Question about IBM ThinkPad T30 2366 Notebook
IBM T30 won't boot with LCD, but will boot OK with external eonitor
Water got spilled on the laptop, IBM T30. Dried and cleaned it. Now after pressing a power button it will work for 5 seconds and after that will shut itself off only when in LCD mode. If I switch it to external monitor mode it boots up fine. (Since it is not enough time to engage the external monitor with Fn+F7, I switch it with a lid close switch). Could you please give me a suggestion on what it might be? Thanks in advance!
  • ibmt30 Aug 10, 2008
    Thank you very much for a promp reply! ThePC will not boot in LCD mode even if the ribon is not attached, so it is most likely the oxidation. Thanks! Could you please post the circuit cleaning solution brand or name you would use to do the job. Thanks!
  • IBM Master
  • 19,396 Answers
It means computer developed oxide on some contact, and this is causing a short that forces unit to shut down, laptop must be taken apart, dried properly, and eventually cleaned with circuit cleaning solution.
If problem stops when you turn to external display, then probably it is water or oxide in LCD ribbon cable connectors.
Posted on Aug 10, 2008
How to display on lcd
The bottom left key is labeled in blue, Fn. Hold down this key and press the F7 key at the same time. Repeating this will toggle between an external monitor and the LCD. If this does not work, try connecting an external monitor to the blue 15 pin VGA connector on the rear panel of your T30 and try this again. If you get external video you will know your video chip is working properly, but your LCD may not.
You didn't provide enough description of your problem to help you further.
Jul 06, 2012 | IBM ThinkPad T30 2366 Notebook
Hey I got an IBM T42. It boots fine when its clear but after that it horizontal lines being to appear througout the scree.
Either you can hook up an external monitor or access BIOS setup (Basic Input/Output System) to replicate if the horizontal line appears. This step will check if the problem is with the video card or the LCD.
If you get the horizontal line on the BIOS or never get it on the external monitor, then surely the LCD screen is beginning to fail. You need to reinsert and/or replace the LCD inverter or LCD itself.
However, if you see the horizontal lines on the external monitor but not on the BIOS, try to update the video driver. If this will not resolve the issue, you need to replace the video card or the motherboard of your laptop.
Hope this helps.
Jun 06, 2011 | IBM ThinkPad T30 2366 Notebook
My daughter spilled water on her IBM Thinkpad - she's dried the battery and everything looks fine, but it won't even power on.
HI there,
Spill damage to a laptop often short curcuits the motherbaord inside and often ruins it. There are some vendors on eBay who offer a flat rate service where they guarantee that if they canntot repair the spill damage, they will return the laptop with NO CHARGE for the attempt.
I've used several of these vendors anit's about a 50% recovery rate so far. If they CAN repair it, they'll give you a quote qhich could be from $125 to as much as $250.
Go to eBay and in the searchbox type in "Laptop Motherboard Repair" and look through the auctions/vendors to find one like I described above. Otherwise, your only option is to find a local laptop specialist (like I am in my town) and get a price for buying and replacing the motherboard.
Best Regards,
Marcus
Sep 24, 2010 | IBM ThinkPad T30 2366 Notebook
My ibm thinkpad t30 boots up but my monitor is blank
Do you hear any startup sound when you turn it on? If there is, try hooking an external monitor. If it has good display, replace LCD, if not then it may be a videocard problem. possible motherboard replacement will resolve this issue.
May 25, 2010 | IBM ThinkPad T30 2366 Notebook
My T30 turns on but the screen doesnt work?
Try to attach EXTERNAL MONITOR to check if you have display from External Display and to confirm that your Laptop System is still working. If you got display from external monitor, therefore you have a faulty LCD / Inverter (gives your LCD a back-light)
Apr 06, 2010 | IBM ThinkPad T30 2366 Notebook
T30 laptop - no picture on screen
It sounds like you may have the computer set to boot to an external monitor source. Try using the fn key and whatever "f" key up top that toggles the monitor source. if this doesn't work, try pressing f8 when booting up and boot into windows safe mode to see if it may be a driver issue or some kind of resolution issue.
Good Luck!
Jesse
Jan 04, 2010 | IBM ThinkPad T30 2366 Notebook
I'm getting power..but its not booting up
have you got any other external monitor? try to get screen with external monitor if you will have your lcd is not working, if you wont have any view , something wrong with mainboard or CPU
Jun 27, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
I have a problem with my ibm thinkpad notebook i want to connect my notebook hp projector how can i
When you connect a data projector or a monitor to the video output connector on the laptop you can toggle the display in various configuration by press and hold the blue Fn key and then press the F7 key (once or a couple of times as required) this key has a blue symbol of a pair of monitors.
Press it once the LCD will switch off and the display will switch to the external video output.
Press it again and the display will be on both the LCD and the external video output.
Press it again and the display will be only on the LCD.
Jan 17, 2009 | IBM ThinkPad T30 2366 Notebook
LCD blank on IBM T30 - 2366
You are lucky to have an external display! That means that your motherboard nor video card did not fry. Two possibilities here: the ribbon connector from the mobo to the lcd has been disconnected or your cathode tube/exciter is bad. You must have some electronic repair experience and laptops in particular for success here.   Every screw must be remembered as to its original location -lengths vary. ESD precautions must be observed (look that up if you don't know).  Follow the remove/replace procedures for the LCD and do not ever force anything. Here is a guide: http://www.insidemylaptop.com/replace-screen-inverter-in-ibm-thinkpad-t40-t40p-t41-t41p-t42-t42p-laptops/
 It is not difficult if you organize and use caution. Good luck, Steve Medley
Nov 10, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
200 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
