Question about Sony NWZ-S615F Walkman Video MP3 Player
Player won't turn on
I left player conected to pc for 2 weeks and now it won't turn on. what can i do ?
My player went dead and now it will not charge.
Posted on Sep 06, 2008
How to conect my samsung sp y3 to pc
1. Install the Samsung Media Studio on your PC from the installation CD that came with the player.
2. After the software installation completes successfully, connect the player to a USB port on your PC.
3. Samsung Media Studio program starts automatically once the player is connected to the PC. Follow the instructions.
Oct 13, 2014 | Samsung Yp-S3 Personal Mp3 Players
My Ematic 7 4g wifi ebook reader can't conect to
just go to network setting and turn ON WiFi first, then make a search for the availebel networks
Nov 14, 2012 | Computers & Internet
Board will not start
Just after that there was NO correct answer to fix this problem causes the problem not solved even if it is marked as solved. Me too I have this problem, I was fix it by setting jumpers to default 60 Hz AC power because I won`t have 50Hz AC power or some AC power converter before PSU, I mean this is voltage errors, it`s need to be set to default +5V(60Hz) PSU not +5VSB(50Hz) PSU, (Step1) like might be set to USBPW12 to pin 3 both USB to right side inserted jumper it`s in left side of, near ATX 12v advanced CPU power cable connection socket. Next (step 2) is set up front USB jumpers to +5V or system won`t start up, it`s on motherboard about between PCI1 and PCI2 on right side it must be set up to USBPW56 and don`t set it to USBPW78(5+VBS) because system won`t start up, the jumper must be set to right side I mean it`s last jumpers to right side need to be set up, because it`s +5V(60Hz) PSU supply. The USB wake-up feature requires a power supply that can provide at least 500mA on the +5VSB lead when these jumpers are set to +5VSB otherwise the system won`t power up. Next step if it still not starts up its BIOS fault, it`s easy to repair, just (Step3) turn off PC remove BIOS battery (it`s down to IDE cables), start it up wait a bit, then turn it off and turn it again on wait a bit again, turn it off place BIOS battery in to socket to be able save BIOS settings i mean battery is need to save them otherwise settings won`t be saved and Chassis will be broken. (Step 4) Turn PC on press del key after BIOS is load in open Power\Hardware monitoring\Chassis Intruder set to Disable, save settings exit. (Step5) If BIOS (PC won`t power up) it`s Chassis1 jumper fault, it`s need set to Default (Chassis signal, and GND(Ground)), it`s between SATA 2 and SATA1(Serial ATA connectors 7-pin it`s near and down to BIOS battery, the jumpers might be set to right side, after it`s completed repeat Step3 and Step4. CMOS is BIOS battery. If that all doesn't works Take BIOS clearing jumper in it`s clear state, near BIOS chip. Turn on PC with CMOS clear jumper turned on its work. Take beck jumper in its default state after that take bios chip out and CMOS battery out both them an two times restart PC after insert all beck if PC will be working all keyboard flashes once, after its in AC power.
Aug 18, 2012 | ASUS P4P800-VM Motherboard
@hari did you turned off your sony player before connecting it to pc ?
if not then turn it off and try again.
Nov 22, 2011 | Sony NWZB135F MP3 Player
When hit switch pto won,t come on
check the 2 wire conection under the frame near the pto clutch, motor off of course. Make um tight.
Apr 30, 2010 | Oregon Scientific Electric PTO Clutch for...
I dont know how to put music in this mp3 player!!!
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Good Luck,
I hope this helps
Please rate me,
Thank You
Apr 08, 2010 | Sharper Image 1612911 MP3 Player
Every 6 weeks my loptop will not conect to
You need to make sure that your router has the latest firmware and v\change your wirle4ss chaneel and turn off the device for a couple of time twice or thrice a week so it won;t get over heated. also make sure that it is plug on a surge protector so if you will get a power outage it won't reset the router
Sep 05, 2009 | Linksys WRT300N Wireless Router
Help please
did you use the safely remove hardware button on your taskbar
if not the computer was still writing to the device when you removed the usb connector and damaged the software on the device
my sis did that and killed a very expensive Mp3 player
(iPOD video 40gb)
its toast
Jul 25, 2008 | Insignia NS-DV2G MP3 Player
The battery conection to the board
The manual pretty clearly states not to replace the battery - the manufacturer usually has a way to fix any issue you are having with the player. Now that you have damaged the player yourself, your warranty is voided. sorry about your luck
Jun 21, 2008 | Sony Network Walkman NW-A3000 MP3 Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
Top Sony Audio Players & Recorders Experts
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
