Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
42H83 Convergence Green convergence is curved... Do STKs ICs need to be replaced? I currently have STK392-110 ICs.
  • smag Aug 10, 2008
    Are STK392-150 acceptable replacement or should I stick to STk392-110.
  • smag Aug 20, 2008
    Changed both STK ICs (with -110) and all 6 1.8ohm resistors. Now all color are curved at the edges and I can not adjust convergence in Y, only in . Any ideas?
  • Toshiba Master
  • 8,617 Answers
Yes the convergence ICs need to be replaced, however so dont the six 1.8 ohm 1watt resistors as Toshiba recomends replacing those six resistors when the ICs are changed. You can get the 50H71 / 50H82 Convergence repair kit as the 42H83 is identical to the 50H71 series, so the kit will work for your model. Heres the link where you can get the kit.
http://servicemanuals.vstore.ca/
Posted on Aug 10, 2008
  • Sonny Berry
    Sonny Berry Aug 10, 2008
    The STK392-150 are suspossedly a direct interchange, But I have heard of problems switching them in toshibas and panasonics. I would recomens not going much higher than STK392-120 unless you change out the convergence resistors and ICs as a unit.
  • Sonny Berry
    Sonny Berry Aug 20, 2008
    Check the large two watt resistors near the Ics to see if any are open, Also double check the solder connections on the Ic pins.
Toshiba 42h83.... The blue convergence will not line up. The horizontal will but the vertical will only move so far. when touch focus starts the reds and greens are perfectly strait the blue vertical is...
bmarino18,
Initially I would have told you to replace the convergence ICs but after reading your post carefully I think you could have a problem with the convergence box. The lines can only be bent/curved for two reasons. One - the yokes are bad causing an undue strain on the power supply and not being able to correct the problem. Two - the convergence box/board is bad and is not holding the settings causing the curve you see. I cannot tell you which problem you have. You wil have to determine this. I do have a tip at http://www.fixya.com/support/r4273935-replace_digital_convergence_box which may be helpful.
Thanks for using FixYa and for the great rating.
hardrocko
Dec 08, 2010 | Toshiba 42H83 42" Rear Projection...
There is a blue shadow to the picture. The color chips were recently replaced and it has been doing this since the replacement. I have tried to adjust the convergence but on the screen with the cross hairs...
STK ICs that were replaced maybe the reason convergence is not lining up or you may have some open low ohm resistors that need to be replaced ,near convergence ICs. STK392-570.
Mats Electronics has STKs for 14.95 each
1-800-628-1118
Jun 23, 2010 | Mitsubishi WS-55511 55" Rear Projection...
Picture color is seperated and curved why?
convergence ICs STKs big black ics have number on them replace Both Call Mats 1-800-628-1118
STK394-020
Oct 04, 2009 | Samsung HC-P4752W 47" Rear Projection...
I have a zenith rear projection screen.the left half of the screen is fine.the whole right hand side has a green tint and has double vision.
Bad convergence causes this replace STKs or whole convergence Board STK ICs are big black ICs will have part # on them STK392-110s call Mats for STKs 1-800-628-1118 or to replace whole board call Zenith exchange 1-800-632-6637 they even have power supply boards when in stock or they can rebuilt your board.
Sep 21, 2009 | Zenith A60M91W 60" Rear Projection...
Picture is multi color, double shadows, curved
This is failure of convergence out ICs in TV. Qualified TV tech will replace convergence out ICs or board.
Feb 14, 2009 | Philips Televison & Video
Convergence
Replace Both of your STKs convergence ICs big black ICs STK392-110s use number on your STKs for replacement www.electronix,com 1=800-223-3205 for Parts if they are 110s use 180s if 020s use 040s
Dec 26, 2008 | JVC AV-32D305 32" TV
Sony KP-511HW40 - blue/green tint issue - convergence issue?
Replace your convergence ICs STKs big black ics Go by number on them STK392-560 ect..... Parts you can order on line www.electronix.com or Call 1-800-223-3205 you will also need silicon heat sink compound to put on New ICs replace Both STKs
Dec 25, 2008 | Sony KP-51HW40 51" Rear Projection...
Toshiba 55H70 lack of convergence, then no picture at all
Replace Both of your STKs they are your convergence ics they are big black ics have STK number on them if they are using 110s upgrde to 180s STK392-180 they are better ics. Call Electronix Parts 1-800-223-3205 they will have STKs.
Dec 24, 2008 | Toshiba Televison & Video
Can't control red convergence on VS-45607
The STKs are three channel ICs they each control horizontal and vertical of one color the third channel controls part of green and the other half of green is controled by the other ICs third channel. Its customary for the Ics to fail and only have one channel bad in the IC. However its recomended to change both because of the bad Ic having green it can actually weaken the other IC and that one will fail shortly.
Aug 03, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Our model 42h83 toshiba projection tv is having color convergence problems (specifically the green). We tryed adjusting the convergence but that doesn't work. We don't want to spend $400 dollars that I am...
You need to replace both convergence ICs they are both STK392-110 ICs. You can get replacements at the following link and they provide free instalation instructions with pictures on how to remove and replace the convergence ICs.Here is the link.
Jul 01, 2008 | Televison & Video
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
693 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
