Question about Siemens Computers & Internet
My mouse pad is not working on my laptop - Siemens Computers & Internet
  • 36 Answers
Go to your mouse properties and see if you touchpad has been disabled on turned off. If that doesn't work - go to your device manager in your control panel and make sure your touch pad is installed correctlly. if it is, make sure it is enabled
Posted on Aug 10, 2008
Mouse touch pad not working
Try to Upgrade your Mouse Pad driver.
Your problem would be solved by doing so.
I have faced the same problem. I did upgrade Mouse Pad driver and Yes my mouse pad working fine.
Apr 24, 2013 | HP EliteBook 6930p Notebook PC
How di make my mouse work
usb mouse or mouse bad ?
Look at the type of mouse you have.
To date, there are three types of mice: the USB mouse, the PS/2 mouse and the Bluetooth mouse.
USB mice connect with a USB adapter, which has a rectangular shape. Conversely, the PS/2 mouse uses a PS/2 adapter, which is round.
Finally, there's the Bluetooth mouse, which has no external adapters.
Plug the mouse into your machine.
Now, how you do this will depend on the mouse you're using.
With a USB mouse, simply plug your device into your laptop's USB adapter, which will also be rectangular in shape.
For PS/2 mice, you'll need to plug it into a PS/2 adapter. Plug your mouse into the PS/2 end then plug the other end into your laptop's USB adapter.
And for Bluetooth mice, no plugging is required.
Install the mouse drivers.
If your mouse is not plug-and-play, you're going to need to install its drivers. To do this, insert the CD or diskette that came with your device.
The installation should occur automatically.
Pair your mouse, if using a Bluetooth mouse.
At this stage, non-Bluetooth mice are ready to be used.
However, if you are installing a Bluetooth mouse, you must perform one additional step: pairing it to your machine.
To achieve this, use your laptop's touchpad and right-click on your Windows screen. Select the option "Pair Device." From there, follow the on-screen instructions to sync your mouse with yourcomputer.
Place your mouse onto a mouse pad. Before using your mouse, you need to place it onto a mouse pad.
This should be done for all types of mice, whether they are wireless or trackball.
Otherwise, movement will be difficult
mouse pad
Examine your mouse pad.
Dirt and grime can affect performance and slow down mouse sensitivity, if not shut it down altogether.
Make sure the surface of the track pad is clean and that there is nothing that has managed to get beneath it or around any trackball buttons that could affect the pressing and depressing of the component.
Check to see if your mouse pad has been turned off.
If the Fn (Function) button at the bottom left of the keyboard is pressed in conjunction with some other key on the keyboard it can result in the disabling of the mouse pad.
To enable your mouse pad on a Windows PC go to the Control Menu.
Under the Printers and Other Hardware option, click on Mouse.
Then, click on the tab on the top of the pop-up menu that says Device Settings.
The touch pad for your computer should come up as a selectable option. Click on it and you will see the option to enable your device, then click OK. If this does not work,
Check the manufacturer of your laptop (for example, Toshiba) and then navigate to their official website. Find an area for Software and Drivers, and move on to that area.
Enter your laptop number (check your documentation/manuals and/or the bottom of the computer) and look through the drivers that are presented as a result of this number input.
It could be that your mouse pad simply needs updated drivers. Find the driver that corresponds to your computer and mouse pad (for example, most Acer laptops use a Synaptics touch pad).
Then, click on download.
Once the drivers have downloaded, double click them to ensure they install, restart your laptop, and your mouse pad should be working again.
hope this helps
Sep 09, 2012 | Compaq Presario CQ57-339WM
I have a dell xps M1330. Its mouse pad is behaving weird. If I try using it, it doesnt work but if I keep holding a shortcut key(play/stop/volume keys) while using the mouse pad it works fine. Any help?
hi,
your mouse pad dose not connect to the ground of device so when you keep and hold any
shortcut of keyboard , this connection done , and mouse pad work.
for this you (if you can) or a technician must remove the keyboard and change the flat cable
between mouse pad and devise .
good luck
gorbesia
Jun 19, 2011 | Dell XPS M1330 Laptop
The mouse touchpad,stopped working and now the mouse usb,has stopped working.
please chaeck the mouse pad lock mode or any light is glowing on top of the mouse touch pad?
Sep 05, 2010 | Computers & Internet
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
Mouse pad not working - external mouse works fine,
try to re-intall your mouse pad driver and update your machine's bios.
if still doesn't work then you mouse is faulty and might need to replace.
Jun 30, 2009 | Computers & Internet
Mousepad not working
Hi Sharad arya,
Try pressing Fn+F8 to activate/deactivate touch Pad.
takecare.
May 12, 2008 | Lenovo 3000 Y410 Laptop
To fix mouse pad
Before you dismantle your laptop, check that the pad isn't disabled. Go to control panel and click on Mouse, the mouse pad configuration should be in there. turn it on. also look for it in Device manager (right click on my computer, go to properties) make sure the mouse pad has a driver loaded and it's working.
Feb 25, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
167 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
