Question about Gateway GT5220 PC Desktop
How can I tell if my DVD burner/drive is shot? Windows Vista
How can i tell if my dvd drive burner is shot? I can see the drive in my computer, however it won't read any discs. Any suggestions before I replace? I would appreciate any help.
    Genius:
  • 1,689 Answers
First you may try to remove it from the PC, open it then check if a part is loose or broken, now while the burner has no cover, you may run it, and check if the lens is stuck in its position, you may wna to check the railing if it is clean (be careful not to directly look at the lens while it is on.
now if nothing seems to work, you may then get a new burner.
Posted on Aug 10, 2008
SOURCE:
My lg (gh22ns30) dvd+rw burner will not read a dvd or dvd rom.
You can go to the control panel, then to device manager, click on disk drives. Make sure you have the right one and then delete it. Restart the computer and it should "find" it and install it, that is if it still works.
Feb 24, 2012 | LG (GH22NS30) DVD+RW Burner
Mon lecteur est en panne je veux le changer
You can change the dvd rom by opening the computer case and taking out the sata cable and power cable.
you can replace it with any SATA DVD+/-RW SATA Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Windows XP, Vista and 7 will automatically install the new DVD drive for you.
Vous pouvez modifier le DVD-ROM en ouvrant le boîtier de l'ordinateur et en tenant le câble SATA et câble d'alimentation.
vous pouvez la remplacer par n'importe quel DVD SATA + /-RW SATA Drive
Windows XP, Vista et 7 installera automatiquement le nouveau lecteur DVD pour vous
Mar 01, 2011 | Sony Optiarc AD7240S DVD?±RW (?±R DL) ...
WILL NOT LOAD IN WINDOWS VISTA
This is the requirements for DVD Express. There are a lot of programs that are not compatible with Vista.
Minimum Requirements
  • Windows XP, 2000, 98, ME
  • Pentium II 450 MHz processor
  • 64 MB of RAM
  • Hard Drive free space of 10GB
  • DVD Burner (DVD-R, DVD+R, DVD-RW, or DVD+RW)
  • Blank DVD Media (DVD-R, DVD+R, DVD-RW, or DVD+R
http://www.dvdcloningsoftware.com/dvdxpress.htm
You might consider to partition your hard-drive so you can run XP on it too and be able to run programs like this one. Hope this helps, sorry for you luck. Let me know if I can help you with anything else.
JimmyC
Oct 04, 2009 | 321studios DVD X Copy Express (200083) for...
Dvd drive not reconized by windows
Hi ranman3995,
Your not alone with the Vista problems. I'm going to send you to a Microsoft site that will walk you through changing your registry that should fix the problem. HERE.
Good Luck,
Mark
Jan 14, 2009 | Samsung SH-S182D DVD RW Dual Layer Burner
I need drivers for a dvd super multi
I have an LG super multi burner that worked great on my older computer with windows xp, but i just moved it to my new computer with vista and it will not accept the software. the computer will read discs in the drive, but it will not burn, it acts as if there is not disc in it to burn. what can i do?
Sep 24, 2008 | LG GMA-4020B Super-Multi...
Can I burn to disk a movie from my hard drive "avi file format"and play it in a dvd player
you cant play avi on normal dvd player,but you can convert avi to dvd format by use free softwere ( filmMachine )
Aug 10, 2008 | Panasonic Televison & Video
Pioneer DVDRW DVR-K17B ATA Drive
This is my error in report viewer for my dvdrw in laptop.
dvdrw icon is hide and it can't read any disk dvd/cd.
PLEASE HELP ME! THANKFUL
" Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 39. "
Aug 06, 2008 | Pioneer DVR-107D DVD±RW Burner
Need help
The most likely problem is that the Burner is shot and will no longer function. How long have you had this burner? Have you run tests on the burner? Has your system crashed before this began to occur? I can only solve your problem with this information.
RCF
May 27, 2008 | Microsoft Windows Vista Ultimate Edition
Lite On LH-18A1P DVD RW
Copywrited DVD Movies require that an MPEG software DVD Decoder be installed on your system. Windows doesn't include any because of their Anti-Trust violations and court issues.
(not to be confused with other media players, and DVD players that are included with DVD Movies, such as HOTLLAMA, and Interactive - you still need a DECODER. This is a throwback to the early days of PC DVD ROM's that required a HARDWARE MPEG DVD DECODER be installed, usually in a PCI slot, and connected to your video card through the VESA expansion connector. Nowadays, the hardware is built into the DVD unit, but it still requires a software decoder to operate).
Every DVD ROM or Burner comes with one...usually "Cyberlink PowerDVD", and now Nero's included one in their bundled OEM package.
Any version of any one of these will unlock the "DVD Movie" features for all media player installed on your PC.
[oops, almost forgot, you need Nero 7 or better for Vista. Any Cyberlink should work for you].
If you don't have one, try borrowing one from anyone who's got one. You can also go the P2P route, and download one, if you're so inclined.
Good luck, and I hope that fixes your problem!
Jan 05, 2008 | Lite On LH-20A1H DVD RW Dual Layer Burner
Gateway GT5220 PC Desktop Logo
767 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Thomas F. Schneider
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
