Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
82 flh clutch adjustments
After installing new clutch plates and steels and a heavy duty throw-out bearing kit, using a Clymer manual for the specs the clutch seems to function properly. My problem is around 70-80 miles an hour the engine will rev way up, indicating that the clutches can't handle the power. I used 1 1/32" for the adjustment from the pressure plate surface to the inside surface of the release disc (actually the release disc is stamped so that it has a 1/4" (cup) on the outside edge) and that is where I pulled the measurement from (to the innermost surface). Should I instead measure to the top (outside) surface of the release disc?
    Genius:
  • 2,028 Answers
Doesn't matter. Sounds like you have it in properly, and the high end play you're getting can be adjusted out. Adjust it to where the you don't have the high end play, and also be sure that there is no low end drag. High end being 70-80 mph and low end being idle, I say this because I've had to deal with some weekend warriors lately that would like to work on their own bikes, but don't know their wank from a torque wrench. If you've installed your own clutch, I know I'm not dealing with one. Now, keep in mind that if you can't get the adjustment from the current set up, then you may need to add a friction, steel, or spacer, in order to get it working properly. I suggest adding a friction, however, you will have to keep within tolerance, so in some cases, a friction or steel won't work, and you have to go with a spacer. Also check the ramp and bearings, if you haven't already. A bent or worn ramp, or bad ramp bearing can cause a float at higher speeds. Let me know what you found.
Posted on Aug 12, 2008
2007 holden epica 2.5l manual has noise only when clutch is depressed
The throw-out bearing is worn and making the noise. The bearing only have pressure on it when the clutch is depressed.
Advise to have new clutch plates installed along with new throw-out bearing since it's all apart anyway and just a few more dollars for the clutch plates. It's a lot of labor.
Good Luck
Sep 22, 2017 | Holden Cars & Trucks
New clutch kit on my 2000 Audi TT a year and 3 months ago. Thrust bearing (throw out bearing)noisy! Faulty workmanship or faulty parts? John.
most clutch kits do not include a new throw out bearing as that is bought separately
most likely that the mechanic doing the job thought that if the bearing was included (around $25.0 aud) that he would not get the job or he ripped you off by not putting the new bearing in
could be the bearing as they do work hard and are mass produced and are known to fail early
a faulty bearing is shown by a tinny rattle when the clutch is engaged or a growl when the clutch is disengaged
if the noise goes when the clutch pedal is pressed slightly , it indicates that the bearing is rattling on the pressure plate fingers and there is a need to adjust the freeplay at he slave cylinder
.it is not necessarily a faulty bearing
Apr 12, 2017 | Audi Cars & Trucks
Not able to select gears when engine is running,but when off selects easy,after fitting a new kit still does the same
The clutch is not releasing , several things can be the cause, check the following , Throw out bearing same size,clutch driven plate not fitted back to front, clutch fork is fitted to throw out bearing housing and pivot mounting, is the slave cylinder rod the same length, has the clutch free play been adjusted, has all air been bled from the master cylinder, If cable operated has free play been adjusted. Has the new pressure plate the same throw as the old one.
Jul 02, 2016 | Cars & Trucks
What size clutch in a 1999 th 5 speed magner
clutch size is 240 mm x 26.1 mm with 23 tooth spline
get it as a kit including the throw out bearing from most auto spares shops
genuine will cost at least $300 more
If you do a lot of heavy work (towing ) then for a bit extra get a heavy duty clutch as it will pay for itself in the long run.
they are available on e-bay
Feb 12, 2015 | Cars & Trucks
Why is my ranger rough on shifting to all gears?
The clutch may be going out. First check the fluid level in the clutch master cylinder-if you have a hydraulic clutch. If just a cable operated clutch, check that it is adjusted. The cable will have an adjusting nut to take up slack.
If fluid is full, or if cable is adjusted right, the clutch will probably need replacing: a new clutch disc, new pressure plate, new throw-out bearing. Buy this as a kit for about $150.
Sep 07, 2014 | Cars & Trucks
How to Install a new eaton 2104-20892561 clutch on a Mack Ch613
It\'s the same for all CH models and then some ,do you have the old one out ? I will look for you, I have done a lot of them ,I\'m going to ask a few questions so bear with me , ok ? ,do you have a pilot shaft or can borrow one ? for aling clutch ,and a big tranny jack , did you remove or have motor out or are you just removing tranny. ? it\'s all just really heavy it\'s a 2 person job no dough, but for the most part same as a car or truck, OTC makes a clutch installing tool to hold the two clutch plates and two pressure plates , hard part is putting throw out bearing in and holding clutch lever all the way back so it can fall in and don\'t forget to put clutch brake on shaft, if using 1 piece unit, aftermarket ones break down to easy (crap) but you can put it in after an adjust it when adjusting clutch for first time .hope this gets you going ,get back to me and I\'ll do my best to get info for you or a place for you to get it hope this helped .
Woody
Sep 01, 2014 | Cars & Trucks
When i slightly let out the clutch it starts to move
you need to check the Throw out bearing, the Cherokee XJ has a Hydraulic Throw out bearing. the slave cylinder is Inside the bell housing and the transmission and everything needs to be removed to get to it. You will see two hydraulic lines that go from the slave calendar to the throw out bearing. chances are that the bearing is bad, maybe the roller part is ok, but the part that expands to push on the pressure plate is bad. I had this and it was my first hydraulic bearing, but it is a pain, because everything has to be removed to get to it. good luck.
Jul 31, 2012 | 1993 Jeep Cherokee Country
92'isuzu pick-up, 2.3L.manual tran. the truck starts and it goes into all gears, but it hardly moves.I adjusted the clutch cable and it got better I always had to adjust the cable. now it bearly move on...
Yes it is time to install a new clutch kit(clutch disc,pressure plate ,throw out bearing and pilot bearing)also have the flywheel resurfaced.The disc has gotten too thin to be clamped by the pressure plate.Best if you replace everything at once with new parts,avoid rebuilt parts.Good luck!
Mar 06, 2011 | 1992 Isuzu Pickup
Clutch is noisy,when i depress the clutch the noise goes away
this noise is caused by a noisy clutch throw-out/release bearing, that is the part that presses against the pressure plate and disengages the clutch disk, the transmission must be removed to replace this part, so it is best to replace the clutch assembly at the same time, the labor for both is the same, about 5 hours
Oct 23, 2009 | 2003 Toyota MR2 Spyder
Manual clutch
Sounds like the wrong pressure plate. I got a kit from Autozone and it was the wrong pressure plate. My old one was obviously thicker. With the new pressure plate, the shift fork was almost at full travel before any resistance. That's no good. I had to pull the transmisssion again and use my old pressure plate. Luckily, it was in good condition. Then, the clutch slack was easily adjusted and works great.
Jun 07, 2008 | 1992 Isuzu Pickup
Lands Phones Logo
198 people viewed this question
Top Harley Davidson Lands Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ted dux
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
