Question about Creative Labs Zen V MP3 Player
Zen Will not turn on
I was transferring files from my computer to my Creative Zen and then my Zen locked up. I pressed Contol+Alt+Delete on the computer to stop the transfer process, and now my Zen will not turn on.
It seems as though it does not have any power at all, and it does not seem to be recharging while hooked to the USB port?
Thanks,
  • maurbas_99 Feb 16, 2009
    my zen seems to be dead. I can't turn it on. I plugged it into the computer, but it wasn't recognized.
There is a small hole somewhere on your zen. stick a pin in it for 15 to 20 seconds . tada!!! that will reset your zen!!! it worked for me!!!
Posted on Sep 28, 2008
  • kissian Sep 28, 2008
    (reseting your zen will not erase your files)
Creative Centrale doesn't read my Zen Mozaic 4GB
My Zen Mozaic will charge when I plug it into the computer, but I can't access the files from My Computer and Creative Centrale says, "No Player is connected" when I click on the 'Transfer' button. It works on my other computer though, but that computer has a virus so i can't us
Feb 20, 2009 | Creative Labs Creative Technology Zen MP3...
Can't Add files to mp3 after reinstalling-device not found.
I have an older ZEN, so I'm not sure if I have Creative Media Source 5, but mine never worked really well either. My Windows Media Player recognizes mine, so I just sync to that library. I even have gotten a new laptop since I got my ZEN and I never downloaded anything, I just connected it to Window's Media. I hope that's helpful!
Dec 26, 2008 | Creative Labs Zen MicroPhoto MP3 Player
Creative Zen 32GB player wont display music files in Creative Media Explorer
Update the firmware, available at support.creative.com:
Creative Zen
Try another PC or another USB port
Make sure the hold/lock is not engaged
Reset
Check for firmware update on Creative's website
Get Recovery Tool from Creative
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If all else fails, check with this guy:
http://www.mycreativefansite.com/2007/05/myzenchecker-tools-guide-to-problem.html
Creative Zen – Formatting
Step by step instructions for formatting a player
1. Detach the player from the PC if it is connected, and turn off the player.
2. Press and hold the Play button while powering on the player.
3. When the player displays the Creative logo, release the Play button
4. Select Format (All) and select Yes to format the player.
5. After the player has finished formatting, select Reboot.
6. Re-transfer the tracks to the player.
-Tha Mp3 Doctor
Sep 27, 2008 | Creative Labs Zen Digital Media Player
Can't delete pictures or folder in Zen 2 GB
Try updating the firmware at support.creative.com
Creative Zen
Reset
-Tha Mp3 Doctor
Sep 25, 2008 | Creative Labs Zen Digital Media Player
Rebuilding
You need to use the Recovery Tool from Creative's website at support.creative.com
Creative Zen
Reset
-Tha Mp3 Doctor
Sep 23, 2008 | Creative Labs Zen Digital Media Player
Problem transferring MP3s to Zen Vision 30GB
I have a Zen Vision M 30G, and this is what worked for me.(Widows XP home Edition. First you're going to want to transfer all your files back to your PC to back them up. I've found that even though you can't transfer from your PC to Zen, you can transfer from Zen to PC. Connect your player, and after your Pc recognizes it go to My Computer>click on your player, it should show up as "storage media.">then you right click on it, then select "reformat." A warning should pop notifing that you will lose all you data. Click yes, It should take less than a minute to complete. So essentially you have just wiped your Mp3 player's hard drive clean. Now transfer all your backed up files back to your player.
Aug 16, 2008 | Creative Labs ZEN Vision:M Digital Media...
My creative Zen 8Gb wont allow more than 597 songs..
I'll run a cleanup on your zen, if that doesn't work then you should format it and re-transfer everything. Additionally, you may want to upgrade your players firmware.
How to enter the Zen’s Recovery Mode for Clean Up, Format All, Reload Firmware, and Reboot:
1. With the Zen off, press and hold the "play/pause" button.
2. Continue to hold until you perform Steps 3 and 4. If you accidentally release the button, start the procedure again.
3. Gently push the end of a thin object (like a pin or straightened paperclip) into the Reset hole. You should be able to feel the release click of the button.
4. Slide the On/Off/Lock switch towards the power button and hold until the boot screen appears on the display.
The Recovery Mode screen appears, and four menu items are shown:
Clean Up: A cleanup of the file system and database files takes place. All (uncorrupted) data should stay in tact. When the cleanup is complete, select Reboot. Your player restarts and starts rebuilding its music library. All files should remain intact unless they were detected as being corrupt.
Format All: This will completely reset the Zen and remove all user stored files on it.
Reload Firmware: This will prepare the Zen to accept a reload, new, or older firmware based on the specific firmware file you download and execute on a computer. Selecting this option will prevent your Zen from being able to boot, so make sure you have the firmware file on you computer and ready to load.
Reboot: This will execute a soft reboot of the Zen's operating system.
How to Clean Up, Delete Temp Files, and Reformat the Zen using Zen Media Explorer:
1. Plug the Zen.
2. Go to Zen Media Explorer.
3. Select "Settings and Information".
4. Select the "Tools" Tab.
5. This page will show you the options to Clean Up, Delete Temp Files, and Reformat the Zen.
(Warning: When reformatting, you will lose all files you put on the Zen)
Jun 19, 2008 | Creative Labs Zen Digital Media Player
C cover art does not transfer to my zen vision m, only the music tracks transfer
A few possibilities. Go to http://193.95.171.83/SRVS/CGI-BIN/WEBCGI.EXE/,/?St=224,E=0000000000373151655,K=1742,Sxi=15,Case=obj(8179),Kb=ww_english_add,VARSET=ws:http://us.creative.com/
for more details
Creative ZEN players do not currently support album art from Rhapsody version 4.0.
Album art is either embedded in a track, or exists as a thumbnail image in a separate file, allowing one album art file to be associated with an album. Currently, Rhapsody only supports album art embedded in the track. Future versions of Rhapsody are expected to support thumbnail versions.
Creative Media Explorer or Windows Media Player 10 or 11 can be used to transfer music purchased from Rhapsody to a player with album art included.
Album Art is supported by Creative ZEN, Creative ZEN V Plus, ZEN V, Vision:M and ZEN Vision players.
The ZEN Vision (PF1150) requires a firmware update for Album Art. You can download the updated firmware:
If you experience any difficulty transferring Album Art with Windows Media Player 10 or 11, to ZEN Vision:M, delete WMPInfo.xml (see below), and then transfer the tracks again.
-Tha Mp3 Doctor
Apr 18, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative ZEN Vision M
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
If that doesn't fix it try the USB cable
Screen Doesn’t come on anymore
http://www.anythingbutipod.com/forum/showthread.php?t=18859
If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Feb 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Can't transfer songs onto my mp3 player
Some types of mp3 files won't transfer to Creative Zen players. Try re-encoding the files either again in mp3 or in wma and try importing them again.
Jan 01, 2007 | Creative Labs Zen Micro MP3 Player
Creative Labs Zen V MP3 Player Logo
88 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
