Electric front driver seat stopped working
The driver's seat will only move up, not down, forward or backward. This is the second time in a month that this happened. The first time, I replaced the 40 amp fuse, number 104. This time, I replaced the fuse but it did not fix the problem.
check switch for proper operation //check motor control for power ,connections and wires are not damaged or disconnected===check seat track for debris or something stuck
Could be a bad switch or motor, or something jamming the seat movement.
Can you hear the motor running on both switches and directions?
I don't think they would have two fuses for the seat, but that might be a possibility.
Hope this helps.
sounds like you might have a switch problem if the memory for seat position works ok. If you have a multimeter that checks for continuity then you could start there at the switch but you would also need a wiring diagram for the seats
Check the fuse box for a blown fuse, both seats may operate on one fuse depending on the model of vehicle and the fuse may be located either under the dash on the drivers side or in the engine compartment on the drivers side.
You can move the drivers seat back by turning on the power, getting in the seat and position your feet firmly on the fron flor with your back firmly against he seatback, and then engage the switch pushing back - while pushing like hell with your feet. You can actually hear the seat drive shaft turning while the seat moves back. The principle should be the same for moving forward, but pressure would have to be aplide to the back of the seat.
My intuition tells me that the 6 way power seat track forward / reverse motor is bad. Sometimes you can replace just the one motor but most often a whole new power seat track is the only way to repair. It is not too bad to replace but the seat will have to be removed from the car and placed upside down to access the track assy. There are 2 bolts in the front of the seat and 2 bolts in the back of the seat that hold it down to the floorboard. Once it is loose you can rock the seat backwards to access and unplug the electrical connectors.
front driver seat blow 30amp fuse when moved
