Question about HP Office Equipment & Supplies
When we push print the printer c6200 says to insert memory card. It is connected to the computer and connected
    Genius:
  • 1,689 Answers
The printer is being info-fed by the memory card, you can set the PC to do it through the utility of the printer, or you may leave the printer unplugged from the power outlet for about 30 minutes, reboot the computer and then power the print up again, this wil refresh the printers settinsg making it print throught he PC.
hope this helps
Posted on Aug 10, 2008
Memory card error
view & print button is used for viewing the content in the memory card if it is inserted in your printer. If you are giving job from computer and it is not getting printed try the following steps.
1. check the cable between computer and printer.
2. check the printer queue ( see a printer icon on the right bottom of the screen near time). if it is there double click and check whether any document is pending in the queue. if so cancel all pending job and restart the computer and try printing again.
Oct 10, 2013 | HP Photosmart D7160 InkJet Printer
P350 lexmark saying that a memory card is not present yet it is.also blue tooth on phone cannot connect to printa allthough it is all turned on.
Make sure you are inserting a compatible memory card for your model. Below is the list of compatible digital media memory cards for the Lexmark P350 printer:
  • CompactFlash I & II
  • Sony Memory Stick, Memory Stick PRO
  • Secure Digital (SD) Card
  • MultiMediaCard (MMC)
  • xD Card
  • Sony Memory Stick Duo (with adapter)
  • Mini Secure Digital (Mini SD) Card (with adapter)
  • Sony Memory Stick PRO Duo (with adapter)
  • SanDisk TransFlash Memory Module (with adapter)
  • RS-MMC (with adapter)
Guidelines to print via bluetooth:
  • You can print photos from a Bluetooth-enabled device such as a camera phone using a USB Bluetooth adapter.
  • Make sure that the Bluetooth Enable and Discovery Mode selections on your printer are set to On.
  • Insert a USB Bluetooth adapter into the PictBridge port on the front of the printer.
printmastert_72.jpg Note: Bluetooth adapter sold separately.
  • Once the printer detects the Bluetooth adapter, the following message appears on the printer display for five seconds: Bluetooth Dongle Connected.
  • To print photos from your Bluetooth-enabled device, see the documentation that came with the product.
Aug 15, 2011 | Lexmark P350 InkJet Photo Printer
Trying to print a picture from my dell computer. when i hit print on the computer printer does not print. what button do i push on the printer itself. when i go to view/print it just says to insert memory...
With the printer power on, unplug and then plug in the printer from/to the computer. This should force the printer to be reinstalled.
Check the printer status.
Click START>Control Panel>Devices and Printers>click on your printer. check the status for any error messages. On the printer status, delete all pending jobs. Once the printer status display shows that all pending jobs have been deleted, retry printing.
Let me know if printing is reestablished. Thanks.
Mar 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Printer wont read SD cards does read sony memory
If it does not seat (fit) properly, why say the printer will not read SD cards? It certainly will read SD cards that are supported. You can still upload to computer and print from there as you suggested.
Dec 27, 2009 | Canon PIXMA iP6700D InkJet Photo Printer
How do you transfer photos from memory card inserted in HP C5280 printer to my computer?
You cannot read that memory card inserted in HP printer to your Computer because that HP Card Reader port is only for direct access printing from memory card.
All you have to do is use a Multi-memory card reader into the PC where connected to USB port.
I'm sure 100 works!
Oct 09, 2009 | HP Photosmart C5280 InkJet Printer
Printer is is photosmart express mode and won't print document. Screen says 'you can insert a memory card'
if the printer is usb memory card type,, remove all memory chip or usb to printer, only connect it to computer pc and give command for printing.
Sep 28, 2009 | HP Photosmart C4180 All-In-One InkJet...
How do you transfer pictures on thememory card inserted in the print to the computer?
if you plug the memory card in the slot. software will see it and start automaticly.
May 30, 2009 | HP Photosmart C4480 All-In-One InkJet...
HP C5180 All-in-one : Memory Card Error, No memory card in it
  1. Remove the memory card from the camera.
  2. Locate the memory card slot on the product that is compatible with your memory card. Figure 1: Memory card slot locations c01331721.jpg 1 - CompactFlash (I, II) 2 - Secure Digital, MultiMediaCard (MMC), Secure MultiMedia Card 3 - xD-Picture Card 4 - Memory Stick, Magic Gate Memory Stick, Memory Stick Duo (with user-supplied adapter), Memory Stick Pro 5 - Front universal serial bus (USB) port (PictBridge-enabled)
    NOTE: Some portable USB flash drives with a read-only partition, such as U3 smart drives, might be incompatible with the front mass storage port on your product. These partitions are added by the manufacturer and may include utilities and other software. Refer to the manufacturer for additional details about your drive.
  3. If it is not already on, turn the product on by pressing the power button (c01324469.gif ).
  4. Turn the memory card so that the label faces inward and the contacts face the product. Figure 2: Inserting the memory card c01335108.gif CAUTION: Inserting the memory card in any other way might damage the card and the product.
  5. Gently push the memory card into the memory card slot until it stops. The memory card does not insert all the way into the product; do not try to force it.
  6. When the memory card is inserted correctly, the status light next to the memory card slots flashes and then remains solid green. CAUTION: Never attempt to remove a memory card while it is being accessed. Doing so can damage files on the card. You can safely remove a card only when the status light next to the memory card slots is not blinking. Do not pull out a memory card while the light is flashing green.
Step two: Print the photo
  1. Press Photo Menu . A message displays on the control panel with the number of files found on the memory card.
  2. Press the right (c01185072.jpg ) and left (c01185108.jpg ) arrow buttons to browse through the photos on the memory card.
  3. When the photo number you want to print appears, press OK .
  4. After selecting the photos, press Photo Menu again.
  5. Press the right arrow button (c01185072.jpg ) to select Number of Copies , and then press OK .
  6. Press the right arrow button (c01185072.jpg ) to select Layout , and then press OK .
  7. Press the right arrow button (c01185072.jpg ) to select Paper Size , and then press OK .
  8. Press the right arrow button (c01185072.jpg ) to select Paper Type , and then press OK .
  9. Make any other appropriate changes to the settings, and then press Print Photos .
May 23, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Can't download to computer from memory card
there should be 2 to 4 inserting ports in the printer for memory card, so you have to just insert the memory card in right port and there is also some type of jecks for memory cards to insert them in card readers.
Apr 13, 2009 | Computers & Internet
Printer keeps saying insert memory card
The message is not an error message and does not indicate an issue with the product. The message is designed to be an invitation to print photos from a memory card. Follow these steps to insert a memory card into the product. For more information please check the link bellow: http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01436439&cc=us&lc=en&dlc=en&product=3194498 Good Luck
Aug 21, 2008 | HP Photosmart C6280 Printer
44 people viewed this question
Seeker5211
Seeker5211
