Question about Buffalo Technology WHR-G54S Wireless Router (WHR2G54S)
Can't connect I'm home on leave from Afghanistan and can't connect to the internet on my Buffalo Wireless router. The icon says "connected" and signal strength "excellent" but when I try to connect I get the error that says "cannot find server". I know it's probably just a setting on my laptop but I would really appreciate some help. Thanks Tyler
  • enquiries920 Oct 04, 2008
    I connected up my wbmr G54 and ran the wizard, LAN shows connected also wireless on another computer shows connected, but am unable to connect to internet. Could it be IP address problem if so how do I resolve. As in the buffalo manual I set the LAN to automatically obtain IP address.
  • alcoy_minera Nov 03, 2008
    cant connect to the internet, the icon always says acquiring ip address
    Problem Solver:
  • 16 Answers
It will be one of two things or both - either your computer is notsetup for DHCP or your router is using the same IP address as your ISPor both.
To check ISP IP address connect your computer to your modem then: from start => run => CMD (hit enter after this)
a command window opens, type "ipconfig /all" without the quotes.
The line with "IP address" gives you your ISP IP addr.
Compare this with what you get from your router manual if they are the same then do the following:
Toconfigure your computer to use a DHCP IP address, go to the Controlpanel => network connections => Properties (right click on yourdefault connection) => double click Internet protocol (From generaltab) => (a new window pops up) from the general tab ensure that"obtain an IP address automatically" is selected.
To change the IP address of your router check your manual and do the following:
IP Addr => 10.10.1.1
Sub net mask => 255.255.0.0
Default gateway => IP address from your ISP
Make sure to the router is set to act as a DHCP server.
You should be up and running.
Posted on Aug 10, 2008
SOURCE:
Airstation buffalo wireless connection
Check the user manual here (link bellow). Hope this'll work. If not, let me know and I'll help you further.
http://manual.buffalo.jp/buf-doc/35012391-1_en.pdf
Feb 01, 2014 | Buffalo Technology AirStation Computers &...
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Client Manager will not pick up my buffalo wireless card.
You can find the driver in the Buffalo download archive for older products:
http://site2.buffalotech.com/support/downloads2.php
Choose from the menu.
You also find manuals and set-up guides there.
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Jul 31, 2009 | Buffalo Technology Buffalo AirStation...
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Cannot get onto internet
disable the firewall on control panel.
check all the properties boxes on the network
connections and make sure firewall is disabled.
access the router setup and make sure that VCI is set to manual
and that you enter in the settings yourself (eg: 0,38 for aol broadband). Don't leave VCI, etc on auto, the router can't handle it.
Jan 09, 2009 | Buffalo Technology WHR-G54S Wireless...
I wish to connect a WGT 624v3 wireless router to a laptop on Vist
Hello again! No problem at all, and thank you for the information. I'll do what I can to help.
If the plan is to make a wireless internet connection with the new laptop, I would usually split it into three stages:
1) Establish a wired connection to the internet
2) Connect wirelessly from the laptop
3) Secure the wireless connection
In this case it's worth trying to connect wirelessly straight away. This is because a wired connection seems to have been established already, with the old desktop.
So the first things to do are:
A) Make sure the router is connected to the modem;
B) Switch on the router and modem. There should be some comforting green lights displayed on the front of the router, including one that looks like a wireless beacon. That shows the wireless 'access point' in the router is functioning
C) Switch on the laptop. There may also be a switch on the laptop to enable the wireless connection: if so, switch it on.
When the laptop has fully booted up, see if there is a 'wireless networks' icon visible in the laptop screen Notification Area (bottom right). If not, try restarting the computer.
If there is an icon, floating the cursor over the icon may show a message saying 'wireless networks available' or similar. Click on the icon and your relative may see a screen with an option to 'view wireless networks', or similar (I'm an XP user, so hope you can interpret here). If so, one will be an unsecured connection - hers! She should be able to click to connect. I recommend being as close as possible to the router when first connecting.
If she cannot find her own network, or there is no icon to click, or the network has previously been secured - please let me/us know.
If everything works correctly the first time (!), your relative should now have an unsecured wireless connection to the internet. This is a good time to experiment with the placement of the router and the laptop, to ensure a good signal is received. However, it is NOT recommended to use an unsecured connection for long, and not at all for anything private. It is like leaving your personal information on the doorstep for all to read. A wired connection is, by contrast, secure.
If everything works to this point, I'm happy to help with securing the wireless connection. However, establishing any connection is the first step. So, please let me/us know if anything is not clear, or does not work as hoped. Good luck!
Dec 12, 2008 | NetGear WGT624 Wireless Router
Buffalo Airstation G54 wireless is not working
connect your computer straight to your internet modem.
If it works then connect the router after reset....
read the manual..if it does not work then return your router and get a new one or simply buy netgear..has been working for me Without problems for 4 years other than two years ago got fried due to electrical over charge
Apr 05, 2008 | Buffalo Technology AirStation WBR2-G54S...
Wanting to purchase a router
Ok, my friend if you don't have internet services whether you use router or modem you won't be able to connect...
You can buy a netgear, buffalo or speed touch router they are quite good...
Feb 19, 2008 | Digi ConnectPort (CP-WAN-A300) Router
Buffalo wireless router
you may need to dissable your wired lan adapter as it will be looking to assign the same ip address and you need it to assign to your wireless adapter. Asuming your router is wireless enabled as some are not be default and make sure your router has DHCP enabled to automatically assign ip addresses to your pc,s
Sep 16, 2007 | Buffalo Technology Buffalo AirStation...
Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
139 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Ekse
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
