Washing Machines Logo
Posted on Apr 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Ringer just goes around instead of backwards an forwards so clothes get tangeled around agitator
Anonymous
Level 2:
Scholar:
  • Expert 125 Answers
  • Posted on Apr 28, 2011
Anonymous
Expert
Level 2:
Scholar:
Answers
125
Questions
0
Helped
26583
Points
379
This must be a top load unit. Your agitator dogs are probably shot. Pull up your agitator and replace them. They're just tiny plastic pieces with ridges on one end. The ridges are worn off no doubt. Usually this is maybe a 5 dollar fix. Good luck.
2answers
Clothes getting twisted around agitator
That does not sound good. New dogs sound great, but you must get to the bottom of why the clothes are becoming twisted on the agitator. Usually not enough WATER. Think loose flow of clothes submerged.
Long story short, you cannot jam pack this machine. Less clothes, more water, will equal long life.
Be sure that the mating teeth for the dogs, is not damaged. Slipping here would make loud noise.
More water, less clothes.
While stitching the cloth goes backwards instead of moving forwards.the backwards stitching switch is constantly on. What should I do
check to see if your machine is in buttonhole mode, one of the legs of the buttonholer will always be a reverse zigzag.
Why when we start sewing the cloth goes backwards instead of coming forward?
It should sew from the front to back so, from your description, it sounds as if it is working correctly. Perhaps you could explain more clearly if this is not the solution
One piece agitator wraps cloths
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
2helpful
Janome machine going backwards instead of forwards. Goes forward if I hold the reverse button down.
sounds like a screw may have become missing to keep the reverse knob in its proper position so it is backwards inside the machine
2answers
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
1helpful
Agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
2answers
Cordless phone setup instructions
Click on Menu on the base
click on the forward >> or backward << keys until it says the day of the week
click on set/ringer soft key
use forward >> or backward << to adjust the time and AM/PM
when you are done either click menu or wait and it automatically goes back to normal.
Agitator stops when sweeper is pulled backward
If you have made no changes to the vacuum's setup and are using it on same carpet you have previously used it on with no problem, then the most likely cause is the agitator/beater bar's drive belt is worn or on some models may have a tension adjustment which is set too loosely. This can also be caused by having the vacuums height adjustment set to low for the carpet or flooring you are using it on, causing to much drag when the vacuum is pulled backwards for the agitator to overcome.
The vast majority of agitators turn in a forward direction, as if it would pull the vacuum forward, when you pull the vacuum backwards the drag is increased.
So...First check height adjustment (a no cost fix), then check out the tension adjustment (if present on you model, some engage when top of vacuum is tilted back after stepping on the release pedal) Lastly, consider changing belt especially if you have had the vacuum awhile or if it gets a fair amount of use or it you seem to need to use it on a low height setting all the time to vacuum up debris.
Hope this helps!
Top Haier Washing Machines Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
