Question about Clarion DRX-9675Z CD Player
The face will not light up when it is closed. No buttons work, either.
I have had this cd player for a long time. Before I removed it from my car it was having problems reading cds, so I replaced it. I tried installing it in my bro's car and we have all the connection right, voltage is there, but it will not power on. I took it apart and cleaned it up and tried it again. Nothing, so I forced the face open like it does when you push the eject button, and it powered on. But when the face closes it goes blank, and nothing works. I have tried to reset it as well... Any Ideas?
  • BNagy Aug 12, 2008
    Cool, I will check this out. Thanks!
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 108 Answers
You may have a bad contact on the faceplate or on the main head unit. You can try cleaning the electrical contacts with a small amount of rubbing alcohol and a cotton swab. If this doesn't help, then you may need either piece serviced. Often times the solder joints on the PC boards inside the head unit or inside the face may need to be repaired. A local stereo shop can check for this or a local electronics repair can look for "cold solder joints"
Posted on Aug 11, 2008
I have a AIWA X204 CD in my car.I don,t know what I did, but the player doesn't answer to any comand. i push every one of button, but he don;t start to play.The screen it's light up,, and...
I think that's Demo mode.
I got stuck there too.
This is what worked for me:
  1. Power the radio off (hold the power button in top left corner in for several seconds)
  2. Remove face plate
  3. Hold in reset 10 seconds
  4. Press push-menu dial/button 3 or 4 times
  5. Insert cd and hit source to switch to tuner before cd starts
Not all of these steps may be necessary.
I suspect having the power off before the reset button was the important part.
Jul 26, 2011 | Aiwa CDC-X204 CD Player
No sound or lights
make sure the yellow wire has power all the time and the red wire has power when the key is on. Most likely you do not have power to the red.
May 19, 2010 | Boss 506CA CD Player
Power is working face is not lighting up or
Did you try pluging the car (hard) blue remote wire into the "jack" on the back of the stereo arching it??
Oct 28, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Xplode cdx-gt460u CD Reset Error
REMOVE THE FACE PLATE THERE SHOULD BE A RESET BUTTON ON THE FRONT OF THE RADIO PUSH THAT AND TRY AGAIN IF THAT DOESNT WORK THEN PULL THE RADIO AND DISCONNECT FROM POWER 4 A LIL BIT AND THAT MAY WORK
Dec 29, 2008 | Sony XPLOD CDX-GT200 CD Player
CD Stuck in cd player
There should be a reset button on either the face of the player or under the faceplate if its removable (tiny black button). Otherwise to remove the cd disconnect the unit and then plug it in or remove the memory fuse or battery lead for 5 seconds.
Jul 05, 2008 | Pioneer DEH-P4100
Old CD player (25 years!) is stuffed. But can't retrieve CD in drive. Open/close button works but no reaction. Can I force it mechanically?
usually in the front face of cd player drawer is a small hole
a straightened paper clip pushed in the hole will unlock the drawer and let it slide forwarw manually to remove the cd
May 03, 2008 | Televison & Video
Hidden coupled frequencies and 2 buttons not working
try reseting the unit if i dont work new face required
Aug 15, 2007 | Alpine CDA-9827 CD Player
Sony CDX M8800 Front Panel Problem
u need 2 replace the ribbon that goes to the panel to the unit.i had the same problem with mine then i went on to ebay and found the ribbon there (cdx-m8800 repair kit)hope this helps
Dec 17, 2006 | Sony CDX-M8800 CD Player
Face does not come down and remote won't work
EXTREMELY common problem for these units. The faceplate ribbon cable has gone bad and needs to be replaced.
Sep 20, 2006 | Sony CDX-M800 CD Player
Clarion DRX-9675Z CD Player Logo
70 people viewed this question
Top Clarion Car Audio & Video Experts
xxxxxx xxx
Marco Avila
Marco Avila
Are you a Clarion Car Audio and Video Expert? Answer questions, earn points and help others
