Question about Car Audio & Video
Parking brake wire override
Tryong to hook up my dvd player in my car, but I do not know how to override the parking brake wire can you help?
  • 1,586 Answers
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Posted on Aug 11, 2008
XDVD700 how do i override the E Brake wire
usualy just hooking the e-brake wire to ground will do it. You may want to use a switch, hook one end to ground,one end to the wire leading to the dvd. that way you can flip it on and off when you want the dvd player to think the parking brake has benn engauged. Hope this helps.
Aug 17, 2009 | Car Audio & Video
Warning message!
this wire is the gray wire with the round eyelet. go to a metal ground and the Video will play
Jan 23, 2009 | XO Vision XO9013 Car DVD Player
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Dec 30, 2008 | Pyle PLTS76U Car DVD Player
Parking brake bypass
apply 12v positive to the wire to bypass the parking brake
Dec 12, 2008 | Jensen VM9510 Car DVD Player
Bypassing car dvd parking brake
Usually the wire should be grounded. Connect the wire to a ground point via a switch (is illegal to watch TV/DVD while you're driving)
May 06, 2008 | Dual XDVD8181 Car Video Player
Parking Brake Bypass
I know my PLTS75 when we hooked it up. you connect the brake wire to the negative pole to bypass that
Mar 28, 2008 | Pyle PLDF7IN Car DVD Player
Dual Parking Brake Code HELP!!
the esiest way to solve these problem is to make a switch connecting the blue/white with the brown cable it would work just find i had the same problem.
Mar 10, 2008 | Dual XDVD8181 Car Video Player
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Jensen
is it the solid yellow wire if so that is the memory wire and it should be hooked up. if you are talking about the parking brake wire you either need to hook it up the the parking brake spring or bypass it
Nov 21, 2007 | Jensen VM9510 Car DVD Player
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
