Question about Kenmore Oasis HE 27082 Top Load Washer
Removing top component
How did you remove the top component? I have the exact problem and can see the garment in the tub but cannot get to it.
  • Anonymous Aug 28, 2008
    need to take top off kenmore washer
  • 550 Answers
Kenmore washer
remove left right edge trims of control panel
remove phillips screws from bottom edges of control panel
slide control panel forwad and up ~1inch
flip control panel over the back
remove bronze body springs
remove lid switch connector
lift body ~1inch slide forward and off
reinstall in reverse order
Posted on Sep 02, 2008
Water leak at bottom of Whirlpool Estate washer. Removed the cabinet. No leaks from the water pump, hoses or inlet valve. The tub leans a little toward the front of the machine. When filling/rinsin
It is common on Whirlpool models for the water to splash out the top when filling especially when sheets or nylon cloth is loaded in the washer. Air fills the cloth and balloons the garment up this caused water to bounce off the garment and splash out the back. This is the most common reason for those mysterious leaks. Lowering the water pressure coming into the washer can help prevent this.
Jan 25, 2015 | Whirlpool Washing Machines
Often, the machine (Maytag, MAV1000) doesn't spin at the end of a cycle. The belt must be slipping because there is a lot of black "belt dust" underneath the machine. We recently had a...
i have a feeling that probably your tub bearing may be jammed. You can lift the machine at a 45 degree angle take the belt off and try turning the transmission pulley either way, one way will turn free for wash mode and other way will be more difficult but you should be able to turn the pulley so you could see if if your tub turns if not well you just found your problem. You will not be able to repair it b because you will need special tools.
Other probability would be a garment stuck between the two tubs accessable by removing front panel and lifting the top.
lift top by inserting flat blade tool at each end in between top and front push clips and lift top
Front removal twoo screws 5/16 nut driver on each end inner portion of the front panel.
Unclip tub cover and remove and you will be able to see between the two tubs.
Hope this helps.
Jul 02, 2011 | Maytag Washing Machines
Code F20, what is it and what do i do?????
The "F20" means no water is detected entering the tub or the pressure switch trip was not detected.
There is a good possibility the reason why is because some or all the water is coming out the dispenser. The reason why it's coming out of the dispenser is most likely due to a small garment was shoved up into the tube that delivers the water into the tub. This can happen if the washer is overloaded or if the garment is too small. Small garments should be placed in a garment bag before washing.
Remove the dispenser drawer and confirm there is no block there and then open the door and look at the rubber boot at about the 10 or 11 o'clock position and you should see where the water enters the tub. You will likely find a small garment up inside the tube restricting the fill water from entering the tub and causing the F20.
Feb 13, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Squeaky when used and the edges or strings on garments get caught on the front part of dryer and either ruin the garment or break the string Do i need a new dryer?
There are several drum slides mounted on the front tub bearing (shroud). When these slides wear out the tub can drop down just enough to cause garments to get hung. If you catch it early enough you can just replace the slides. If not you may have to replace the front bearing as well.
You can tell by removing the top of the machine. There are normally 2 to 4 screws holding the top on. open the door and look up to the top and you will see the screws to remove and then take the top off and look at the front of the dryer where the tub rests on the top of the slides and bearings. you can look at it and tell if it is wore out. slides are 316 and front tub bearing is 313 on the illustration.
Jul 14, 2010 | GE Dryers
When in spin cycle water will not drain out of the washer Model # etw4300sqo
Unplug the washer.
Use a shop vac to remove water from the tub.
Remove the screws on the rear of the control console on the right and left back corners (2 screws).
Fold the console to the rear of the machine.
Remove the 2 curved brass clips holding the machine cabinet top to the rear panel.
Disconnect the lid switch wires.
Remove the cabinet.
The drain pump is attached to the front of the motor on the bottom center.
Remove the drain pump.
Remove the garment stuck inside the pump.
Mar 11, 2010 | Whirlpool Washing Machines
Kenmore 3.5 super capacity. will not go to spin
if the drive coupler is broken it won't wash or spin. Does it have a removable lower access panel on the front? if so its an amana. see if u can manually turn the transmission pully both directions. AND make sure there is nothing holding the tub ie nail through tub whole garment between tubs etc.
Jun 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Shirt caught between the drums on my whirlpool cabrio washer
1. Unplug and take off the top of the washer.  There are two pressure clips in the front inside the crack between the top and body of the washer.  Use a stiff putty kniff to depress the clips and flip the top up out of the way.
2. Pry the top plastic shroud off the tub.  There are a series of plastic retainers clips around the shroud.  Pry them up and remove the shroud.
3. On the small agitator on the bottom of the washer, use your putty knife to remove the domed plastic cap in the center.  Pry it up with the corner of the knife to expose the nut.
4. Use a socket wrench to remove the center nut.  It will likely take a good deal of force to loosen it.
5. Once you have removed the center nut, get another person to help you lift the stainless steel inner tub out of the washer.  Place it aside.
6. In the bottom of the outer plastic tub, you will find the shirt (or other garment) caught in the drain.  Remove the screws on the top of the plastic drain cover, and lift up the drain cover.
7. Remove the stuck item(s).  For all the coins and small part that have fallen into the drain tub, you may have to open up the back of the washer and remove the drain hose to access the items in the drain.  Luckily the drain hose is held on with cheap hose pressure clamps, so you can do this relatively easily.
8. Call or email whirlpool and tell them that the washer is pulling clothes into the space between the inner and outer drums.  They will respond by telling you they have never heard of this problem before and if you need service, call "A&E Factory Service toll-free at (800) 771-3029."
9. Be frustrated and vow never to buy a Whirlpool product again.
Hope this helps
Apr 20, 2009 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
Clothing in between tub and will not spin at high speed on spin cycle i think i need to remove agitator to remove whatever is stuck around shaft and tub
Remove the cabinet.
Remove the plastic ring snapped to the outer tub.
Use a wire coat hanger to remove the garment.
Replace the plastic ring and the cabinet.
Mar 09, 2009 | Kenmore 22422 Top Load Washer
Drum turns slow and makes a loud noise
Check for a garment stuck between the tubs.
Check the direct drive coupling on the motor.
You must remove the cabinet to do this.
Mar 05, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore Elite Oasis TL washer, stubborn Sd code
Found the problem. After removing the back panel, found some garments in the bottom of the surrounding clear plastic tub. These must have been periodically blocking the outflow area and triggering the Sd error code. Fixed it by opening the top components of the washer so I could see down into the surrounding tub from above. Fished out the garments with clothes hangar. Put everything back together and have done six loads with zero problems.
Mar 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
172 people viewed this question
Sal De
fordexpert
Robert Rankin
