Question about JVC AM FM CD DET FACE CAR STEREO
My jvc kd-r610 car receiver is not playing or anything. I blinks "protect"
  • 25 Answers
JVC head units go into protect mode usually when there is a short circuit on one of the speaker wires. Sometimes this is just caused by moisture in the doors or wherever the speakers are located. The first thing to do would be to reset the unit and see if it fixes the problem. To reset the unit there is a small button behind the faceplate which you will need to push in with a pen or other sharp object. Hold this button in for a few seconds. This will reset the head unit to factory settings which does mean that you will lose all of your saved radio stations, audio settings, color settings etc. If this does not work then one of your speaker wires is probably damaged. To find out which one unplug all of the speakers, reset the unit and plug them back in one at a time. When the unit goes into protect again you have found which speaker is causing the issue. Cheers, Dan
Posted on Apr 28, 2011
  • Mapela Jun 04, 2012
    Yay!!!! This totally worked for mine!!
SOURCE:
KD-HDR40 will not play any CDs, only displays a "CD reading" message.
Sounds like CD mechanism failure. Did some sticker or anything went inside? Any way, need service.
Mar 03, 2012 | JVC Kd-hdr40 Car CD/ MP3 Player
I can not get my jvc kd-r610 on fm radio. lost the manual. help
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=kd-r610
Aug 20, 2011 | JVC AM FM CD DET FACE CAR STEREO
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
My jvc deck says PROTECT on it and won't let me listen to music or anything! What should I do?
my jvc kd-s37 keep going into protect mode now how can i get it where it stays out i reset it several time but it still goes back into it
Nov 25, 2010 | JVC AM FM CD DET FACE CAR STEREO
After instal of JVC KD-R610, the words 'protect' flashes, and I'm not sure what i've done wrong. Wires match, connections are good, i tried the rest...???
this usually happens when there is a short in the speaker wiring (wires crossed) or when you have too many speakers hooked up. rule out these factors.
Aug 05, 2010 | Car Audio & Video
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
I believe i may have gotten some water in my JVC car stereo KD-R610, and I am wondering if there may be a way to save it? Is there a special or correct way to reset it. The radio comes on but says PROTECT....
If you have not put on the set after the water logging then you could have been saved. Now there is a chance that the processor section have shorted circuit. please open the set, use a hair dryer and warm up to clear up all the moisture. use petrol to clean the main board do not put any petrol on the main panel or plastic.but only the PCB. after cleaning heat again till you have warrmed up and cleared all moisture. reconnect the set and test. I hope this must clear your fault or else you will be having faulty componentts that needs further continuity and voltag checks for finalising. hope my advice helps. good day
Jul 05, 2010 | JVC KD-PDR30 Car CD/ MP3 Player
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
JVC AM FM CD DET FACE CAR STEREO Logo
2,570 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Dalynn Turner
Marvin
Marvin
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
