firmly and start the system again.
disregard the solution above if the harddrive is detected in the bios. there is a four connection in the IDE /PATA hard drive.
P master
P Slave
S Master
S Slave
if you connect or use one IDE cable in two connection, the other should be in slave. master is where the Operating system is.
try to verify the hard drive label for a master or a slave harddrive.
If this solution not solve, please notify me b4 u rate so that i can give you further solution. thanks!
Jan 28, 2008 | Western Digital 320GB MyBook External USB...
Failure to mount on desktop
Iomega which is now a thing of the past were renowned for their fragility It may well have died
May 23, 2007 | Iomega MiniMax (33464) 250 GB Hard Drive
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
