Question about Sunbeam Microwave Ovens
PEELING COATING IN MY SUNBEAM MICROWAVE OVEN
I HAVE A 12 YEAR OLD SMALL MICROWAVE OVEN. WHEN I CLEANED IT RECENTLY I NOTICED THE BOTTOM OF THE INSIDE WHITE COATING PEELING OFF A LITTLE REVEALING A BLACK UNDERCOATING. IS MY OVEN TO BE A CONCERN TO ME? MS. ELOISE BORKOWSKI
  • ELOISEMBORKO Aug 10, 2008
    ACTUALLY MY MICROWAVE IS 8 YEARS OLD AND 1200 WATTS.
  • Sunbeam Master
  • 9,098 Answers
Yes, if the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
Otherwise, you can have rust and arcing.
Posted on Aug 12, 2008
I bought a microwave oven from next last year and just tried to clean it and the white coating inside is coming off I ordered in store and waited 12 weeks for delivery. Am I covered under guarantee
as i advised another questioner never buy a microwave with a painted interior as they will always peel.best to buy STAINLESS STEEL.read your paperwork and check your g/tee but if is it not in g/tee it is obviously not fit for purpose so take it back to the shop anyway.
Oct 23, 2017 | In Microwave Ovens
The coating on the bottom under the turntable is peeling off and there is a crackling noise and more peeling going on if
Please stop using and discard, it can be very dangerous to use it like this, fire, explosive, poison hazzard
Jan 31, 2016 | Microwave Ovens
Ceramic coating problems in microwave
1. you did put metal plate in it or spoon in it once.
2. oily spot left without cleaning.
3. you can paint the scratched are after cleaning it. not recommended
Mar 24, 2014 | Neff Microwave Ovens
Coating peeling off inside wall
The area will first have to be sanded smooth and cleaned and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's, etc.
Oct 25, 2012 | Magic Chef MCD1611 Microwave Oven
The metal is showing inside. The white coating is pealing. Is this dangerous?
The peeling of the white coating inside of the microwave oven is dangerous in terms of creating a fire hazard and potentially contaminating the food you cook within it. This can be prevented by cleaning up all splatters and spills immediately before using the microwave oven again. You can fix the peeling by replacing the microwave oven or repairing it. To repair it, you will have to remove the peeling coating and then repaint the interior of the microwave with paint that is designed for microwaves in general. Though, if you do this, you will have to let the paint dry up for at least 24 hours. I hope this helps you!
Feb 10, 2012 | GE Microwave Ovens
I have a GE microwave that is barely a year old. Recently, my husband was heating up some melting chocolate and white sparks started flying within the microwave. When we opened it, all we saw was that some...
Very difficult to explain briefly as microwaves are truly complex.
You will almost certainly have 2 problems. 1)You need to carefully sandpaper the area where the paint is peeling off and "only paint with appliance paint as this does not have lead in it and 2)The sparks are due to a variety of things, but the most obvious, replace your main capacitor and HV diode. This combination is the normal culprit for arching. If it continues after that, the Magnatron needs replacement as well (Unfortunately, for first time diagnosis, electrical testing equiptment is needed.)
Jul 30, 2010 | Microwave Ovens
Paint inside microwave oven bottom is peeling
The oven cavity will probably start to rust where the paint is gone. If you're up to it, sand it and paint it with a color that matches the interior color. Other then colors, there is nothing special about paint inside a microwave.
Jun 20, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Chipping/peeling rusting paint in interior under carousel
Scratches and bare spots are fairly common, but should be addressed as soon as they arise so the corrosion will not spread and arcing does not occur.
Unplug the power cord and remove the turntable and the support that is under the turntable. Clean the surface of the support wheels or any other part that rubs on the oven cavity.
Take some mild sanding cloth or scotchbright and clean the bare and rusted areas in the microwave. Use appliance touch up paint to re-coat the surface. You can find the touch up at most anywhere that sells appliances, it comes in a plastic bottle similar in appearance to fingernail polish, yes it does have a brush inside.
Let it dry per the instructions on the bottle or 24 hours if not specified.
May 11, 2010 | Emerson MW8102SS 1100 Watts Microwave Oven
Bottom of GE interior door microwave is burnt/rusted
just use sand paper to clean the rust then use some high temperature paint (sold in tins) eg spray paint but it must be labeled high temperature and spray 2 to 3 coats . your microwave should be safe again
Nov 17, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Microwave Ovens Logo
437 people viewed this question
Top Sunbeam Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sunbeam Microwave Oven Expert? Answer questions, earn points and help others
