No picture or sound
TV went off, red power indicatior light blinking. Makes the clicking sound like it's trying to come on but doesn't.
  • 1 more comment
  • 9ers Aug 10, 2008
    Toshiba TP50G90 50" Projection Television
  • 9ers Aug 10, 2008
    Our power went off later in the morning for about 20 minutes. Sould we still try solution 1?
  • 9ers Aug 10, 2008
    So if unplugging didn't work, a repairman is required, correct?
    Thanks for the assistance!
  • 8,617 Answers
The clicking your hearing is the relay which is bridging to try to take the TV from stand by power to start up power supply when the power switch is closed. You can try unplugging the set to see if it resets, But i believe the problem will be in your power supply section of your set.
Posted on Aug 10, 2008
  • Sonny Berry
    Sonny Berry Aug 10, 2008
    Yes, I would however insure that the repairman is certified to work on your type of TV, as an inexperienced repair shop can cots extra money by replacing Boards that you dont need replaced.
  • 19,396 Answers
Try first unplugging power cable for 5 minutes
  • 1 more comment
  • Ginko
    Ginko Aug 10, 2008
    t The clicking sound it is caused by TV safety switch preventing TV from turning on. Internal safety Switch prevents tv from turning on when a short or an overvoltage is detected.
    This is often caused by a faulty IC, a burnt capacitor or another faulty component on tv board.
    Try first unplugging power cable for 5 minutes, to see if this reset TV, as sometimes safety switch is just stuck.
    If it does not clear the error, then the unit must be taken apart an the board tested with a multimeter until you find the problem.
    This job should be done by a technician, unless you have experience repairing TVs, I suggest to call service, you will find repair service phone number printed on last pages of your TV owner manual.
    Regards
  • Ginko
    Ginko Aug 10, 2008
    Even if power went off two days ago you should do unplugging if you havent done it yet, try first 5 or ten minutes, then 20 minutes if first attempt did not work, when power is drained from tv safety device wil reset, unless a component had been damaged during power cut, this will fix the problem.
  • Ginko
    Ginko Aug 11, 2008
    Yes, when unplugging does not work it usually means there is a short or a faulty component, to locate and repair the fault you need a repairman.
Why does plasma TV have no picture?
What brand and model # is the tv? This is very important as far as researching your problem. You probably aren't the first or the only person with this problem. There are typically four to 5 boards including an x main, a y main, power board and others. Sometimes easy stuff like capacitors or fet's go bad and you can fix it yourself pending your soldering abilities. Sometimes whole processors go bad or entire boards and these need to be replaced. Sometimes people want to fix sometimes they want brand new
Jul 07, 2015 | Televison & Video
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
My TV died & all that remains is the red light of death!
What you see is an indication of some failure inside the board. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | Televison & Video
My toshiba 57h93 worked fine this morning power went out
Ur DM power board is dead,must be replaced.Try this
website for the board.Tv repair World.com.
Oct 20, 2009 | Toshiba 57H93 57" Rear Projection HDTV
Red power light continuously blinking. no picture no sound.
It could be the lamp went out and needs replacement. The Toshiba website states when this happens to unplug the televison for 10 minutes then plug back in. If that does not work then try another power outlet. If that does not work then call for service
Sep 12, 2009 | Toshiba 57H81 57" Rear Projection...
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
TV picture went out.
power supply problem check capacitors...caution
high voltages..large capacitors retain nasty charge for a long time.........
Feb 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Sony trinitron KV-27S42
Replace the horizontal output transistor (Q502) and check the electrolytic caps in the vicinty, unsing an ESR meter. PLEASE NOTE THAT THE TV TUBE MIGHT BE CHARGE WITH ABOUT 27,000 VOLTS.
Sep 13, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
