Question about Garmin Edge 305HR GPS Receiver
Heart monitor doesn't work - Garmin Edge 305HR GPS Receiver
I have heard that the gold connector does not always connect with the +ive part of the battery. Others have bent the gold connector out slightly and the problem has been solved. Good luck.
Posted on Apr 03, 2009
The heart rate monitor chest strap no longer works and I need to buy a replacement. Which are compatible ?
Maybe you can find a replacemente. Do a google search for terms
Heart rate Monitor, the make, model and PARTS
If can't find, do a search for Manufacturer's website and try to get information from some "Contact Us" option. Some even have a phone number.
A shot in the dark:
Accessories Polar USA
Polar Transmitters Straps and Heart Bras
heart rate monitor parts Google Search
Elastic Strap for Heart Rate Monitor Garmin
Sep 01, 2015 | Exercise & Fitness
My Skechers GOwalk Strapless Heart Rate Monitor (Basic; Model Number WR30M; Distributed by Sports Beat, Inc.) will not read the heart rate. I bought this digital watch new, and it worked in reading the...
Well it depends on how much you sweat.
The sensors need to be wet to read correctly.
You can buy something called Heart Rate Gel cost about $5 to $10
Some people just lick the sensors on the watch strap and it works until they can start sweat enough..
Hope this helps.
Nov 03, 2013 | Bowflex WR30M EZ Pro Strapless Heart Rate...
My heart rate monitor does not work when gripping the hand bars.
please follow the steps and fix it. God bless you
1) Make sure the heart rate monitor is under your clothing, against your skin, and as high under the pectoral muscles as is comfortable. Note: If the heart rate monitor does not function when positioned as described, try moving it slightly lower or higher on your chest.
2) Make sure the logo on the sensor is facing forward and is right side up.
3) Use saline solution (saliva or contact lens solution) to wet the two electrode areas on the sensor unit. If the heart rate readings do not appear until you begin perspiring, re-wet the electrode areas.
4) As you walk or run on the treadmill, position yourself near the center of the walking belt. For the console to display heart rate readings
5) The heart rate monitor is designed to work with people who have normal heart rhythms. Heart rate detection problems may be caused by medical conditions such as premature ventricular contractions (pvcs), tachycardia bursts, and arrhythmia.
6) The operation of the heart rate monitor can be affected by magnetic interference caused by high power lines or other sources. If you suspect that magnetic interference may be causing a problem, try relocating the treadmill.
7) If the heart rate monitor still does not function properly, test it by having another person try it.
Jan 22, 2013 | Ironman Exercise & Fitness
Can not turn on
Then it needs a new battery or some sort of repair. The button on the face turns the monitor on for use, if this doesn't work, then you need to replace something.
Apr 24, 2011 | Polar FS1 Unisex Heart Rate Monitor Watch
Which Polar heart rate monitors work with Fuel Fitness FS320e Elliptical
Any analog signal Polar should work fine. Stay away from the RS-800 series.
Mar 26, 2011 | Polar Heart Rate Monitors
Heart rate monitor not working, changed battery and fiddled with battery to make sure contacts touch, still not working
You need to go in and reset you heart monitor so it is set with the device. Go into accessories; heart rate monitor and reset it. For some reason, it loses it's connection with the monitor and needs to be reset. Especially if you haven't used it for a hwile. My son borrowed my garmin and heart reate monitor. I thought he broke it, but it just needed to be reset.
May 01, 2010 | Heartbeat Garmin Forerunner 305 Gps...
Remove the batteries and clean the battery contacts inside the device with a common pencil. Then insert new batteries that you know are fresh. That should fix it. If it still won't work for you go to and send it in for repair. Joe
Mar 19, 2010 | Heart Interface Garmin 305 Gps Heart Rate...
Heart rate reading low
try this link for the manual.
polar f11 heart rate monitor manual Google Search .
However, you may wish to reset the unit and start over with new settings. You can resetyour Polar F11 by following a few easy steps. Press any button to activate the Polar F11 Fitness heart monitor unit. Press all buttons on the Polar F11 Fitness heart monitor simultaneously, except the "Light" button.
How to Reset a Polar F11 ' Healthfully reset polar f11 heart rate monitor Google Search
Oct 29, 2017 | Polar F11 Heart Rate Monitor
Every heart rate monitor - replacement battery doesn't work.
This link might be helpful...under the picture of the given product click on "great information about this product" It gives all the specs and troubleshooting ideas. I hope this is helpful.
Dec 06, 2008 | Exercise & Fitness
Garmin Edge 305HR GPS Receiver Logo
128 people viewed this question
Top Garmin GPS Experts
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
