Question about Roper RAS8244KQ Top Load Washer
Whirlpool TAWB600EQ1 - Washer
Won't go into spin cycle or pump out. Fills and agitates okay.
How mush is it to replace lid switch?
Posted on Oct 23, 2008
    Genius:
  • 1,028 Answers
Ck lid switch usually on right side of lid opening or on later models under back corner at lid hinge area
Posted on Aug 11, 2008
SOURCE:
Washer fills but won't agitate or spin
Try making sure the belts are actually on the drum, probably have to turn upside down. Sounds silly but a lot of simple things are missed.
Apr 02, 2012 | Whirlpool Washing Machines
Hoover 500mb washing machine failing to spin.
my does everything but it just wont spin drye
Mar 25, 2012 | Hoover HTC243 Top Load Washer
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
Washer won't do spin cycle....and won't start any cycle
Hello & Welcome to FixYa
When the washer fills but does not agitate or spin then you can check if the lid switch is fine. You can jump start the lid switch by connecting both the wires with each other or use the third wire to act as jumper between the two. After this if the problem is solved then replacing lid switch is recommended repair. Please get back to me if you have any other questions.
Kevin
Jul 15, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer does not seem to change cycles. Fills and agitates fine, but does not seem to go further than the first cycle.Suspect timer issue.
Good day,
If it fills and agitates and gets thru the first cycle, but won't pump out and spin, then it would be a bad lid switch. Check the following clip for more info.
http://www.youtube.com/watch?v=fC8SY3cU1Yc
Nov 06, 2010 | Whirlpool Washing Machines
Fills but will not agitate, spin, or drain, motor sounds strained
i have a whirlpool that go threw a wash cycle, but will not shin out the water
Apr 16, 2009 | Whirlpool LSR5132PQ Top Load Washer
Roper RAS8244KQ Top Load Washer Logo
136 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Gerry Harvey
Gerry Harvey
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
